20+ Footer - Building in Hawaii
#201
Posted 04 February 2010 - 04:55 PM
I was wondering how you are going to attach the sprit? I tried looking, but maybe missed that.
#202
Posted 04 February 2010 - 05:12 PM
i race on a 1720, a 27 foot sports boat. it has one winch for halyards back from the mast. It is ideal for putting the asy sheets round in a blow as it takes all the pressure off the sheets allowing you to relax a little. Other 1720s dont do this tho and apparantly we are a bit nesh for using the winch. but hey if it means my 50 year old mum can tame a mast head kite in 20+kts then i think its a good idea as ratchet blocks can only do so much.
It's not just your 50 year old Mum who will like the winch.
I've sailed with plenty of 20 to 30 year old guys and just when you need that 2 feet of sheet to come in to accelerate, they let out that pathetic whimper "I can't pull it - my hands hurt
We sail 3 races in a day in winds often over 25 knots, by the 3rd race the sheet kills your hands - we often switch trimmers, which only works if you have two competent trimmers aboard.
A good friend who switched down from a M24 to a Melges 20 admitted to me that his 20 still has this problem.
I've experenced the pain and don't want a boat with this limitation.
Are winches required on a D6? Only if you want them.
If you decide you want them later, there's a lot of room in the cockpit to screw them down (photo shows straboard winch mounted)
Go Mom!
Posted 04 February 2010 - 06:36 PM
There is a reason I'm asking (hint, hint, of course)....
#204
Posted 04 February 2010 - 07:46 PM
I think JD was talking about a de-mountable prod of so fashion.
Jim - have you gone so far as to figure out how much sail you'll carry uphill ? - Curiously comparing the numbers on the newly-announce LS20 which see turbo'd beyond reason - eight-hundred-something lbs, and 360 sq ft - I was wondering how they'll do that.
#205
Posted 05 February 2010 - 11:20 AM
And would it be:
Foam >> thickened epoxy >> lay on glass immediately >> pour laminating resin on top of glass and roller it in >> peel ply
or
Foam >> thickened epoxy >> allow to cure >> roller laminating resin on >> lay glass >> roller resin up through glass>> peel ply
#206
Posted 05 February 2010 - 04:53 PM
Jim, a quick technical question: During the construction, after laying the foam where you want it, what is the very next thing to go on? I've read people mentioning about skimming a layer of thickened epoxy over the bare foam surface and then applying the glass? If so, what's in the epoxy? Would it be say west with a bit of silica or microballoons or what?
And would it be:
or
I've done a layup like this for a 505 and we used option 1, laying on the kevlar/glass as the bond coat was still wet. We used Divilette (spelling?) which was a very light material, the five gallon pail weighed nothing at all. If you were to let the bond coat dry you'd want to give it a light sanding before laying in the inner skin.
#207
Posted 05 February 2010 - 05:06 PM
And would it be:
or
Use your first method - I let it set up a little before applying the glass.
This can be tricky because of it sets up too long, it'll get sticky and that makes getting the material on much more difficult.
There are lot of different concepts on the perfect core bonding paste - industry standard is to mix a bit of silica (or equiv.) in the resin to a mayonaise consistency.
The Divinycell core I used is very thirsty, so if you don't do this step, you will use almost twice as much resin laminating the material directly to the core - it just keeps soaking into the core.
Corecell is a bit better, and isn't as "spong-like".
#208
Posted 05 February 2010 - 05:11 PM
Duct Tape. Lots of it.
Hi Dan and Herb,
The bowpsrit attachment is a project in process - I suspect the final solution will be reached as it is being built.
Depending on how this comes out, this may or may not be the solution for the production version.
That sail area number for the LS20 seems a bit high (is it a typo?)
#209
Posted 05 February 2010 - 06:47 PM
Eager to see how that works out with the bowsprit attachment.
On another subject, how are you designing/building the foils? It sounds like the keel will be a modified M24 keel and bulb, is that true?
#210
Posted 05 February 2010 - 08:59 PM
Thanks Jim,
The fin is a special design, not a Melges fin.
I have my eyes on a Melges 24 bulb that is sitting in Hawaii - I would ideally reshape this - depends on the deal I can work to purchase/borrow it.
