Boom Sheaves in a 1990 C&C 37+
6 replies to this topic
#1 RHH
RHH
  • 2 posts
Posted 24 May 2013 - 02:00 AM
I have a new (to me) C&C 37+ and need to replace all 6 sheaves in the boom (inboard and outboard reefing lines and outhaul).  All 6 appear to be original (1990).  The outhaul was wire and I am replacing it with Dyneema.  Each sheave (plastic for the reefing lines and aluminium for the outhaul) is 51 mm od (2 3/8), 13 mm id (1/2) and 16 mm (7/16) wide.  The width is the problem, they each have their own channel and I cannot find ones that take a 1/2" pin but are only 7/16" wide.
Help?
Thanks!
#2 Overbored
Overbored
  • 487 posts
Posted 24 May 2013 - 02:27 AM
they make them to fit your boat and very fast. http://www.zephyrwerks.com/default.asp
#3 Ishmael
  • 16,892 posts
Posted 25 May 2013 - 02:05 AM
Go to http://cncphotoalbum.com, sign up for the email list and ask your question there.
There's a bunch of 37+ owners and a lot more with other boats and many opinions, I'm sure someone knows.
#4 Gaasyendietha
Gaasyendietha
  • 34 posts
Posted 25 May 2013 - 10:54 AM
try Klacko they made the original:
Built all C&C masts.
http://www.klackospars.com/
#5 Ishmael
  • 16,892 posts
Posted 25 May 2013 - 02:11 PM
My mast (C&C 35-3) supposedly came from the C&C spar shop. Klacko built a lot of the early masts, but I think C&C had an internal shop for a while.
Klacko says they built the masts for "24,25,26,27,30,33,34,38,40,43,51, and all custom".
Edit: My spar drawings say the mast is the same extrusion as used on the 34, but I know that at least two different extrusions were used on the 35-3's.
#6 VikingBlod
VikingBlod
  • 30 posts
Posted 27 May 2013 - 08:23 PM
I have a 1990 C&C 37/40 XL. The mast in my boat is from Off Shore Spars. Take a look at their online store.
http://www.offshores...in-sheaves.html
#7 RHH
RHH
  • 2 posts
Posted 03 June 2013 - 04:52 PM
Thank you, offshore had them in stock!
