Overhauling the rigging on a Searunner 40
14 replies to this topic
#1 Roy M
Roy M
  • 12 posts
Posted 03 June 2014 - 11:43 PM
Hi.  I am in the process of completely overhauling my rig and deck gear on my Searunner 40, which I built and launched in 1978 (sail number 68).  As a 35+ year-old boat, a lot of stuff has already been replaced with more modern gear and materials, but I did start out being one of the first West System boats in L.A.
I won't get into the non-rig related stuff I've done (unless anyone actually wants to know), but I'd appreciate hearing some comments and suggestions regarding this phase of my project.  I recently retired as a shipwright in San Diego and am preparing to cruise full time one year from now.  Hence the rig overhaul.
I am going to be changing out the mast (or heavily modifying the existing one) to actually be a cutter rig, with internal halyards, full-batten main, and roller furlers on the jib and staysail.  I am replacing all of my old winches and replacing with new Harkens:  The halyard winches (using banks of clutches) will both be 35.2 STA units, the genoa sheet winches will be 50.2 STAs as I am older than I was when I built this craft.  The main sheet is going to be a 40.2 STA, and the two staysail sheet winches will be an older set of 22s, also STAs.
My traveller, about 10 feet long, spans the cabintop and connects with the boom about  3/4 of the way out.  The gooseneck will be fixed at about 8 feet above the cockpit (currently it's a slider, about 7 feet up), since I'm adding a Bimini, to accompany the new hard dodger in the works.
All sails will be new, with the exception of the existing assymetric.  I may, or may not, consider a code 0.
Any observations or comments?
#2 Zonker
Zonker
  • 1,401 posts
Posted 04 June 2014 - 01:49 AM
All sounds like good ideas so far.
What sort of track system iff any will you use with a full batten main?  With a fixed backstay do you really need full battens to support the roach? We have a roughly similar mainsail on our 40' cat and went with 2 top battens full and lower ones overlength.  Still harder to get the sail down to reef when sailing downwind than our old mainsail with short battens.
Considering using dyneema standing rigging like the fellow with the Searunner 34?
Sails - make sure your sailmaker understands multis and the higher loads they put on sails.  No heeling and higher apparent wind = more stress
Are you going to sail her a true cutter (yankee + staysail) or genoa mostly and then staysail when it blows hard?
#3 Roy M
Roy M
  • 12 posts
Posted 06 June 2014 - 04:01 AM
You picked the right questions.  I haven't made the plunge, but am about to, in the next couple weeks.  I have four basic options:  recycle the existing mast section, which involves replacing the mast head assembly to achieve the internal halyards, as well a other major surgeries; go whole hog with a new Selden with all bells and whistles, or an intermediate choice of a local mast builder, using Harken t-track and splitter, with my own work; or, fourth, using the Tides Marine system.  Decisions, decisions.  Probably will use the Dyneema for the running backs, but not the shrouds or stays, too chicken.  I am using Amsteel for my existing Edson steering cable system.
yes, my local sailmaker, Chuck of Ullman in San Diego, knows multihulls, as well as my rigging advisor, Fritz Richardson of Pacific Offshore Rigging, who owned a sister ship several years ago and has had considerable multihull sailing experience (CRUSADER around Cape Horn).  I am going to have both the yankee and the genoa and figure out which is best under what conditions.  I'd like to be able to remove the staysail when I'm under genoa alone to ease the tacking issues.
#4 Raz'r
Raz'r
  • 31,617 posts
Posted 06 June 2014 - 04:29 AM
just an FYI - on my Contour 34 I had synthetic water stays, runners and main shrouds, but wire diamonds.    Worked really well.
#5 THOR
THOR
  • 1,449 posts
Posted 10 June 2014 - 04:26 AM
except of diamonds all ColligoMarine stuff on the boat ( F 33) works nicely
give John a shout he will be able to help
good guy
thot
#6 pelorus32
pelorus32
  • 68 posts
Posted 10 June 2014 - 08:15 AM
I've just re-rigged completely in over braided heat set Dyneema terminated in turnbuckles. The weight saving was enormous - 73% decrease and the new rig is much stronger than the old. The only place I'd be concerned is with roller furling headsails.
Best decision I ever made...and to quote another person I spoke to during the process of deciding: The question is not "should you do it?" the right question is "why would you ever use anything else?"
Only caveat is where are a heavy displacement monohull.
#7 Future MOB
Future MOB
  • 137 posts
Posted 10 June 2014 - 06:40 PM
How did you terminate? Any photos? Did you pre-load after splicing to take out construction stretch (not sure if that's the rights term)? I agree that this is the way to go, but a boat I recently sailed on was still having trouble getting the right tension using lashing (they have Dux on lowers only), and thought that turnbuckles were the way to go.
#8 Training Wheels
Training Wheels
  • 614 posts
Posted 10 June 2014 - 06:41 PM
Any specific concerns with rigging the diamonds with dux?.
#9 Raz'r
Raz'r
  • 31,617 posts
Posted 10 June 2014 - 06:52 PM
only concern I had was with the point load at the spreader and the construction stretch. I believe both could be managed.
#10 Training Wheels
Training Wheels
  • 614 posts
Posted 10 June 2014 - 07:32 PM
Thanks. Did you have good luck using lashings?
#11 Raz'r
Raz'r
  • 31,617 posts
Posted 10 June 2014 - 07:37 PM
it was a bit of a pain for the water stays, especially when new, but do-able over time.  Much easier on the running backs as there was a block/tackles. Main shrouds also had adjusters as it's a folder.  For a fixed rig, I'd think about turnbuckles on the main shrouds.
#12 rustylaru
rustylaru
  • 113 posts
Posted 11 June 2014 - 05:49 PM
Roy.
I have a cutter rig that we be available in the fall from a searunner. PM for photo's and details. Parts of it may be of use to you.
#13 Roy M
Roy M
  • 12 posts
Posted 22 June 2014 - 03:22 PM
Okay, so I've listed the mast, boom, all sails and Navtec turnbuckles on Craigslist San Diego, and have had two hits already.  It's a package deal for $2500.  This may be your last chance to get this killer deal.  The first cash deposit of $500 seals the deal.  I won't need to pull the rig until August, so you have time to get stuff together.
#14 Roy M
Roy M
  • 12 posts
Posted 04 July 2014 - 02:15 PM
Okay.  I've got a local guy who is definitely interested in this deal, so if anyone else is considering it, don't let the grass grow under your feet.  Also, I've got two Barient 26 2-speeds and a Barient 16 2-speed as a package for $500.
#15 Speng
Speng
  • 4,987 posts
Posted 12 July 2014 - 04:26 AM
IIRC a Searunner or similar was a test boat for Colligo rigging and they sailed it down in Mexico with all the UV etc. I think most people are ditching the lashings on bits with a lot of steady rig tension and using turnbuckles or similar. Other than that it's the way to go. Cost effective and easy to DIY.