#211
Posted 06 February 2010 - 01:03 AM
#212
Posted 06 February 2010 - 02:40 PM
Turning out to be a nice boat, Jim. Can't wait to see the finished product on the water. Any ETA to when she'll be sailing?
Been a hellish week of long-boarding (not the fun kind in the surf), and ready to put the first coat of primer on the hull bottom today.
Then I'll have few more days to fill/fair the small areas that always appear after the thing is one color.
It’s really difficult to spot imperfections when it's got a microballoon camouflage finish.
Who bought your Melges?
Posted 06 February 2010 - 03:27 PM
Hi Dan and Herb,
There's another thread going for the LS20 - guess they put the sail area for the 30 footer on their sailplan; upwind SA is actually 17.6 m^@ (189 ft^2)
My boat's rig is about a meter taller, and has 40% more upwind sail area (approx 266 ft^2)
I'm being careful not to overdo the rig size on my boat, but we'll need to see how it goes in light air before we finalize the prouction version sail plan.
Not every place on the planet is as windy as Hawaii.
#214
Posted 07 February 2010 - 01:43 AM
It's really difficult to spot imperfections when it's got a microballoon camouflage finish.
No one actually. I have a nice job lined up (better than the one I have now) that will bring my income to what it used to be, so I am holding on to the Melges. If all goes well and I land the job we'll be back on the water by April.
#215
Posted 07 February 2010 - 04:51 AM
The D6 design is aimed to balance high performance with ease of sailing.
The size, construction, layout, rig and keel are all sized to give exciting sportboat performance in a package that doesn't require the entire crew to have a lot of experience sailing high performance yachts. I want to be able to take my friends out yacht racing.
The base design will carry a reasonably heavy keel bulb that will provide stability exactly when needed; when it's windy and things are starting to get a little bit out-of-control.
This keel configuration will also work well for anyone who sails solo or double-handed.
That said, the D6 design has been designed to accommodate higher performance, and can be easily "turboed" with a few modifications:
Lighter weight bulb
Longer sprit
Large spinnaker
My boat will have the long sprit and big spinnaker, and retain the heavier bulb for Hawaii's strong breezes.
The winches are the smallest available and are there primarily to hold the spinnaker sheet in big breeze so the trimmer gets some relief.
They will also serve to adjust the forestay and halyards, and just about any other line on the boat.
[/quote]
You don't have to have a bigger spinnaker with a longer sprit, you can have the same size spinnaker and make jibing easier and gain speed with the same size spinnaker.
I guess we have the benefit of sportboat evolution in NZ, every boats different in search of speed, and get modified on a yearly basis which the performance based handicaps here promote. The disadvantage is no one design racing.
#216
Posted 07 February 2010 - 06:20 PM
I agree completely (that's why I'm fitting the long sprit on my boat)
But the long sprits may take some people a little time getting used to.
I want people to have the ability to optimize their D6 to their abilities and for the areas they sail, so there will be some options in keels, rig and sails available.
We intend to offer the D6 in a "base" configuration that is slightly detuned from maximum potential.
This will allow a greater number of sailors to jump into the boat and develop the skills that are required to sail a fully powered up sport boat.
Some simple adjustments to the keel, rig and sails will "turbo" the boat, but you won't have to start out that way.
I'm a strong believer that the owners should run the class, so the OD configuration will end up as the majority of the owner's prefer.
The goal is to keep modifications simple and cost effective, so you can switch between your home town and the class OD configuration easily.
#217
Posted 08 February 2010 - 06:39 PM
Ok, so I followed your build pretty much since the beginning, and I know orginally you were talking about a detachable prod instead of a pull out sprit. Is that still the case?
BTW, I am really digging the look of the stern with the whole rudder gudgeons a part of the hull and the big sugar scoop. I'm diggin this boat Jim.
#218
Posted 09 February 2010 - 04:05 AM
Sunday we watched the game and then stayed up till 3AM watching the non-race in Valencia.
Getting the hull all white better shows the imperfections in the fairing, so today I built a new sanding long board, and marked areas that need filling/reducing.
Back half of the boat is in really good shape, except I need to tweak the chines.
