Filling screw holes in aluminum extrusion
aluminum extrusion hardware
12 replies to this topic
#1 Ajax
Ajax
  • 8,865 posts
Posted 06 July 2013 - 01:07 PM
On old boats that have seen years of hardware modifications, what are the best methods to fill in old screw and rivet holes to maintain the structural integrity of the spar?
So far, all I've seen is screwing in allen-head plugs coated with Lanacote. Are there any other methods that I should be aware of that might be better?
#2 Trendsetter
Trendsetter
  • 1,935 posts
Posted 06 July 2013 - 01:53 PM
I have had welders come in and spot weld all the spots to fill in the holes and make it whole again.  short of that I think you are more or less playing tear along the dotted line even if you fill it with screws
#3 Wet Spreaders
Wet Spreaders
  • 1,607 posts
Posted 06 July 2013 - 02:14 PM
The PO had screwed a cam cleat to the mast - I think that it was for the kite halyard, although using it seems like a really crappy idea to me, so I removed it. I filled the holes with Marine Tex (white) and put a plastic bag over it while it set to make it smooth. I'm sure that I could find them if I look, but you can't see them from the dock, so cosmetically that's a decent, low cost, choice. Not helpful structurally, obviously.
#4 SloopJonB
SloopJonB
  • 18,788 posts
Posted 06 July 2013 - 05:57 PM
Welding should be minimized on spars - it screws up the heat treating.
#5 Mr. Fixit's brother,, Mr. Fixit
  • 1,130 posts
Posted 06 July 2013 - 06:07 PM
http://www.alibaba.c..._aluminium.html
#6 dreaded
dreaded
  • 9,125 posts
Posted 06 July 2013 - 07:14 PM
just pop a rivet in and forget about it...
#7 One eye Jack
One eye Jack
  • 1,209 posts
Posted 06 July 2013 - 08:15 PM
Monel pop rivets or screws.. Stainless reacts with the aluminum.. Welding not a good idea as another said, it can screw up the mast with the heat. But he holes need to be filled as an empty hole can cause problems with flexing etc.
#8 Ajax
Ajax
  • 8,865 posts
Posted 08 July 2013 - 01:55 AM
Ok, thanks for all the good info, gents.
#9 pauloman
pauloman
  • 62 posts
Posted 10 July 2013 - 01:31 AM
I've heard of success filling holes old screw holes in aluminum by adding standard epoxy thickeners to an aluminum filled mcu paint - a google search for MCU aluminum should maybe turn up something
#10 Jim Conlin
Jim Conlin
  • 578 posts
Posted 13 July 2013 - 11:34 PM
Paul, by chance, do you sell this miracle stuff?
#11 CaptKen
CaptKen
  • 330 posts
Posted 15 July 2013 - 12:19 PM
JB Weld might work.  It is similiar to Pauloman's idea but off the shelf.  I've had good luck repairing small bits in car and lawn mower engines with it.
#12 sailorbob
sailorbob
  • 532 posts
Posted 16 July 2013 - 03:43 PM
JB Weld makes a bunch of different fillers.  Make sure you get the one for ALUMINUM otherwise you will have a dissimilar metal issue!
#13 SloopJonB
SloopJonB
  • 18,788 posts
Posted 16 July 2013 - 11:25 PM
You can buy powdered metals to use as thickeners - presumably aluminium is one of them.
