Macif Going Big
10 replies to this topic
#1 Icedtea
Icedtea
  • 3,715 posts
Posted 24 September 2013 - 09:23 AM
Here's a press release from Macif stating they're building Gabart a circa 100ft tri to go out and break some records.
States that there'll be an attempt to break the record set by Banque Pop. Wonder will they go again as Spindrift?
I read it in French, not so sure if there's an English version.
It's VDLP designed, launch date set for 2015 sometime.
http://www.macifcour...e-macif-en-2015
#2 Corley_
Corley_
  • 184 posts
Posted 24 September 2013 - 09:38 AM
I assumed from the press release that they are focused on the solo multihull round the world record attempt but it doesn't actually say as much literally.  Still I think a 100' conventional foil assist trimaran would not be competitive with BPV so they are going for the solo record (I think) as a 100' multi has proved to be manageable by the excellent French solo sailors.
#3 oioi
oioi
  • 886 posts
Posted 24 September 2013 - 09:53 AM
Confirmation that it is solo here
http://www.thedailys...francois-gabart
Whilst exciting its a shame that he is not going to defend his vendee win, guessing the vendee will be struggling for a strong fleet in 2016
#4 Icedtea
Icedtea
  • 3,715 posts
Posted 24 September 2013 - 10:04 AM
I think the change to semi-one design will hurt the Vendee rather than help it.
Makes more sense actually for him to go for the solo as I think Joyon and Coville have taken those tris as fast as they are going to go.
#5 Corley_
Corley_
  • 184 posts
Posted 25 September 2013 - 01:14 AM
My observation from the provisional specs is that VPLP are pushing the beam out relative to the Iren's designed Sodebo and IDEC it's still not extreme but will provide more righting moment.  This boat will have a 20m (65') beam approximately vs about 16.5m (54') on Sodebo and IDEC.
A trimaran of about 100 feet long in the final category, intended for offshore navigation alone.
Length: 30 m
Width: 20 m
Mast height: approx. 35 m
Surface of sails to the close: 600 m²
Downwind sail surface: 700 m²
Sodebo
Mise à l'eau : juin 2007
Port d'attache : La Trinité sur Mer
Architectes : Nigel Irens / Benoît Cabaret
Calcul de la structure : John Levell
Dessins des appendices : Martin Fischer
Etudes hydrodynamiques : Yann Roux
Constructeurs : Boat Speed (Australie)
Poids en charge : 12 tonnes
Mât : basculant 35m
Surface grand-voile : 237m²
Surface solent : 158m²
Longueur : 31 mètres(102 pieds)
Largeur : 16,55 mètres (55 pieds)
Toutes les voiles sont en Cuben Fiber ou en D4
IDEC II
Longueur hors tout : 29.70 m
Longueur flotteurs : 24.5 m
Largeur : 16.5 m
Poids : 11 t
Surface de voilure au près : 350 m²
Surface de voilure au portant : 520 m²
Hauteur de mât : 32 m
Chantier : Marsaudon Composites Lorient
Mât et bôme : Lorima
Appendices : Gepeto
Calculs : Hervé Devaux
Voiles : Incidence Brest
and for comparison Groupama3's specs, this is the Jules Verne trim so the mast fitted for the Route du Rhum was shorter (anyone know how long the "short" mast is ?).  The sail area and mast height were reduced for the Route du Rhum when Franck Cammas solo raced the boat to victory.
  • Build date: 2006
  • Architects: VPLP
  • Type: Trimaran
  • Shipyard: Multiplast
  • Length : 31.50 metres (103.3 ft)
  • Width : 22.50 metres (73.8 ft)
  • Displacement : 18 tons
  • Mast height: 41 metres (135 ft)
  • Sails : 557 sqm / 828 sqm
  • Crew: 10
#6 umpire
umpire
  • 1,344 posts
Posted 25 September 2013 - 10:16 AM
Already confirmed that Spindrift is going for the JV
http://www.spindrift...-2/2013-season/
#7 Icedtea
Icedtea
  • 3,715 posts
Posted 25 September 2013 - 11:17 AM
Wayheyy that'll be entertaining, anyone know if they'll be making any mods to the boat for it? Or just going with her as she is?
#8 samc99us
samc99us
  • 1,186 posts
Posted 26 September 2013 - 09:20 PM
I hope she makes some mods, no idea how Spindrift 2 will break the extremely impressive records she already set as BP V. 47.16kts top speed, averaging 37.8 kts? That's damn hard to beat without full flying capability IMO, or a significantly more powerful boat.
#9 MR.CLEAN
  • Reporters
  • 37,163 posts
Posted 26 September 2013 - 09:42 PM
Gabart is fit, strong, young, and brilliant.  He should be able to tame the additional speed and power the Irens tris purposefully lack.
#10 MR.CLEAN
  • Reporters
  • 37,163 posts
Posted 27 September 2013 - 06:43 AM
http://www.sealaunay...d-one-imoca-60/
#11 Vincent DePillis
Vincent DePillis
  • 987 posts
Posted 29 September 2013 - 11:35 AM
They keep moving the mast back.  This one sits on the aft beam!
