What do you think?
zeyang
Posted 17 June 2009 - 06:53 AM
Posted 17 June 2009 - 07:04 AM
Posted 17 June 2009 - 10:24 AM
Posted 17 June 2009 - 10:25 AM
Why on earth would anyone build a lapstrake-looking boat out of alloy? It's going to take 100 times longer than to build a non-lapstrake boat, weigh a ton (conservatively) more, be a bear to maintain, almost impossible to make fair - I just don't get it at all!
But have fun!
Posted 17 June 2009 - 10:29 AM
Im with M, curious way to build.
Couple of questions
1. How are you gong to weld it without burning the wood? or is this a rivit and sealant job.
Will weld. First tackweld with tig (in a safe distance from wood), then cut out the wood and start MIGweld all together.
2. 8mm over those frames!! why so thick?!?!.
due to ice in antarctica...!!!
3. How many are on the build to get it done in 12 months?
around 5000 hours totally, divided by 1 or 2 person.
ok, so that was three questions, bite me.
BTW - what will it rate?
approx 20 tonn.
Posted 17 June 2009 - 11:42 AM
Posted 17 June 2009 - 12:09 PM
Surely you are not worried about weight saving. So why did you prefer aluminum over steel. Working a thinner steel sheet would be easier than an 8mm thick alloy. Welding,Repairing in remote places, and looking after aluminum is much more problematic, especially over time. Electrolysis will be a constant threat. Anyhow, good luck. If the end result is satisfying, its all that matters.
Posted 17 June 2009 - 01:26 PM
Posted 17 June 2009 - 01:37 PM
Posted 17 June 2009 - 01:42 PM
agree, 8mm is not special thick. I was thinking about 10 mm but price pr kg raises dramatically due to marked demand, so I opted for 8mm. with 2 cm overlap i actually got 1.6 cm there. Im thinking about frames every 60 cm as in original drawing. with laps you can avoid quite a few frames and still get it fairly strong hull, but ofcourse not like finnish nuclear icebreakers.8mm plating is not outragious. It's tough, the frames can be smalled and fewer the durability is increased and it's far easier to fair. Lots of PNW fish boats in that size range use .25" plating.
I'm not sure about the "lapstrake" thing but I imagine it could look very good if done carefully.
Who designed this "Colin Archer"?
Where are you building it?
Best of luck with the project.
Posted 17 June 2009 - 01:50 PM
correct. he designed some very few in the beginning but switched to carvel before 1900. In some original papers he stated that he could build if customer asked for it, but will cost more. i dont know the reason why its more costly. More wood maybe? in my opinion, carvel is more difficult and demand more from a boatbuilder in competence.I've never seen a "Colin Archer" type in lapstrake. Correct me if I'm wrong, but they were generally carvel planked correct?
Good luck!
Posted 17 June 2009 - 01:55 PM
I think the world will come to an end, so its good to have an ultimate escape machine.. just kidding :-)I think this sounds great. Especially since I'm not the one building it.
Zeyang, you have very good reasons for what you are doing. It will be very interesting to see the end result.
I too would be interested in knowing what plans you are following.
Posted 17 June 2009 - 02:47 PM
Good luck!
Posted 17 June 2009 - 03:27 PM
design is original colin archer (by himself) from 1905. you can get all his drawings at norwegian seafarers museum. im building behind a barn far away from sea! Only cows around here!
zeyang.
Posted 17 June 2009 - 03:28 PM
Posted 17 June 2009 - 05:49 PM
I think we're all wondering about YOU Zeyang.
Tell us more about yourself and why you came up with this insanely mad idea.
Posted 17 June 2009 - 06:21 PM
Posted 17 June 2009 - 06:38 PM
Heck, you must be on the few illiterate around here, I know at least 1.3 billion just in the neighbourhood who can read fluently.Well, I can't read a word of your website, but the pictures sure are great! One of the more interesting projects to come along in a long time.
Good luck to you!
Posted 17 June 2009 - 06:52 PM
Good luck to you!just kidding.
Mandarin is an insane crazy language. The guy who invented it, must have been out of his mind.
But the girls are really pretty though!
Anyway, thanks for comments.
Zeyang.
Posted 22 June 2009 - 04:59 PM
Posted 22 June 2009 - 07:50 PM
Tom Colvin, who designed and built many a steel boat, once wrote that if all the material were free, he would build in aluminum for the pleasure of working with the material. From what I've read, welding in AL takes a lot of skill, but everything else is easier and more pleasurable than steel.
