Who Makes a 3-up Mast Instrument Bracket?
14 replies to this topic
#1 MidPack
MidPack
  • 3,566 posts
Posted 19 November 2013 - 09:52 PM
I must be looking in the wrong place, and the small company I bought my last one from in 2007 has disappeared (a slick removable CF bracket for $206, that was supposedly the bracket of choice for Melges 32's back then). Searching online all I find is a Nexus/Garmin CF that's $600-700 and a Raymarine/TackTick - both sized for Maxi displays (too large). If I just want 3 MN100, i70's or Triton displays, who still makes something reasonable ($200?)? I see pics of various brackets on boats, but can't find any manufacturer/sellers online. Lots of "pods" for powerboats mostly, but I don't want pods.
#2 break my wallet
break my wallet
  • 70 posts
Posted 23 November 2013 - 02:37 PM
CF will be about $600 for a 3 up display... if you get 3 individual brackets it will still be 175 each for REAL CF..
are you in north america?? I have a source if you are.
#3 TooTall
TooTall
  • 168 posts
Posted 17 December 2013 - 03:23 PM
Break my wallet - who's the source.  I run Tacktick instruments - with three displays at the mast - I've been looking for something other than two single displays with a plastic bridge.
#4 MidPack
MidPack
  • 3,566 posts
Posted 17 December 2013 - 03:34 PM
You may have seen all these, so FWIW...
http://www.scanstrut...&type=Sailboats
http://www.mauripros.../NEX699753.html
https://www.westmari...42124&langId=-1
http://www.svendsens..._p/hot-crib.htm
#5 gjbike
gjbike
  • 273 posts
Posted 19 December 2013 - 04:21 AM
It wouldn't be hard to bolt a piece of lexan to the front of a single mount large enough to hold 3 instruments. Or you could use 2 mounts -one top, one bottom with a piece of Lexan between
#6 Mr. Squirrel
Mr. Squirrel
  • 2,247 posts
Posted 19 December 2013 - 07:14 AM
Here are a couple for $300ish.  Not sure how big you need the openings to be.
http://www.newegg.co...=0MA-0036-00026
http://www.imarineus...CFcJ0QgodPysASw
MS
#7 break my wallet
break my wallet
  • 70 posts
Posted 19 December 2013 - 02:27 PM
sent you a PM  with contact details
#8 MidPack
MidPack
  • 3,566 posts
Posted 19 December 2013 - 04:59 PM
Interesting idea. I have thought about cutting out of piece of Lexan or wood the same size as the bottom 4" or so using the companionway hatch board as a template to mount the (TackTick) instruments on. It would just sit in the companionway slots, and be removed when not in use, easy-peasy. Of course it wouldn't be ideal for line of sight (a little low), and crew might kick it and damage instruments inadvertently...
#9 ross22
ross22
  • 2 posts
Posted 19 December 2013 - 10:11 PM
I made a carbon fiber one for triple faces wireless tack tick for a big boat this summer for a client
Extra long so the out haul and reef lines can run behind it
If you want contact me and I will make you some
For the small tactics
#10 JACO
JACO
  • 209 posts
Posted 19 December 2013 - 10:38 PM
How about this............(hopefully it's attached.)
#11 break my wallet
break my wallet
  • 70 posts
Posted 19 December 2013 - 10:50 PM
Attached File  Attachment-1.jpg   228.55KB   29 downloadshow does this look?
#12 JACO
JACO
  • 209 posts
Posted 19 December 2013 - 11:15 PM
Looks quite nice, but I think the original poster was looking for something for a small format display.
And Tacktick has a decent looking black alloy 3 position for the large formats that's sorta reasonable at under $350.  Carbon looks Gucci though.
#13 gjbike
gjbike
  • 273 posts
Posted 20 December 2013 - 03:31 AM
Here is something I made easily . I no longer have that boat but I spent all of $25 in supplies from Lowe's. Aluminum is easy to bend and Lowe's will cut the Lexan to size. I put some leftover handlebar foam wrap on the part against the mast to prevent scratches. The mounts are held on with 3M heavy duty outdoor foam tape. Need to be sure they are not in the way of flying sheets and halyards.
[/URL]">http://<a href='http...llow external'>0977168b-a27b-4f18-baeb-d916cefaab98.jpg
#14 MidPack
MidPack
  • 3,566 posts
Posted 20 December 2013 - 06:23 PM
I was hoping for something like this...
Attached File  CF Bracket.JPG   313.42KB   56 downloads
#15 Graciousj100
Graciousj100
  • 142 posts
Posted 25 December 2013 - 12:57 AM
Hey I have that exact setup. Works great thanks Midpack