There's a little work in the fwd 1/3 of the hull bottom - I knew I had some areas to deal with but needed to get the paint on to really see what's going on.
So I know what I'm doing this week - more sanding!
Just need to keep remembering it'll be well worth it.
Jesse: Thanks for the compliments on the boat - yes, the sprit will not be retractable, but I have a scheme developed to make it easily removable.
Posted 10 February 2010 - 03:55 PM
#220
Posted 11 February 2010 - 03:43 PM
Found a few of these near the centerline where the laminate laps were recessed, mainly because it was the most difficult part of the hull to reach with the long-board.
Here's a pic showing a "fix" to the fairing; two very slight lumps fore and aft of a slight hollow.
The bumps were very small - just had to sand through the primer to get rid of them.
Filled the hollow with resin rich mixture of ultra-light filler. I try to avoid using much thickness of the ultra-light filler - it's not as tough as micro-balloons. This patch is about 1/2mm thick max.
Not in the shop today, but back at it Friday.
Last bit of fairing in the bow needs a final sanding, and then I'll apply the second pass of primer - the first pass is 50% gone after long-boarding.
Posted 11 February 2010 - 05:15 PM
So you think you've got it fair, and then you start pulling a string along the hull bottom - that's when you pick up the 1/2mm bumps and hollows.
Jim,
First of all, great work! I love watching your build.
Question though, why wouldn't you have just sprayed on 545 High Build Primer if you knew there would be fairing of highs and lows?
#222
Posted 11 February 2010 - 06:31 PM
#223
Posted 13 February 2010 - 05:00 PM
Jim,
Not spraying because I’m not a painter and I don’t have a spray gun.
I am looking for someone to spray the topsides and deck.
Awlgrip high build primers are not recommended for below waterline applications, but more importantly, are really hard and difficult to sand after cure.
I’ve tried them on a powerboat deck once – that was enough.
545 is quite thin, but an excellent paint that sands beautifully.
I just put a thin coat on the other day to get the hull a uniform color – makes it much easier to pick up the surface imperfections.
Rolling it on with enough reducer that it flattens out nicely.
#224
Posted 13 February 2010 - 06:55 PM
Jim:Jim,
Are the base, the catalyst and the reducer the only components used when rolling on the 545? What percentage of reducer do you use to let it lay down?
#225
Posted 14 February 2010 - 02:15 PM
Jim:
Yep - just use the recommended amount of reducer - I think it's about 10%
Foam rollers give the smoothest finish, but the only ones I can find here fall apart after about 15 mins.
I'd like to find out if anyone has found a foam roller than 545 won't eat up.
#226
Posted 15 February 2010 - 05:25 AM
Robert slept through the AC races, but we were up all night watching - Hawaii is 11 hours earlier than Valencia
Posted 15 February 2010 - 02:09 PM
Wings Rule!
Ha ha! But Robert has an advantage, he can fold his away!
#228
Posted 15 February 2010 - 11:29 PM
Jim:
High build usually=talc, ng.
Avoid foam with 545 and use pink fabric fine nap. will get more stipple but roll an extra coat to sand through, 545 solvents too gnarly for foam. tip'n'roll freeboard or call Kimo and shoot at KYC like every one else there. can tip n roll or just roll Awlkwik.
#229
Posted 17 February 2010 - 05:32 AM
Jim
#230
Posted 20 February 2010 - 03:56 AM
#231
Posted 20 February 2010 - 05:47 PM
2 coats of 545 primer on the hull bottom/topsides past couple days - I'll try and get a photo or two this weekend, but the weather hasn't been very nice.
Realize this topic has been a bit lacking the past week - kind of like watching paint dry, which is basically been the task at hand.
Now that I have a good solid coat of primer on the hull, I have few minor areas to chase w/some fairing - this seems to be a never ending task.
My companionway hatch arrived - it's perfect!
Posted 23 February 2010 - 06:44 PM
Jim;Half the hull bottom core on the plug.
What is the foam used for the hull? Does it haveto be heatedto get he shape shown?
#233
Posted 23 February 2010 - 07:20 PM
I've had good luck using the west systems brand foam epoxy rollers for 545 primer and when rolling and tipping topcoat. Every other foam roller I've ever used has started unraveling within minutes.
