Painting a dry sail bottom
11 replies to this topic
#1 Flying Fish
Flying Fish
  • 106 posts
Posted 14 October 2013 - 12:46 AM
I have a B25 I plan on painting this winter.  It is dry sailed and in need of paint, top and bottom.  I intend on spraying and do not have the equipment for a two part paint so i plan on using Interlux brightsides.
What is best for speed?  should I paint and then apply McLube polish?  Should I not apply anything but wetsand with 1000?
#2 dreaded
dreaded
  • 8,960 posts
Posted 14 October 2013 - 03:58 AM
use
Interlux VC 17m Extra Antifouling Paint
#3 Pinching
Pinching
  • 515 posts
Posted 14 October 2013 - 09:15 AM
The advantage of dry sailing is less annual maintenance on the bottom and no paint buildup.
The disadvantage, other than cost, is keeping the bottom clean and fast between races.
I sail out of Naptown on a bigger boat with a Durepox bottom (zero antifouling properties).  After a 3 day summer regatta, the bottom gets a little slimy/fuzzy.
Get something you can clean.
Also, the bay will stain most light colors brownish.  The owner uses an acid solution to clean/whiten up the bottom after each race.
No free lunch, but it is less work than burnishing baltoplate every year
P
#4 thefuture
thefuture
  • 656 posts
Posted 14 October 2013 - 11:23 PM
Pettit easypoxy flows out better and lasts longer than bright side. Neither work underwater. Use Vivid below waterline. Bright colors and burnishable. Wetsands easy for slick bottom.
#5 Flying Fish
Flying Fish
  • 106 posts
Posted 16 October 2013 - 09:29 PM
Thanks all.  I only want to do this once.
None of you said to go with McLube polish over the paint.  Interesting.
#6 dinghysailor
dinghysailor
  • 119 posts
Posted 16 October 2013 - 11:52 PM
If you use brightside you will be doing this more than once. You could use performance epoxy, durepox or awl grip. Then polish with mclube or wax a few times a year if you really want to dork out.
#7 Christian
Christian
  • 9,121 posts
Posted 17 October 2013 - 12:07 AM
Then use a product that is made specifically for dry sailing and not some in-water-storage bottom paint.  Durepox or VC performance epoxy are both great for this application
#8 Pointy End
Pointy End
  • 435 posts
Posted 17 October 2013 - 01:02 PM
If you only want to do this once, I wouldn't use a 1 part enamel like Brighsides or Easypoxy......Especially if you ramp launch.
If you're going to spray, why can't you use a 2part epoxy like Awlgrip 545?
100 x harder than an enamel and is formulated to be wet sanded....unlike a 1 part topcoat.
#9 amro
amro
  • 5,105 posts
Posted 17 October 2013 - 02:04 PM
Interlux used to have a dry sail paint called vc eco. No antifoul, hard finish and was said to stand up to abrasion due to trailer/cradles. Perfect for a melges or a j/70. Not sure if it's still produced, or what's replaced it if not.
#10 Blitz
Blitz
  • 767 posts
Posted 17 October 2013 - 02:11 PM
Petit Protect 2 part epoxy
#11 Mr. Fixit's brother,, Mr. Fixit
  • 1,130 posts
Posted 17 October 2013 - 03:55 PM
What spray equipment that will shoot Brightside not shoot a two-component paint?
#12 Flying Fish
Flying Fish
  • 106 posts
Posted 20 October 2013 - 11:52 PM
Two part epoxies require a positive flow air feed as the fumes are toxic when spraying.  A one part epoxy does not or I would buy Awlgrip.  Spraying a two part epoxy with a $50 mask can kill you.
