trickle down
428 replies to this topic
#401 nav
nav
  • 7,357 posts
Posted 22 July 2014 - 11:16 AM
^ remember it's not an all or nothing situation, 3 some of the time & 4 some of the time is ok too AFAIK
Although I guess you then run into problems with asymmetric boards etc as the rule only allows cant and rake - so perhaps in the end you are stuck with one design philosophy or the other.
#402 floater
floater
  • 1,333 posts
Posted 22 July 2014 - 03:42 PM
I guess it's not certain that four is draggier than three. It's worth keeping in mind that the kink in the dihedral is likely draggier than the straighter anhedral foil.
But what is more interesting - perhaps the ultimate speed of the anhedral is higher?
My WAG is that cavitation may hit the dihedral on the inside of the radius. And because the anhedral has a larger radius - perhaps a greater ultimate speed?
#403 McGyver
McGyver
  • 487 posts
Posted 22 July 2014 - 06:16 PM
One good question is why it took so long for foils to show up on sailboats.  This ferry was in use off Buenos Aires over 40 years ago.
#404 Doug Lord
Doug Lord
  • 8,069 posts
  • Interests:Foiler design and development,.........sailing fast,
    movable ballast systems and..... justice.
Posted 22 July 2014 - 08:13 PM
Monitor was designed and built in the USA in the early 50's-about 60 years ago. At the time it was the most successful sailing hydrofoil ever. It was capable of foiling tacks and gybes and had a unique foil control system using shroud tension among other things. This is the first video I've ever seen of the boat:
More info from foils.org:
11 Jan 98] The following is an extract from a book that I wrote some years ago about hydrofoils. From "Ships That Fly" : MONITOR -- All of Gordon Baker's mechanical genius was not expended on military hydrofoil applications. About 1950 he was interested in using hydrofoils for sailing purposes, having built a three V-foil cat boat with an airplane foil configuration (two foils forward and one aft). This craft attained remarkable speeds while beating into the wind reaching 20 knots. Speed ratios of over 1.5 times the real wind velocity were recorded. However, it had a tendency to "pitch pole" when running before the wind and would go into "irons" when coming about. These undesirable characteristics led Baker, with US Navy backing, to develop the MONITOR, a sloop with two ladder foils forward and a submerged foil aft. The forces of all the stays were fed into a mechanical computer. Based on these inputs, the computer determined and then set, through a linkage system, the appropriate angle of attack on the aft foil for the wind in which the boat was sailing. This solved the problem of pitch-polling and made it possible to come about and stay on the foils. MONITOR first flew in 1955 and a pace boat clocked her at 25 knots. In October of the following year she was paced at 30.4 knots. It was reported that MONITOR attained speed to true wind speed ratios of just over 2.0, and at times unofficial boat speed measurements close to 40 knots were observed. It is interesting to note that the U.S. Navy backing of MONITOR was motivated by its objective to learn more about the foil structural characteristics and construction methods used by Baker. Recommended references: Baker, G.G., "Design of Hydrofoil Boats with Particular Reference to Optimum Conditions for Operating in Waves", Baker Manufacturing Co., Engineering Report No. 248, July 29, 1960. Also, Alexander, Alan F., et al, "Hydrofoil Sailing", Juanita Kalerghi, 51 Welbeck Street, London, 1972. -- John Meyer (jmeyer@erols.com)
#405 Tornado-Cat
Tornado-Cat
  • 10,148 posts
Posted 22 July 2014 - 08:27 PM
Yes, with 4 foils we may see different setting depending on the conditions.
I guess the foil will have 3 positions : full lift, small lift when ww, neutral.
#406 floater
floater
  • 1,333 posts
Posted 23 July 2014 - 04:09 AM
...But physics suggests that the TNZ solution should be faster - because, if you've got a lifting foil beneath your feet - it's got to reduce your righting moment.
All else being equal - bear with me here - having half a TNZ foil in the water beneath two hulls means you are lifting the boat from the centerline....
You're partly correct.  I've been looking into what happens with two boards in the water.  Vertical lift on the windward board does reduce the righting moment.  However, the effect of leeway tends to shift the vertical load more to the leeward foil.  This is more pronounced as the boat flies higher.  Heeling to leeward also shifts load to the leeward foil, but tends to make the boat less stable in heave.
When flying at a medium height (say, 300 - 500 mm) the righting moment isn't altogether different from a hull with straight boards, since the straight boards also reduce righting moment.
 The details change with the foil configuration, but the trends seem to be similar over a wide range of foil configurations (C, J, L).