Posted 22 June 2009 - 07:55 PM
its true. Ive had the pleasue of discussing with Mr. Colvin about boats in general, he is very into cost consideration. (as a professional builder). With todays prices of aluminum, its really a good option. Im not a professional welder but i find alloy welding quite easy with todays equipment. Not harder than steel in any way. Prices is down by 20-30% which could beat steel when you take painting and sandblasting into the picture. And besides material is only a fraction of the cost. Manhour is the biggest cost. (which is basically free when you are homebuilder.
If you look at books from other famous builders, among them maybe Mr. Farmer, there is much positive feedback about using alloy.
zeyang.
Posted 22 June 2009 - 09:51 PM
zeyang.
that's all really nice and everything, but you're not allowed to post here any more unless it includes pictures.
Posted 22 June 2009 - 09:55 PM
zeyang.
Posted 22 June 2009 - 10:40 PM
zeyang.
Ok. Here is one reason why alloy is easy to work with. You can use ordinary wood working tools. (it seems i got alloy disease, even my car is fully alloyed these days) The saw cut 8mm just like butter. But please wear mask! The small alloy bits are hot and stick easily to your skin.
Posted 22 June 2009 - 11:34 PM
Posted 23 June 2009 - 03:54 AM
cool pics.
Is that a beer with a screw cap?
and wth...an aluminum (or is that 'aluminium') Land Rover???
Posted 23 June 2009 - 08:31 AM
Ofcourse.Wow. After all those threads about cruising boats designed on this site but not built, cruising anarchy has a unique build to follow. On a side note, when Sons said he needed pics, he meant the pretty girls.
Posted 23 June 2009 - 04:35 PM
Posted 24 June 2009 - 12:57 PM
Posted 24 June 2009 - 11:13 PM
Posted 25 June 2009 - 05:58 AM
Not too much, just tool boxes etc, ahh yes, i build two panniers for my bike. :-) Extremely solid boxes, much better than the stuff you buy at high prices in plastic.This is great! Love what you are doing.
What else have you built in aluminium?
Posted 25 June 2009 - 09:43 PM
Posted 25 June 2009 - 09:56 PM
Posted 25 June 2009 - 10:08 PM
Posted 25 June 2009 - 10:12 PM
Posted 25 June 2009 - 10:48 PM
Posted 25 June 2009 - 11:38 PM
Posted 25 June 2009 - 11:49 PM
Posted 26 June 2009 - 12:05 AM
This thread has the potential to be the best one on the whole website.
Well done.
Posted 26 June 2009 - 12:16 AM
hi list, im building me a colin archer in lapstrake. hopefully finish next year. size is 40 feet. aluminium in hull is 8 mm. Shape and look will be in just like a wooden boat.
What do you think?
zeyang
Posted 26 June 2009 - 07:12 AM
Great project! Thank you for sharing it with us. What made you choose this design? Do you have any experience with this type of boat?
Posted 26 June 2009 - 08:11 AM
Posted 26 June 2009 - 08:21 AM
Posted 26 June 2009 - 01:38 PM
On the boat the battens look like it has a lot of curvature but in reality is pretty straight.
Posted 26 June 2009 - 02:03 PM
Posted 26 June 2009 - 03:39 PM
Posted 26 June 2009 - 04:56 PM
Posted 26 June 2009 - 05:51 PM
One life, live it! (stolen motto from Land Rover Corp)
The crazy boatbuilding monkey is jumping up and down in front of camera.
Doing lofting, its good to have kneepads. Kneeling for 200 hours on the floor do makes the knees painful.
Posted 26 June 2009 - 06:49 PM
correct. he designed some very few in the beginning but switched to carvel before 1900.I've never seen a "Colin Archer" type in lapstrake. Correct me if I'm wrong, but they were generally carvel planked correct?
since im building one of his last design
Posted 26 June 2009 - 07:11 PM
Posted 26 June 2009 - 08:25 PM
I'm confused. Are you building an early or late Colin Archer design?
Posted 26 June 2009 - 08:34 PM
this boatbuilding monkey does not look like Chinese. Are you Chinese?
This project is going to make you a star. Whether you want to be or not.
Posted 26 June 2009 - 08:59 PM
Your project is quite nice Zeyang.
Lofting on the floor is a good way to learn and makes you smarter when you transition to CAD.
