Seeking Stanchion Base Source for Tanzer 25
Stanchion Base Tanzer 25
9 replies to this topic
#1 Kaptainkriz
Kaptainkriz
  • 2,018 posts
Posted 04 July 2014 - 06:44 PM
Tried reviving an old thread but could not find it....  The bases on my Tanzer 25 have some cracks and need to be replaced.  They are aluminum and mount over the toe rail.  Google search of a zillion images have revealed nothing similar.  Really, almost any would do, but I would like to stick with two screw holes and rail slot to avoid holes in the deck core (it is solid at the edge). I've attached a photo of one that would work along with the original, but cant find a source for these or similar.  Any help would be appreciated.  :)
Attached File  Base 2.jpg   64.12KB   6 downloadsAttached File  Base 1.jpg   54.23KB   9 downloadsAttached File  Base Original.JPG   26.82KB   8 downloads
#2 Schnick
Schnick
  • 2,511 posts
Posted 04 July 2014 - 07:34 PM
I'd send those pictures to someone at Garhauer.  I bet they could make them.
#3 Gypsyclubjuggler
Gypsyclubjuggler
  • 151 posts
Posted 04 July 2014 - 08:53 PM
Any metal shop can fabricate you stanchion bases, just give them the old ones to work dimensions off.  Usually easier than finding OEM or specialist ones.
#4 GMiller
GMiller
  • 457 posts
Posted 05 July 2014 - 06:57 PM
If your boat has a metal toerail integral to the base, I know of a couple of C&C's that have gone with these.
http://www.rigrite.c...es_Alu.html#C Stanchion Bases
#5 Ishmael
  • 16,188 posts
Posted 05 July 2014 - 08:32 PM
Holland Marine also has the C&C bases, along with Grampian and CS parts. It might be worthwhile calling them to see if they have any Tanzer parts, I know (think) they used to.
http://hollandmarine...lder/CC001.html
#6 Kaptainkriz
Kaptainkriz
  • 2,018 posts
Posted 05 July 2014 - 08:57 PM
Thanks for the inputs so far...looks like there are a few interesting possibilities. Keep em coming. :)
#7 Py26129
Py26129
  • 2,101 posts
Posted 06 July 2014 - 02:55 AM
You might give these guys a call if you have not already done so. http://www.tanzerboatparts.com
If they can't help you then I'd go to a local machine shop
#8 Kaptainkriz
Kaptainkriz
  • 2,018 posts
Posted 06 July 2014 - 09:56 PM
Thanks, I'm in communication with them. Unobtanium part....so will need to fabricate or find an alternate.
#9 jacrider
jacrider
  • 182 posts
Posted 08 July 2014 - 12:30 AM
Try Holland Marine in Mississauga.  He has lots of OEM parts that he has accumulated over the years.
#10 SpongeDeckSquareFoil
  • 522 posts
Posted 08 July 2014 - 02:44 AM
I've had good results with Whitewater Marine as far as making one-off parts to print. Might be worth a shot.
http://www.whitewate....com/index.html