#234
Posted 23 February 2010 - 10:42 PM
Surely you not going to roll and tip this boat - say it isn't so
#235
Posted 26 February 2010 - 05:05 PM
No!
Looking for someone to spray the hull and deck.
Hope to be back in the shop next week - I have only a few minor hollows to deal with near the bow.
My wife is a sculptor, and she can see the areas that need filling (I need a string line to find them!)
So she's signed up to help me locate the last few imperfections before I flip the hull right-side up and start dry-fitting the hardware.
Been hauled off MY boat project to deal with a 56 ft catamaran that 1/2 sunk 3 months ago.
I've been called in by the owner to get some real numbers attached to the composite repairs.
The insurance company has been extremely difficult through the claim process, and the delays in getting the situation resolved have become absurd.
They insurance company wasted 2 months trying to organize relocating the boat to be repaired in a grassy lot right next door to a restaurant in a tourist area, ignoring all local zoning ordinances and the fact the lot was in a flood zone that actually floods when it rains. Their plan was to throw plastic tarps on the ground. I guess working with power tools while standing ankle deep in water was okay in their book.
Whatever . . .
#236
Posted 27 February 2010 - 12:31 AM
I hear everybody's favorite boat-killer is working on big Mo down at Marisco's.
#237
Posted 27 February 2010 - 05:24 PM
Maybe I should get over there now and get it ready?
#238
Posted 05 March 2010 - 08:58 PM
Are you OK?
It's been a wild week of moving water for you.
#239
Posted 05 March 2010 - 10:26 PM
Jim,
Are you OK?
We saw the water level in the little harbor 100 feet away from home rise and drop 8” in about 15 minutes, but that was all.
Footage from Hilo was more dramatic, but no reports of damage.
It was fortunate that the wave decided to come at midday - eveyone had hours to prepare - we all watched it come to the Big Island first.
Hilo had an 11 meter wave hit in 1960 killing many people, so everyone was very relieved that it was only 60cm in Hilo
The alarms went off at 6AM - but there were already crowds in the grocery stores at 4AM becasue we heard about the quake in Chile the night before.
One of the store reportedly limited two cases of Spam per customer.
#240
Posted 06 March 2010 - 02:39 AM
We are all waiting to see you finish this project.
#241
Posted 09 March 2010 - 04:56 AM
Ok since you didn't get your toes wet....GET BACK TO WORK!
Okay, okay!
Back at it today (finally!)
Sanded the port side down to 220 and then washed it down with a hose.
The film of water over the hull surface is a real cheap "clear-coat" that let's you see all the problem areas.
I have some work to do on the chines and a few other small spots to deal with.
Good news is that 99% of the surface is done (at least on the port side)
Sanding the starboard side tomorrow and hopefully I'll get some more photos.
I think this boat just wants to get out of the shop and go sailing
So do I!
Posted 09 March 2010 - 02:36 PM
So do I!
That's a -really- pretty shape.
You already knew this, but you done good.
Posted 09 March 2010 - 04:19 PM
#244
Posted 09 March 2010 - 05:43 PM
lookin good... plans for the rig?
For my boat, see 3rd post on the first page of this topic.
For production versions, we're examining several options including aluminum to get a base boat at a reduced price.
Still waiting to see if the aluminum option is enough cost savings to warrant the extra weight aloft.
#245
Posted 09 March 2010 - 11:38 PM
#246
Posted 10 March 2010 - 01:58 PM
This boat is WAY too pretty for an aluminum rig!!!
The aluminum rig option is only to get you out on the water for less $$$ - nothing wrong with that.
There's very likely some cases where the aluminum rig makes sense, such as a YC considering the boats as a club racer.
The goal would be to match an aluminum tube close enough to the carbon upgrade that most of the fittings could be swapped out from the aluminum tube to the carbon tube.