One thing I would comment on is the propeller aperture. It may be too late in your construction process but you may want to provide more tip clearance between the prop and the hull and rudder. If you don't you may get some nasty vibrations as the tip of the prop passses the structure. A good rule of thumb is to provide clearance equal to 15-20% of the diameter of the propeller, 10% minimum. Also, can you remove the prop for maintenance without removing the rudder?
Keep posting!
Posted 26 June 2009 - 09:14 PM
The stern needs extensive redesign to successfully fit propeller and to retain the good manoeuvrability of the original design.
Be also aware that many of CA's designs have too little displacement for todays fitting out with engine and tanks and of shore cruising.
Originally they did not have detailed construction plans. The boats were designed by the yard and details did not have to put down on paper.
Posted 26 June 2009 - 09:16 PM
There is a cool story behind this, my plan was to cross russia from china to europe so i need to have lots of storages for campinggear and gasoline" so basically this boxes are custommade for storing gasoline. :-)
But hey, this is not sailing-porn pics
Posted 26 June 2009 - 09:33 PM
Good question. I was thinking about 老外 (laowai) , but my friends think its rather stupid name of a boat. Im open for suggestion here.Absolutely fascinating. Please keep us updated.
Quick question...
Not sure if this is breaking some protocol or not but what are you thinking about naming her?
Posted 26 June 2009 - 09:40 PM
I have no idea. Its definetly not Hilton. This picture was taken in northern Italy if i remember correctly (Lido Garda)Not too much, just tool boxes etc, ahh yes, i build two panniers for my bike. :-) Extremely solid boxes, much better than the stuff you buy at high prices in plastic.
I can't quite make out the name of that hotel in the upper left of your picture of the motocycle. What hotel is that? Or does it say, "Motel?"
Posted 26 June 2009 - 09:54 PM
Posted 26 June 2009 - 10:20 PM
Just do what American tattoo artists do. You're sailing *away* from china, so as long as you use pictograph letters, you can put anything you want and then just tell people whatever you feel like calling the boat that day. Who's going to know?Good question. I was thinking about 老外 (laowai) , but my friends think its rather stupid name of a boat. Im open for suggestion here.Absolutely fascinating. Please keep us updated.
Quick question...
It should reflects china in one way or another way. I really like the chinese naming habits of sons and daughters. Really cool.
zeyang
Posted 26 June 2009 - 10:44 PM
Well, all I can say is that you keep some pretty crazy hours if you are in China.
All of China is GMT + 8.
http://wwp.greenwich...sia/china/time/
I believe all of our posts are GMT noted.
You must not like sleep too much.
http://forums.sailin...p...mp;hl=&st=0
And how can you build a boat spending so much time here?
Posted 01 July 2009 - 08:06 PM
Posted 01 July 2009 - 08:16 PM
Not TOO much less talk though! It hasn't quite been a week, so there's probably not alot to update, but I think I can speak for at lease several of us that we're on the edge of our seat awaiting updates on your astounding project.
Posted 27 July 2009 - 01:59 PM
When your boat is finished, if you sail to Los Angeles, the 1st round is on me [if I am still here]!
Posted 31 August 2009 - 04:09 PM
finished plank 8. sofar spent 1200 hours totally and rising :-)Not TOO much less talk though! It hasn't quite been a week, so there's probably not alot to update, but I think I can speak for at lease several of us that we're on the edge of our seat awaiting updates on your astounding project.
Thanks, Not sure about route yet. But LA is not a bad idea!
will keep you update, when i have something to update. now work is just repetition (plankbuilding) for next 2-3 months.
Posted 02 September 2009 - 12:53 AM
Posted 02 September 2009 - 11:12 AM
Posted 02 September 2009 - 01:55 PM
This must be the most inneficient way to build a Metal boat I have ever heard of! Even if a Colin-Archer.
You have to love it.
Posted 02 September 2009 - 04:04 PM
Posted 27 September 2009 - 05:01 AM
BRILLIANT WORKfinished plank 8. sofar spent 1200 hours totally and rising :-)Not TOO much less talk though! It hasn't quite been a week, so there's probably not alot to update, but I think I can speak for at lease several of us that we're on the edge of our seat awaiting updates on your astounding project.
:-) This is the old way of building a lapstrake boat just that i swapped oak-planks with Al. I dont think there is many other ways of building a lapstrake boat. (except maybe rightside up)
zeyang
Posted 27 September 2009 - 08:28 PM
Posted 27 September 2009 - 09:22 PM
Posted 28 September 2009 - 06:36 AM
This is like that guy who spent 12 years building a 1/12 scale Ferrari.
