Raytheon st400+ gears
Autopilot parts
3 replies to this topic
#1 JRC808
JRC808
  • 213 posts
Posted 12 July 2013 - 09:43 PM
The drive motor on my 5ksb's wheel pilot is working well, but the plastic gears inside the tube in front of it connecting the motor to the sprocket to turn the wheel are slowly disintegrating as more and more teeth break off causing self destruction. Any one else have this problem? Anyone know who sells the gears without first taking a leg or firstborn? It's an older mark I black colored systemAttached File  image.jpg   99.49KB   13 downloads
Attached File  image.jpg   90.13KB   12 downloads
Sorry for the sideways shit.
#2 CaptKen
CaptKen
  • 330 posts
Posted 18 July 2013 - 12:31 PM
I know this guy does old Autohelm control heads, I do not know if he does gears and other bits.
Oliver Midgette
Trident Marine Electronics Inc
Norfolk, VA
www.tridentmarineelectronics.com
#3 Py26129
Py26129
  • 2,025 posts
Posted 18 July 2013 - 01:20 PM
Else, do a search for gears & sprockets in your local area. You may be able to source something "generic" to fit the bill.
This approach has worked well for me when replacing bearings in the apparent wind whirlygig at the top of the mast and replacing delrin balls in blocks.
A quick search turned up these guys. http://www.martinspr...t.com/locations
#4 Speng
Speng
  • 4,984 posts
Posted 30 July 2013 - 05:59 PM
Yeah those gears are probably generic. If you can figure out the spec a local shop or this interweb thing can probably find them. If they're custom a local CNC shop might can cut them out of HDPE or whatever they were originally made of.