#247
Posted 10 March 2010 - 03:00 PM
Posted 10 March 2010 - 03:04 PM
You should consider a non tapered aluminum section (F18 style). This is what we have on the 5.70. the rotating mast works great. the rig is light and very simple to set. Spin halyards is run externally which is not a big deal. Main halyard is a 2:1 purchase and ran into the groove of the mast. We have adjustable spreaders on the section of course and the shrouds are set really back from the mast for better support. The non tapered section makes the mast strong, even if you go with mast head kite, no backstay...
that's my 2 cents.
js
#249
Posted 10 March 2010 - 04:19 PM
that's my 2 cents.
js
You can definitely get away with a non-tapered topmast in a rotating rig - the section above the hounds aligns with the airflow. But for this fixed rig it's way too "agro" for a nice race boat - that big topmast section will wash out a large portion of the upper (important) part of the mainsail.
#250
Posted 10 March 2010 - 04:32 PM
Hey Jim how tall will your rig be? I'm wondering if the U20 mast would be a possible match? We have a nice C-tech rig the class has spent two years basically designing with C-tech its a freaking work of art. My carbon stick sans gear was almost $1000 bucks cheaper than the class tin rig regarding replacement costs. As for rig to rig the carbon stick is light years better regarding side to side strength compared to the tin rig.
I and a few other U20 guys have extra tin rigs though I doubt anyone is selling them just yet. You could easily get a rig from the West coast shipped over on a PAC CUP boat trailer for probably a case of beer for shipping and of course the rig price etc.
As for weight differences for the average tin rig vs carbon weight in the U20 group we've come to about 12lbs difference.
Regarding strapping a rig to a PAC Cup boat trailer there are plenty of SA guys here that could probably get that sorted out and the rig packed up on a trailer headed your way. The PAC CUP is this July and every two years so if you hustle on the rig plan you can take advantage of the whole trailer shipping idea.
#251
Posted 10 March 2010 - 06:36 PM
nice! sounds like you can now afford a 12 pack of beers aboard (I read that the average 12 pack of beer weighs 18-21 pounds)!
#252
Posted 21 March 2010 - 04:06 PM
Although most of my day was devoted to cleaning the shop and taking a truckload of trash to the dump.
I'm finishing up the hull cradles in preparation to flip the hull right-side up - hopefully this week.
Still need to sand the port side of the hull and chase some minor fairing touch-ups - started that process last evening.
Snapped a couple photos before leaving the shop last evening.
Posted 24 March 2010 - 08:31 AM
The starboard side has some areas of microlight filler that need to be sanded and primed - hope to get these finished and primed along with the port side work this week.
Not too much longer before I can flip it right side up and forget sanding and faring the bottom forever!
Posted 24 March 2010 - 11:59 PM
I'll have to remember that when we talk to the rating committee about my Ross780. We only drink from bottles (use winch handle holders for the beers, ever seen a 25 foote with 7 winch handle holders?). We also take at least a case, sometimes 1.5 = 50 to 60#! We should get a credit for that!
#255
Posted 25 March 2010 - 12:01 AM
Typical Guy, leaves the seat up!
#256
Posted 30 March 2010 - 05:15 PM
Posted 30 March 2010 - 05:17 PM
Posted 30 March 2010 - 05:18 PM
Posted 30 March 2010 - 05:20 PM
I took the photos after I hosed it down to check for fairness.
It’s wet sanded to 220 - still need to touch-up chines and add a little primer on some thin spots.
It'll look this good as soon as it gets a topcoat
#260
Posted 30 March 2010 - 08:33 PM
Do you have any more photos and pictures of your cradles? I am looking to build some for my boat. No idea how to go about.
You have a paint scheme in mind or what ever you happen to have lying around?
Thanks
Matt
#261
Posted 31 March 2010 - 12:25 AM
#262
Posted 31 March 2010 - 05:06 AM
Is the plan to pull a female mould off this beauty for the D6 production?
Plan is to build a plug for the production mold - it'll be even better.
#263
Posted 31 March 2010 - 05:08 AM
Cut cockpit ports and hatch opening and dry-fit deck hardware
Posted 31 March 2010 - 05:13 AM
The Lewmar hatch will be mounted to this panel which will slide into the opening.
I'll use this for locking up the boat, and windy days when I want to keep water out of the boat.
Posted 31 March 2010 - 05:16 AM
Posted 31 March 2010 - 05:17 AM
#267
Posted 31 March 2010 - 11:16 AM
#268
Posted 01 April 2010 - 05:57 AM
Go the freaking D6!!!!!!!!!!!!!!!!!!!!!!
