UV Protection for Carbon Sprit Pole
20 replies to this topic
#1 WHK
WHK
  • 1,184 posts
Posted 29 September 2013 - 11:39 PM
I'm buying a J/109 and have the following recommendation from the survey report:
The exposed end of the retractable spinnaker sprit should be re-finished to prevent UV degradation
What is the recommended method to re-finish the exposed end of the sprit pole for UV protetction?
#2 Christian
Christian
  • 9,265 posts
Posted 30 September 2013 - 12:20 AM
Paint
#3 pacice
pacice
  • 378 posts
Posted 30 September 2013 - 07:06 AM
clear coat
#4 jerryj2me
jerryj2me
  • 1,740 posts
Posted 30 September 2013 - 11:24 AM
get a cover made for it as well.
#5 Christian
Christian
  • 9,265 posts
Posted 30 September 2013 - 03:45 PM
Only if the clearcoat has good UV properties.  If going clear:  Awlgrip
clear coat
#6 _Vegas_
_Vegas_
  • Reporters
  • 4,672 posts
Posted 30 September 2013 - 03:54 PM
Awlcraft 2000 Clear is the best you can get
Automotive Clear Coat works very well too - like Dupont ChromaClear
#7 WHK
WHK
  • 1,184 posts
Posted 30 September 2013 - 03:58 PM
Thanks for the suggestions. Since the area is small can I use a Preval sprayer or will I have to use a real paint pot and spray gun?
#8 Christian
Christian
  • 9,265 posts
Posted 30 September 2013 - 11:27 PM
You can even brush it on. If using Awlgrip clear it flows nicely if you use the brush thinner
#9 Tucky
Tucky
  • 3,474 posts
Posted 01 October 2013 - 01:53 PM
+1 on the brush- just use foam brushes and a bit of thinner and it will look fine if you are careful. Trying to clean a good brush or spray equipment is not worth it for a small job.
#10 Raked aft \\
Raked aft \\
  • 1,505 posts
Posted 01 October 2013 - 02:34 PM
After you clear coat w/ awlgrip.  Put a couple coats of car wax on it.  Most have good uv protection, (look on bottle)
 Can't hurt...
#11 WHK
WHK
  • 1,184 posts
Posted 01 October 2013 - 08:45 PM
Great - thanks for the info.  I'll be offline the next few days headed to Naptown so we can deliver the boat back to Newport.  Refinishing the sprit is on my project list now.
#12 foshizzle
foshizzle
  • 77 posts
Posted 15 October 2013 - 04:39 PM
Assuming it's carbon/epoxy, you should find out if the epoxy matrix used in the sprit has UV inhibitors, or if a UV inhibited coating was used in the lay-up, in which case additional protection may not be required.  The carbon fiber is not affected by UV radiation.
#13 Christian
Christian
  • 9,265 posts
Posted 15 October 2013 - 05:36 PM
That is just plainly bad advice
#14 solosailor
solosailor
  • 2,191 posts
Posted 15 October 2013 - 05:45 PM
UV inhibitors in epoxy resin is like drinking sunblock.    The protection needs to be on the outside !
#15 e63s AMG
e63s AMG
  • 1,166 posts
Posted 15 October 2013 - 06:37 PM
how do you remove the bad layers? sanding?
#16 Raked aft \\
Raked aft \\
  • 1,505 posts
Posted 15 October 2013 - 07:31 PM
^ yup,
  i'd start w some 320 on an orbital hand sander.  That's what i used and was just right.  not too gritty, not too fine.  The goldey locks paper...
#17 SailAR
SailAR
  • 974 posts
Posted 15 October 2013 - 08:15 PM
Also, depending upon the tolerance, be careful to not add too much paint, or you will lots of fund getting the pole to move....
#18 Raked aft \\
Raked aft \\
  • 1,505 posts
Posted 15 October 2013 - 08:37 PM
Not sure about awlgrip clear, but i used West 207 clear hardener and rolled it on with a 6" foam roller.  Did it in the garage where it was cooler than room temp, say 65.  and it came out like glass.  only in a few spots did i use a brush to tip out some small air bubbles.
  I only loaded the roller slightly, and ran strokes down the length, rotating the pole after the top half was coated.  Did two lighter coats, no sanding between.
  Use a good hand shop light and watch for runs on the sides/bottom after each coat, they can be easily rolled out after your done with a coat. If you keep the coats thin, you shouldn't get runs anyway.
 That was 2 years ago and the pole still looks great!
#19 Wet Spreaders
Wet Spreaders
  • 1,607 posts
Posted 16 October 2013 - 12:36 AM
Congrats on the new boat.
I had this issue with the pole on my J105 - hot carbon in the sun - the exposed clearcoat lifted and flaked off a 4-year new pole. I sanded the delaminated clearcoat off and sprayed with exterior gloss polyurethane in a can from Home Depot. Looks great and still going strong +2 years later - $4.95 plus half a sheet of 220 grit from the shed.
Or you could get all anal and fancy with bunny ass-fluff crocus leaf marine exotic polishing and two-part UV inhibiting raise-shields radiation resistant awlgrabber methylethylbadshit from the chandlers. That's guaranteed an extra 0.00001 kts off the line and critical for OD racing.
#20 BobJ
BobJ
  • 999 posts
Posted 16 October 2013 - 01:03 AM
:lol:
#21 jerryj2me
jerryj2me
  • 1,740 posts
Posted 22 October 2013 - 11:32 PM
Nah its a 2.7 point hit on your phrf