One interesting thing with two boards is anhedral is stabilizing - at least within the restrictions of the A Class rule.
The righting moment picture could be changed drastically with some simple board controls.  Port tack, neutral, starboard tack, switched as the crew moves across.
Why do straight boards also reduce righting moment?
#407 Doug Lord
Doug Lord
  • 8,069 posts
Posted 23 July 2014 - 12:25 PM
Check this sketch out: with four boards down, and flying the windward hull, the windward foil has a small component of force acting to reduce righting moment:
#408 floater
floater
  • 1,333 posts
Posted 23 July 2014 - 02:04 PM
Thank you. Good. For some reason I failed to put the heel back on for conventional sailing mode.
One thing about the foilers - none of them like to heel to leeward.
#409 Doug Lord
Doug Lord
  • 8,069 posts
Posted 23 July 2014 - 02:45 PM
I don't know about that-the Flying Phantom and GC32 are frequently photographed with a small "normal" angle of heel. With Veal Heal the Moth unloads the dgrbd and gains up to around 40% more RM-but it doesn't work so well on multies.
Phantom pix Phantom International, GC 32 pix macca:
#410 macca
macca
  • 720 posts
Posted 24 July 2014 - 07:02 AM
We can sail with leeward heel. But for sure it's faster with windward heel... A lot faster.
#411 darth reapius
darth reapius
  • 49 posts
  • Interests:Chicks, Girls and Babes
Posted 24 July 2014 - 08:36 AM
Does that change upwind and downwind at all Macca? And would it be to do with having less windward rudder in the water... Just less wetted surface area...
#412 edouard
edouard
  • 451 posts
  • Interests:Leisure sailing for 35 years with anything windpowered from Hobies to Classic Keelboats
Posted 24 July 2014 - 08:57 AM
Because controlling the speed is much easier with an engine than with sails. Since sails (or a wing) can't provide power on demand, the control of the foils to provide a given lift at all time is much more complex than on a power boat. There is also the problem of lateral stability with sail powered craft, something you don't have to deal with (or hardly) on a power boat.
#413 Chris 249
Chris 249
  • 5,423 posts
Posted 24 July 2014 - 09:48 AM
It didn't take so long.
Dave Keiper's cruising tri Williwaw was fully flying in the ocean in the late '60s. The video of the boat in action are shocking - the hull and rig looks extremely crude, about as efficient as an early Piver, but the boat smoked when foiling fast.
Small cats like Icarus and Mayfly were foiling at Weymouth Speed Week in the '70s, and there were many other foilers at such events.
Tabarly's tri Paul Ricard was using foils, adjusted by a pivoting main beam, when it was launched in '79 and other tris such as VSD were fitted with them for some time. The 26m (85' IIRC) tri Charles Heidsick was designed to semi-fly using foils and the ground effect of the beam.
Moths were, IIRC, foiling in the '60s in trials; there's blurry pics on Moth sites of a scow foiling on (IIRC) Port Philip Bay in Australia in that era, with further details about the experiment. Windsurfers were photographed foiling about '77, for example in the Churchulla (sp) Bros book. There was also foiling Mistral M1 at my local beach around '83 and there are pics of Harken stock foils being used and advertised for sale on the original Windsurfer around the same time. And as Doug has pointed out, Monitor was there in the '50s.
With the technology of the day, though, boats were normally too heavy to make foiling effective around a course. Creating sails that were powerful enough to lift a boat onto foils but could then stay flat enough when the apparent wind increased would have been impossible, too.
You can add in the fact that popular craft tend to be simple, tough, cheap and perform well in light winds, which are not easy things to achieve on a foiler.
The fact that offshore boats were foiling decades ago proves that foiling trickled UP to the America's Cup, like most technologies did.
#414 edouard
edouard
  • 451 posts
Posted 24 July 2014 - 10:07 AM
Actually the first foiling power boats such as the HD-4 (http://en.wikipedia.org/wiki/HD-4) date back to the 1910s. So it did take a while to move to sail boats, and a while longer again for commercial implementation such as the foiling fairies McGyver was referring to.
#415 nav
nav
  • 7,357 posts
Posted 24 July 2014 - 10:44 AM
Stolen from the FP
This has been threatened for some time - glad to see someone made it a reality.
Now wait for the video...
More here... http://www.google.de...ved=0CHYQrQMwGg
Same idea from last year - Swiss?
#416 macca
macca
  • 720 posts
Posted 24 July 2014 - 11:04 AM
It's more of an advantage when sailing upwind, we have pretty long foils so we can achieve a fair bit of heel. Our draft is 2.3m and the new AC62 is 2.7m IIRC. So for us to have useful windward heel is easier to achieve then it will be on the new AC boats.
