External GPS antenna
41 replies to this topic
#1 Fleetwood
Fleetwood
  • 694 posts
Posted 25 October 2013 - 06:59 AM
I'm looking for an external, rail-mountable, active GPS antenna with a NMEA 0183 output. Don't need a display as it will interface with my PC and other displays.
Any recommendations? ( I thought this topic had been discussed a while ago but I've searched the forums without success.)
#2 X-taze
X-taze
  • 91 posts
Posted 25 October 2013 - 09:53 AM
I have a GPS 19X HVS from Garmin connected to my PC (with Adrena running as routing software) and I am very happy with it. Fast, accurate an reliable.
#3 HILLY
HILLY
  • 1,061 posts
Posted 25 October 2013 - 11:52 AM
I purchased an external g.p.s.antenna from these guys in singapore, thru ebay, delivered to my door in Lake Macquarie within 5 days.
 http://stores.ebay.c...?_fsub=19637069
#4 Fleetwood
Fleetwood
  • 694 posts
Posted 26 October 2013 - 03:25 AM
Good to hear, this is the one I have been thinking of.
What's the mount like? I guess I'll need a rail-mount.
#5 X-taze
X-taze
  • 91 posts
Posted 26 October 2013 - 02:55 PM
It comes with a deck-mount and a pole mount. The other gps on board is a raymarine deck mounted and it is loosing the signal on a too regular basis (don't know if the problem is the deck mount or the gps itself but what is sure is that if somebody is seated above the antenna, the signal is lost). My Garmin module is on a "T-Pole" fixed on the transom, that keeps the rail clean and the antenna clear, useful if you have teak seats in the back pushpits ;-)
If you have additional antennas (iridium, vhf, wifi amplifier, etc) the T-Pole is a nice solution, if not rail-mount is the way to go in my opinion. You will just need to buy something like that: http://www.scanstrut...&type=Sailboats
#6 henry the navigator
henry the navigator
  • 367 posts
Posted 26 October 2013 - 04:10 PM
Take a look at this option:
Airmar GH2183 GPS Heading Sensor 10Hz
Product ID: AM1101-000         MFG ID: GH2183-10
Airmar GH2183 10Hz combines GPS positioning and highly accurate heading information in one compact antenna. The GH2183 eliminates the need to install a GPS antenna above deck and a heading sensor below deck. Only one installation above the deck is required, saving installation time and money.
#7 Rail Meat
Rail Meat
  • 7,725 posts
Posted 26 October 2013 - 07:08 PM
I have one of these as back up to my primary antenna.  It is a great unit, I highly recommend it.
The bottom of the antenna can thread onto any 1" NPT rail mount, and then you need their cable (specify NMEA 2000 or NMEA 0183).  They come in a few different lengths, so order to fit your installation.  Then that will plug into a small converter box that takes the GPS output and pushes it out to a USB plug for your PC.  That will run you $125 for the WS-UBS.  Alternatively, you might want to push out a signal to your VHF so you can have DCS working, in which case you are going to want the WS-UBSN which has a UBS output for your PC and then separate 0183 output.  That box is more, around $380.  Both of those are in addition to the antenna.
#8 Sparrow50
Sparrow50
  • 276 posts
I can 2nd the recommendation. I have one interfaced to my VHF. Never a problem with it. Mine is mounted under the deck so it's invisible and no clutter.
#9 Fleetwood
Fleetwood
  • 694 posts
Posted 27 October 2013 - 06:52 AM
Pretty bloody expensive, >$700! Even the basic (GPS only) is >$200.
Still leaning towards the Garmin (~$150), as I've since discovered that my primary problem isn't my old steam-driven GPS, but the driver for the serial/USB interface to my PC. I just upgraded from Vista (shit) to Windows 7 (OK so far). My old serial/USB cable doesn't have a 7 driver so I had to get a new cable but its driver causes NMEA communication to slow to a crawl (apparently a common problem). There's another driver which is supposed to work OK; I'll try it out tomorrow.....
I'll use the Garmin as a primary and my old one as back-up. At least the PC doesn't think the GPS is a mouse anymore!
Ain't PC/instrument communications fun!!
#10 Wet Spreaders
Wet Spreaders
  • 1,606 posts
Posted 27 October 2013 - 02:17 PM
Add an NMEA to WLAN box and ditch the cables  - no more serial/USB issues
#11 us7070
us7070
  • 9,190 posts
Posted 27 October 2013 - 02:32 PM
what kind of serial to USB did you get?
this is one thing that it's best not to get cheap on - I typically use a Digi Edgeport 1 - generally around $70, but sometimes less on ebay.
if you want to go wireless with your old GPS, it might be better to use serial to bluetooth rather than  wifi.
#12 Fleetwood
Fleetwood
  • 694 posts
Posted 27 October 2013 - 11:20 PM
My plan is to go wifi soon, probably the Shipmodul Miniplex-2wi, but I'd like to get the current setup working in the interim.