Only this is 1:1 scale and it's not a Ferrari.
Posted 28 September 2009 - 08:56 AM
Posted 28 September 2009 - 09:09 AM
Posted 15 October 2009 - 01:25 PM
It will be in alloy. Wood frame is only template to bend the planks into boat-shape. after boat is turned rightside up, i will replace the wood with alloy-frames.Oh and one more question which I think a few others might have been dying to ask.
Why not build the original frames in Alloy instead of timber so they are there to stay???
Posted 15 October 2009 - 01:26 PM
Posted 15 October 2009 - 02:22 PM
Posted 15 October 2009 - 02:47 PM
Good progress Zeyang. Will you replace the wooden frames one at a time with the aluminum ones to avoid losing the hull shape?
Posted 15 October 2009 - 02:54 PM
What a wonderful thread, why wasnt I told!!
Zeyang, you are a man after my own heart, strong work. For a first time builder you are doing an amazing job.
One thing if I may. I think the engine position you have will give you no end of grief my friend. If its at all humanly possible please get part of the engine itself above the waterline!!!! You can leave the prop where it is and angle the shaft but you must lift the engine. Otherwise you will have no end of flooding problems due to siphoning. Unless your exhaust outlet is above deck this arrangement will be trouble.
Also having the engine so low it will be the first thing to be disabled should the boat take on water. In any knock down situation or similar disaster where you take on a reasonable amount of water aboard first thing to go is your starter motor.
On a more pleasant note, how the hell did you end up in China, gwylo ?? (cantonese version)
Posted 15 October 2009 - 06:53 PM
Posted 15 October 2009 - 07:06 PM
Wooden Boat Magazine this month has an article on one of the most original Colin Archer rescue boats - you should check it out.
Posted 15 October 2009 - 09:21 PM
Posted 15 October 2009 - 11:06 PM
xiexie. will find. Is it RS1 colin archer or RS10 Stavanger?
RS10 stavanger is now bought by a museum. I had a chance to see it some time ago. my interest was in the windlass :-)
Posted 21 October 2009 - 10:52 AM
It is Stavanger.
Posted 21 October 2009 - 04:52 PM
Posted 21 October 2009 - 06:30 PM
Posted 21 October 2009 - 06:55 PM
No diesel. Pure wood stove :-)What a great pic of that Colin Archer crashing through the waves with everything set. Makes me want to be there.
I can almost smell the diesel fired stove below.
Posted 22 October 2009 - 06:45 AM
Posted 26 October 2009 - 02:09 AM
Actually i was thinking about just skipping the engine in first place. Originally this design was without engine. (before the oilage) Plan is to have the exaustoutlet above deck. (gooseneck system) Inlet will be closed circuit (in bilge) Reason for having it as low as possible is to use the engine as ballast also.
will also try to avoid all those seacocks or at least minimize them as much as possible. I hate flooding the boat :-)
This gweilo used to work in china, but now i work fulltime with this boatproject instead.
Posted 26 October 2009 - 10:54 AM
When Moitessier lost Joshua in Mexico he went to Hawaii (I think) & had a new steel boat built.
The engine he installed was an air cooled diesel.
He mainly wanted simplicity of maintenance for the engine & no through hulls.
He planned to sail not motor & wanted to run the engine for short periods to get in & out of anchorages & to charge batteries.
I have no idea how it worked out for him.
But, if you use modern sound proofing & flexible engine mounts & you have a well vented engine space with good short exit for the exhaust it may be a good alternative for you.
Another big + is the price, air cooled is way cheaper than water cooled.
In India you can even get an air cooled diesel Enfleld motor bike.
So India & China ought to be good places to source one.
Posted 26 October 2009 - 01:32 PM
Posted 29 October 2009 - 12:45 AM
thanks, i found even a cheaper solution. old fishermens choice - sabb 32 hp engine with pitch prop, cooling runs closed circuit in the keel. exhaust could be like the fishingboat have it.
weight 1000 pound so its indeed a heavy beast.
zeyang.
Posted 29 October 2009 - 07:57 AM
Posted 30 October 2009 - 10:54 AM
:-) some of these old engines have a very cool sound. especially the one cylinder ones...Just dont run it at night in quiet anchorages to charge the batteries!!!
Posted 31 October 2009 - 12:15 AM
Posted 02 November 2009 - 09:14 AM
Posted 02 November 2009 - 12:36 PM
Posted 02 November 2009 - 01:40 PM