It works in the same way as the moth, rig over the top gives lift, RM increases as well. Plus the foil geometry in the water changes so that the main shaft is entering the water at a more vertical angle and the tip is immersed deeper and at a more horizontal angle. This reduces leeway, increases efficiency (less of a surface piercing lifting effect from the main shaft and the tip is in cleaner water) and there is surprisingly no loss of heave stability. So it's all wins when you get the mode rolling.
#417 edouard
edouard
  • 451 posts
Posted 24 July 2014 - 12:07 PM
SoftWing is indeed a Swiss company (http://soft-wing.ch/) but the original designer is Hugues de Turckheim.
#418 Chris 249
Chris 249
  • 5,423 posts
Posted 24 July 2014 - 12:31 PM
Hughes from Tiga? Wow... he was a fun and innovative guy in windsurfing.
#419 edouard
edouard
  • 451 posts
Posted 24 July 2014 - 12:33 PM
Yup.
#420 floater
floater
  • 1,333 posts
Posted 24 July 2014 - 06:03 PM
given no loss in heave control with a windward heel - one might imagine taking a bit of the kink out of the vertical.
The GC foil might be okay with a bit more L, and a little less V. And become a little bit quicker.
#421 nav
nav
  • 7,357 posts
Posted 24 July 2014 - 07:15 PM
...taken from this?
11.4 The maximum dimension of any daggerboard shall be 5.000 m in any direction, measured
    along a straight line.
That's the only relevant* dimension I see ATM - or is it hidden elsewhere?
Wouldn't it be nice if they got away from the mono nomenclature finally , 'daggerboard'! Pfft...
* draught and board length obviously not the same thing, but related
#422 Catatonic
Catatonic
  • 168 posts
  • Interests:Hobie cats, Sailing in general, Ice boats, tits.
Posted 24 July 2014 - 07:48 PM
Yeah it should be daggerboards...
#423 floater
floater
  • 1,333 posts
Posted 25 July 2014 - 01:14 AM
A Class with TNZ foils:
Attached File  image.jpg   186.88K   7 downloads
http://www.carbonicb...ng-way.html?m=1
#424 Doug Lord
Doug Lord
  • 8,069 posts
Posted 25 July 2014 - 02:23 AM
The only trimaran of any size currently sailing(as far as I know) with a version of TNZ's UptiP foils on the amas-my scale test model 5.5'LOA,6.7' Beam, lots of sail:
More here http://www.boatdesig...-36058-107.html and in the Radio Control Multihulls thread in the Multihulls forum
click for a spectacular view--
#425 floater
floater
  • 1,333 posts
Posted 25 July 2014 - 02:34 AM
Sorry - should have said TNZ'ish foils. The straight dagger gives them a decidedly non-TNZ'ish look.
Cool stuff Doug - but is that a wand dangling off the main hull?
#426 Doug Lord
Doug Lord
  • 8,069 posts
Posted 25 July 2014 - 01:03 PM
Thanks-the main foil is wand controlled with dual wands so one is always in the water when she's heeled. The idea is that the foils allow the boat to fly the main hull/whole boat in light air when it wouldn't fly due to wind pressure alone.The breeze in this pictures was measured with a Davis Wind Meter at 5mph(not knots!). That allows the boat to be very wide which gives tremendous RM as the wind picks up. The ama foils worked extraordinarily well validating the whole i-flap concept. They were inspired by TNZ,designed by me, with the major difference of the "i-flap":
#427 ~Stingray~
~Stingray~
  • 15,804 posts
Posted Yesterday, 01:39 PM
fun piece, at http://www.sail-worl...-the-Cup/124989
On the final day of the Moth Worlds, Beau Outteridge caught up with two America's Cup helmsmen: Chris Draper (Luna Rossa Challenge) and Nathan Outteridge (Artemis Racing).
Check out this video where they discuss the relevance of the Moth Class to the America's Cup.
#428 Sailbydate
Sailbydate
  • 2,571 posts
  • Interests:Sailing. Classic Yachts. Following what's happening in development classes.
Posted Yesterday, 08:22 PM
Interesting. Noted NO's comment about staying abreast of any new foiling techniques in the moth.
#429 nav
nav
  • 7,357 posts
Posted Yesterday, 09:48 PM
^ Nicely done.
Still on message; "We love the AC, don't care where"
An incestuous world though, Larry's son, Nathan's brother.....
