Glowfast Draft Stripes from front page
#1
Posted 23 April 2009 - 02:54 PM
Anyone know of a source in the US?
#3
Posted 23 April 2009 - 07:06 PM
#5
Posted 23 April 2009 - 09:04 PM
Anyone here actually used them to see if the glow will last through the night?
Also, it looks like its only available in 25m rolls, or am I reading the page wrong.
I wouldn't mind just a few feet to put on the chute...
#6
Posted 23 April 2009 - 09:34 PM
using
http://www.identi-ta...om/phosphor.htm
or
http://www.chemglow.com/#
I dont sail that much at night, though. Need a new clutch first.
Not trying to take business away from these guys, but..........
glowingly
ed
#7
Posted 23 April 2009 - 09:50 PM
#8
Posted 23 April 2009 - 09:54 PM
I have never seen their stuff but we manufacture photo luminescent safety products. The glow products of today will last in excess of 24 hours, however there is a disclaimer.......the surrounding area must be completely dark. The glow starts off quite bright then diminishes in a logarithmic fashion quickly at first. It will level off after an hour or 2 (depending on the pigments they are using) and then stay at that level for many hours.
So on a moonless cloudy night they will perform as illustrated, if the stars and moon are out they will likely become difficult to see after a few hours. (they will still be glowing at the same level, but your eyes will adjust to the ambient light level making it hard to see.)
As they have worked out a glow patch under the tell tales would work best. Putting the pigments in or on telltales would weigh them down. They pigments typically have a sg > 3.5 so to get them string to glow it would become fairly heavy.
One suggestion I have for them would be to make the labels with the glow as the back ground and the text dark. We have tested both configurations and the glowing letters become difficult to read much sooner than the dark letters on glow background.
Their stuff does look (very) pricey but to meet their claims it should be much brighter than the identi-tape material Glowmaster listed. (ie ASTM 2072 materials are not very bright)
#9
Posted 23 April 2009 - 10:57 PM
#10
Posted 24 April 2009 - 12:40 AM
pjrs, on Apr 23 2009, 06:57 PM, said:
If you mean for tell tales on the leech of the main then my opinion would be no. While a film could be made light enough to work as tell tales they would not glow very bright for very long. Maybe if one used a UV LED (like a black light) shining on the tell tale with either photo luminescent or fluorescent pigment in it, it would glow quite bright.
#11
Posted 24 April 2009 - 04:08 PM
Slap Shot, on Apr 23 2009, 08:40 PM, said:
I've thought about the UV LEDs, they're cheap and not so hard to find now.
What worries me is that UV light is bad for your eyes, and at night you're eyes would adjust to take in as much light as possible, and would then get a lot of the UV...
I don't necessarily want to trade a few nights of racing for loss of eyesight later on.
But I'm no eye doctor, anyone know if the light put out by the UV LEDs is bad for you?
UV LED data sheet
#12
Posted 24 April 2009 - 05:35 PM
UV LED data sheet
I can't imagine that there would be enough UV emitted by the LED in this role where it would damage your eyes. Remember that LEDs emit light in a narrow beam. That said I am neither an eye doctor nor looking to develop this product.
#13
Posted 24 April 2009 - 05:40 PM
why wouldn't a some sort of a black light setup work for night time telltail reading?
#14
Posted 24 April 2009 - 05:50 PM
mike at layline dot com
#15
Posted 24 April 2009 - 06:52 PM
#16
Posted 24 April 2009 - 07:36 PM
Think you'll be able to sell it by the foot?
the 25m roll is a little big for a few uses on a 27' boat...
#17
Posted 24 April 2009 - 09:38 PM
#18
Posted 24 April 2009 - 11:30 PM
Thanks for your interest in Glowfast Marine products.
Thought I would jump on and answer a few of your questions.
A little more about our tapes
They are specifically designed for use on sails and are made of a cloth similar to current sail repair tapes. This makes them light weight, 200 grams per square metre. They also have the same adhesive on them which makes them stick well to sails.
I also thought I would mention a few issues with using vinyl tapes
(These results are from our testing and consulting with sailmakers. I urge you not just to take our word on this and consult you local sailmaker as most of them will have some experience with using glow and reflective tapes)
Vinyl tapes don't stick well to the sail. This is because they stretch at a different rate to sail material and have a tendancy to lift off. The solution is to add a mylar film over the top which will reduce their glow affect.
We have also been informed by a leading sailmaker that they can create a week point in the sail (I want to clarify that i cannot confirm this as during our testing of using vinyl we had problems with adhesion, however we never had a problem with any ripping of sails).
Vinyl tapes also tend to be a bit weighty
In regards to the Slap Shots post below. He is 100 percent correct with the darker the night the easier it is to see our stripes. What we have found though is if it is bright enough that you can't see our tapes glowing it is generally bright enough to see you entire sail anyway.
I would also like to stress the inportance of getting the correct size sail tape for your individual application. We are very keen to make sure that people get the best experience using our products and are always available to help you get the right products for your requirements. You can contact us through our website www.glowfast.com.
We will also be working with our distributors to make sure they have good knowledge of our products and can help you select the right product for your individual needs.
Some things to consider when selecting tape sizes.
How far the product is going to be away (the further up the rig they are the thicker the tapes need to be).
What you are going to use them for i.e if you are only going to be out for a few hours at night you can put smaller draft stipes on but if you want to view them all night then you need a thicker tape.
Hope this has been of help. If you have any further questions please don't hesitate to get in touch.
Jason
#19
Posted 08 October 2009 - 12:16 AM
Somebody on Lake Erie gave Burnsy a couple rolls of the glow sail draft tape. We put it on before the Mac races this year. That shit is the bomb. Not sure if these glowfast guys are selling the same stuff, but if they are, it is awesome. Lasts all damn night. Very cool.
Note, if you are applying the tape to taffeta or dacron, stitch it on. It sticks like mad to mylar, but we had issues with our taffeta coated mylar genoa. We would definitely purchase this product in the future.
#20
Posted 11 October 2009 - 09:44 AM
Copied from another thread:
Hmmm, can't say for sure if that was our stuff - It's been going all over the world.
Glad you liked it though! :)
Our Luminous Sail Tapes have the same properties as insignia so it should stick to everything that insignia does as long as the surface is clean and dry.
We've also tested ours on spinnakers. It sticks, and it's light enough that it doesn't make an impct on the way they fly. It also makes for amazing glowing chevrons at night.
#21
Posted 07 March 2010 - 10:29 PM
I know we're not advertising at the moment, but I thought I'd still mention that we've got a new Cruising Series Sail Tape out. This product is just as bright and half the price because we use a different process to make it. It is a little heavier than the original product (which is still on the market) so we don't recommend that you stick this one on spinnakers.
US customers can buy through our stockists or through the website at http://www.glowfast....sail-tape.html.
I just though that this would be helpful for those who found the Racing Series Luminous Sail Tape a little pricey.
Brita
Sign In »
Register Now!
Help
