Solar light for Windex?
Solar light windex
6 replies to this topic
#1 TheOffice
TheOffice
  • 175 posts
Posted 16 August 2014 - 05:58 PM
Has anyone found a solar light to light the reflective part of the windex? I can't see running a wire in the mast.
#2 Presuming Ed
Presuming Ed
  • 10,361 posts
Posted 16 August 2014 - 06:32 PM
Don't you have wire going up there anyway for the tricolour?
#3 Training Wheels
Training Wheels
  • 606 posts
Posted 16 August 2014 - 10:26 PM
My tricolor lights up my windex just fine.
#4 TheOffice
TheOffice
  • 175 posts
Posted 17 August 2014 - 12:01 AM
No tricolor on The Office! Lights are bow and stern. Thus, no wire and no illumination. Won't use the anchor light when I'm underway.
#5 allen
allen
  • 3,122 posts
Posted 17 August 2014 - 12:07 AM
Use diodes and you can wire it to light either the anchor light or a light for the windex. Just reverse the polarity to select which one lights up.
#6 P_Wop
P_Wop
  • 2,812 posts
Posted 18 August 2014 - 05:51 AM
I went to the local hardware store (OSH) and bought a cheap ($2.99) Chinese solar-powered garden LED light - the one on a sort of tubular stalk.
http://www.osh.com/O...Light/p/7006455
Pulled it all apart, and rebuilt the bits I needed into a small plastic box.  The LED is mounted in the box top and shines up at the Windex, and the tiny (~4 in²) solar panel charges a pair of Nicad AAs.  There's a light sensor which just turns off the LED in daylight.
Simple, cheap, and takes about an hour to do it.
EDIT:  Oh, and apart from gooping the whole thing with silicone, put a small waterproof toggle switch in the side of the box to turn off the LED manually when you're not sailing - quick trip up the rig. But if you're on a mooring or anchored, it makes a great anchor light.  You'll need the switch for the winter when the mast's out.
And if you want to be really fancy, put in a wireless remote switch salvaged from a garage door opener.
#7 White Wing
White Wing
  • 815 posts
Posted 18 August 2014 - 06:35 AM
Maybe put bits of GloFast tape to your liking on the Windex and skip wiriing, solar stuff, etc. - I have their clutch labels on our boat and the glow is impressive.
WWing