I admit I was a little wobbly about that hatch, but it really does look like a good touch. Still not clear, will that be a permanent mount, or is that a removable assembly?
#269
Posted 01 April 2010 - 02:42 PM
Couple of bow-on shots (remind me to finish the upper part of the stem)
That is a truly sweet looking hull.
Best looking treatment of chine & sheer I've seen yet... or at least, the most photogenic.
Posted 01 April 2010 - 02:55 PM
How freaking awesome that is Jim!
The brown panel in this photo is a Masonite template for the hatch panel.
The finished panel will be a glass cored panel with the Lewmar hatch mounted to it.
The panel fits into the larger opening much like a companionway slider, with a gasket to seal around the edge.
Last night I removed the core around the large opening and filled with high density filler. Today I'll run the router around the edge to give a smooth opening.
The large opening will be fantastic for day racing - you can easily reach the mast from the cockpit to get at the main halyard which cleats below.
It's really easy to get in and out of the boat from this large opening, although I'll probably want a sailcloth flap to help shed water on the windier days.
Posted 01 April 2010 - 04:32 PM
#272
Posted 01 April 2010 - 04:52 PM
It has been a pleasure seeing the build through the whole process.
How have the price point comparisons between the carbon and aluminum sticks coming along?
#273
Posted 03 April 2010 - 03:58 PM
After this step, I'll remove all the hardware and record the number and sizes of heli-coils needed, and then ream-out the fastener holes and inject with high-density filler (404).
Here's the jib and main traveler set-up.
Jib traveler is 1:1 but can easily be increased to 2 or 3:1 if needed.n
Control lines dives under-deck at the traveler end and comes out just fwd of the main traveler cleat - right by the driver.
There's a few little water-proofing boxes to make to seal the thru-deck bullet blocks under the cam cleat.
Posted 03 April 2010 - 04:04 PM
The nasty bolt is a temp pin for now
Posted 03 April 2010 - 04:23 PM
For the forestay adjuster a clutch is the most secure means of parking the line. I never wanted that line kicked out of a cam cleat by accident.
For the spin halyard 2 things: The Melges 24 has that cam cleat at the mast for the spin halyard; in 25 knots it is a pain to release, and it's next to impossible to re-cleat the halyard if the kite starts going in the water. The clutch gives you painless release and stopping power.
I wish Spinlock made a smaller clutch - these look a bit over-kill on this little boat, but they're the smallest version made.
Not a lot left to install:
I have to build the foot-braces and lead-box for the jib sheets and vang control (also my compass mount and drink holder)
Mount the tack line cleat just aft of the spin halyard clutch
Install Roberts perch socket at the hatch
Install the access plate to get to the shower foot-pump
Install the handrails for the crew
Build the mast collar (cut the hole the other day)
Posted 04 April 2010 - 04:31 PM
The boat is looking great.
What does the Robert perch socket do?
How do you handle water intrusion from say the front of the jib traveler, where the control line goes under the deck, which looks like a blast zone for water?
The port light looking things in the cockpit, are they line holders? is there a bag or box behind to keep water out?
#277
Posted 06 April 2010 - 02:12 AM
being somewhat familiar with the project I'll take a go at some of your questions:
1. Robert's perch socket is just that - a custom-made perch will slot into the socket and provide Class A accomodations for the small feathered crewmember.
2. The jib sheet is going UP from the traveler to an exit up the mast. Wally-style, not Soling-style.
3. Portlight-like things are in fact, portlights. I don't think they will be open in offshore conditions, and inshore they shouldn't ship much water.
#278
Posted 06 April 2010 - 02:48 AM
1) Robert's perch is a custom made T handle from Harken that fits in any which. The Perch socket is a cup just like the center socket pf a winch top that jim will glass in just aft of the main hatch. See #3, Robert will be quite comfortable in any conditions.
2) Shark is correct on jib sheet. However, at the outboard ends of the jib traveler are tubes for the traveler controls. They are ABS and sized snugly for the line size. dripping maybe, but no splash, captain!
3) Shark is correct on the portlights though, the boat will have a small dodger over the hatch area for open ocean. Jim isnt sure if it will be canvas or composite. I've got my money on a really sexy looking composite.