Also don't like to admit defeat!
My serial/USB is a generic one, probably a part of the problem. I'll look at a better one.
#13 #19
#19
  • 4,810 posts
Posted 28 October 2013 - 03:36 AM
A USGlobalSat BU-353S4 GPS will work fine below decks.
#14 micha571
micha571
  • 287 posts
Posted 28 October 2013 - 07:10 AM
This sounds good, GPS and Glonass in one antenna, high baud rate, 10Hz updating, and way not as ridiculous expensive as the Airmar GH2183:
http://www.digitalya...oducts_id=11706
#15 Sailabout
Sailabout
  • 2,064 posts
Posted 01 November 2013 - 03:32 PM
10hz ( at low cost, under $200)is a big step forward for a yacht but your kit will need to process the glonass and the navstar strings to make use of them or it will just ignore them I assume?
Reading the manual it will calculate at 10hz but only output at 6hz if you use only one sat system, thats still way better then a 1 hz system
Most manufacturers never want to explain that
#16 micha571
micha571
  • 287 posts
Posted 01 November 2013 - 03:44 PM
at low cost, how much are they
Somewhere I've seen them advertised for around 190 USD.
#17 us7070
us7070
  • 9,190 posts
Posted 01 November 2013 - 04:01 PM
my garmin handheld also has a GLONAS receiver - i haven't looked at what the NMEA sentences look like, but i'll check it out.
#18 Sailabout
Sailabout
  • 2,064 posts
Posted 01 November 2013 - 07:10 PM
a navstar starts with $GP and a Glonass starts with $GL
#19 tommays
tommays
  • 1,024 posts
Posted 02 November 2013 - 12:01 AM
I question how much you even need and external unit anymore as my current Standard Horizon HX851 DSC  unit will pickup a single in the basement of my house
My oldest Magellan Pioneer GPS was always hard pressed to work in anything less than perfect a sky-view
gotta love progress :)
#20 Fleetwood
Fleetwood
  • 694 posts
Posted 03 November 2013 - 07:03 AM
Fixed the problem by downloading the latest (Vista) driver for the USB cable, works with Windows 7!
Under deck antenna sounds very interesting; the fewer thins on the rail and the fewer deck penetrations the better.
Any problems encountered with them so far?
#21 evenflow
evenflow
  • 153 posts
Posted 03 November 2013 - 01:56 PM
I second micha571, this would be my choice for what you want.... Digital Yacht GPS 150 Dualnav - http://www.digitalya...oducts_id=11706
If you don't trust either of us, here is the Panbo Review below
http://www.panbo.com..._converter.html
#22 Mr. Fixit's brother,, Mr. Fixit
  • 1,130 posts
Posted 03 November 2013 - 03:39 PM
We use this to tell our satcom where to point
http://hemispheregns...ps-compasses-57
#23 kgw
kgw
  • 539 posts
Posted 03 November 2013 - 04:41 PM
I use the Standard Horizon gps puck to send the info to the SH Matrix. I mounted mine on the cabin top, but a rail mount would not be difficult.
#24 Rail Meat
Rail Meat
  • 7,725 posts
Posted 03 November 2013 - 11:22 PM
Won't work with Carbon hulls, and won't work if there is a lot of water on deck.  But otherwise... good to go.
#25 Fleetwood
Fleetwood
  • 694 posts
Posted 04 November 2013 - 01:06 AM
Water on the deck is standard on our boat! Generally that's also when its important to know where one is....
Sounds like either the Garmin GPS 19X HVS  or the DY GPS 150 Dualnav.
#26 e63s AMG
e63s AMG
  • 1,163 posts
Posted 04 November 2013 - 04:46 PM
where did you buy it and how much does it cost?
#27 us7070
us7070
  • 9,190 posts
Posted 04 November 2013 - 05:50 PM
did you look at the dimensions?
it's pretty big...
#28 e63s AMG
e63s AMG
  • 1,163 posts
Posted 04 November 2013 - 06:02 PM
it's pretty big...
yes, but it does L1 and L2 signal processing...and I can't see if Garmin GPS 19X HVS  or the DY GPS 150 Dualnav do. I have 2 of the garmin 17 that do L1 and L2 processing at 5Hz updates but was looking into upgrading to 10Hz or even 20Hz. The DY GPS 150 Dualnav is only a 6Hz updates (if I am reading the manual correctly) so it does not buy me much
#29 Ocean View
Ocean View
  • 369 posts
Posted 05 November 2013 - 02:42 AM
Couple of options
Tacktick use these and just rebadge them  - expensive but good -  http://www.sanav.com...s_receivers.htm
OR
You could grab the GME AIS receiver unit and use the NMEA GPS data - as well as gain the AIS benefits.
and it's NMEA 0183 and 2000 data outputs will future proof your purchase.
GME AIS GPS NMEA data with AIS RECEIVE  $219
http://www.gme.net.a...stems-1/AISR120
GME AIS GPS NMEA with AIS transmit and receive $549
resellers here.
http://www.chsmith.c...ne-GPS-AIS.html
http://www.boatingce...0-ais-receiver/
#30 Sailabout
Sailabout
  • 2,064 posts
Posted 05 November 2013 - 02:45 PM
it's pretty big...
I cant see on the spec sheet where it says it can process L2 data nor any garmin equipment. That would up the accuracy a lot.
Can you point me to where it says that?
thanks
#31 Mr. Fixit's brother,, Mr. Fixit
  • 1,130 posts
Posted 05 November 2013 - 04:08 PM
it's pretty big...
thanks
Some of the other systems on the Hemisphere website offer L1/L2 capability and also 10 & 20 hz channels. We actually use a pair of Trimble SPS351's for our survey work.
#32 Sailabout
Sailabout
  • 2,064 posts
Posted 05 November 2013 - 05:13 PM
ok
I was wondering if you could get L1L2 data and not pay $3k+ for a receiver, that would be great if you could
#33 e63s AMG
e63s AMG
  • 1,163 posts
Posted 06 November 2013 - 03:58 AM
yes that is why I asked about $.
#34 Mr. Fixit's brother,, Mr. Fixit
  • 1,130 posts
Posted 06 November 2013 - 07:47 PM
I have no idea. It's all leased equipment as part of our Sat Com service.  Broadband internet, phone, fax etc.
#35 Throatwarbler-Mangrove
  • 3,328 posts
Posted 16 June 2014 - 02:38 AM
Who has one, and what has your experience with it been like.  Looks like a really nice product, but unproven manufacturer.
#36 evenflow
evenflow
  • 153 posts
Posted 16 June 2014 - 01:09 PM
I have a digital yacht AIS, works like a clock... more than I can say for the three Standard Horizon handhelds I have that seem to have some sort of failure every 2 years or a part break a day out of the box.
#37 Brightwork
Brightwork
  • 9 posts
Posted 21 June 2014 - 02:05 PM
I have a garmin 19 Hvs set to update at 10 hz and feeding into my pc running Expedition. It is mounted under deck as near to the bow as we can get it. Works well, never any problems.
Bob
#38 Fleetwood
Fleetwood
  • 694 posts
Posted 22 June 2014 - 07:52 AM
Installed the Garmin 19, works just fine so far. Had to slow it down to 1Hz for the rest of my systems, but hopefully can speed it up as I upgrade them.
Interesting about the Standard Horizons, Our GX 2100 VHF/AIS has worked great for the past couple of years, as did its predecessor for the last 15 years!
#39 willsailforfood
willsailforfood
  • 811 posts
Posted 19 July 2014 - 11:58 PM
That unit is also a VERY accurate 3-Axis Compass with 3-Axis Accelerometer & 3-Axis Rate Gyros.  That heading sensor is the same one NKE uses in their top of the line installs (although they update the firmware to better integrate with their systems).
Look at this as a top notch compass AND GPS solution.  This is our PRIMARY sensor for both GPS and heading (other than our old Ritchie globemaster).
#40 Campbell
Campbell
  • 147 posts
Posted 21 July 2014 - 05:07 PM
This is what I use with very good results so far. Especially like that it appears that there is no internal filtering trying to smooth out all the data - I suspect that Garmin uses some form of filter and DR's between 'fixes' as have had overshoot etc from their antennas. You can see the 150 bouncing around when zoomed right in - which would be expected with accuracy and resolution from non-survey grade GPS. Rather that than the boat sitting nicely in one spot - not real data.
#41 spoon
spoon
  • 11 posts
Posted 29 October 2014 - 04:24 AM
does any one have a wiring diagram to wire up the Garmin 19x hvs external antenna to a tacktick wireless interface T122
#42 Dennisail
Dennisail
  • 595 posts
Posted 29 October 2014 - 06:43 AM
I'm not sure how you can configure it for your other instruments.   But I have been using the Globalsat BU353 usb units for ages. I sailed across the pacific with one and my laptop as my primary navigation.  They work perfect with opencpn etc.   They use NMEA 0183.  Make sure to get the S4 so it works with W8.   Cost $37
http://www.ebay.com/...=item2a44383d42
There are a few versions, look on the global at site.  There should be one that is setup to output to NMEA devices.   But a good nerd may be able to get the USB version to output to standard 0183 instruments.   I gave it a go and failed, but I used a $25 garmin 16x lvs to work with my C120 rather than the $300 one raymarine tried to sell me.
The BU353 units I have used were much faster and more accurate than any marine instrument spec GPS receivers that came on any boat I or my mates have owned.   Also forget rail mounting it.   The faster speed etc is all apparent just by plugging it in anywhere inside a fiberglass boat, but they are waterproof.