#279
Posted 06 April 2010 - 03:01 AM
Hi Jim,
Thanks
Matt
Matt,
The trailer rests are Yoga Pads from sports authority. Flip you boat, put these on, and then glass over them with a bunch of layers (wet out on a flat table and then just lay them over the pads) See posting from March 10th at 3PM on page 10.
The boxes are just plywood. Scribe them to the curve of your bottom, glass them to the pads on the inside and outside. Putty and fair the outside per your liking (Jim took 2 days) then paint with a stipple roller. The bottoms are plywood bases with 2x4s on edge that will be bolted to the trailer and then the boxes fit over them and are screwed in. See posting from March 21 at 4:06PM on page 11
The Yoga mats are glued on with 3M super-duper-deluxe-glue your testicles to your leg if you aent careful spray adhesive.
#280
Posted 07 April 2010 - 01:41 AM
#281
Posted 07 April 2010 - 04:16 PM
So how will the kit work, at what stage will components be supplies or will that vary ?
The intention is to use the same concept as the high level composite aircraft kits, with the goal of arriving at the end of the project with the look of a professionally completed yacht.
Realizing that the hull molding is perhaps the most difficult component for a part-time builder to produce, we have decided to produce the "kit" hull complete and ready for paint all the way up to the deck connection at the sheer.
The cockpit "tub" will also be a single molding with the radius at the cockpit/deck edge molded in and ready to receive the deck panels which will require joining along the centerline.
Keel/mast frame is also a single molding that will need to be bonded in place.
Flat panels for the bow tank, aft bulkhead and transom are the only other parts that will require assembly.
Rig, keel, rudder, deck hardware may be purchased separately from the hull/deck structure components, so you don't have to purchase these parts until you need them.
We intend to be able to supply the boats in various stages including complete and ready to sail.
#282
Posted 10 April 2010 - 05:24 PM
Looks like it's blowing about 20+, which is an average day here in Hawaii.
Wonder what 30 knots will be like?
Keel bulb on my boat weighs the same as a Melges 24 (approx 580 lbs).
In all my years of sailing M24's in big breeze, I have never even gotten close to jumping out on the fin to get the boat upright.
This heavy bulb on my smaller design will speed up the recovery of the boat in a knockdown - I want to be able to sail in 30 knots without dealing with the prolonged wipe-outs, and never want my crew over the side to get the boat back upright.
Posted 10 April 2010 - 07:53 PM
Interesting snapshot I took from Charleston Race Week video today. M20 planted in a knock down with a crew needing to jump on the keel to get the boat back upright.
That's funny Jim. I was just watching the same video before checking on how your build is coming....I do have to compliment the guy who jumped on the keel, must be a dinghy sailor...but I sail in SF and like your thoughts on having a bit of lead down there....
#284
Posted 10 April 2010 - 08:23 PM
When do you anticipate pricing on the various editions?
#285
Posted 11 April 2010 - 07:16 PM
Sorry to intrude.
I am building an i550 called TANK www.ricksboat.co.uk
I was looking at your beautiful boat and thought I would really like a transom like yours.
Would it be ok for me to copy it please?
#286
Posted 12 April 2010 - 12:21 AM
#287
Posted 12 April 2010 - 03:32 PM
Hi Mr Donovan
Sorry to intrude.
dude, you're i550 project looks great!! keep it up...the Tank will be a mean machine!!
#288
Posted 12 April 2010 - 04:16 PM
Hi Mr Donovan
Sorry to intrude.
Be my guest - I'll be happy to assist in any way I can.
Although my boat is a little bit different creature than your's, there's a lot of similar battles to wage during any boat construction project.
#289
Posted 12 April 2010 - 04:17 PM
Summer - that's as much as I'll commit to now - other work keeps getting in the way.So when is the big Splash
#290
Posted 12 April 2010 - 04:26 PM
The smaller sporty keel boats paired with dinghy sailors you tend to get a dinghy sailor or two who by instinct head for the keel when its blowing hard and you park it on the side. I've had to yank a few dinghy crew back in the cockpit on the U20 over the years and explain what a keel is for. LOL
#291
Posted 12 April 2010 - 04:30 PM
Have you gotten yourself a rating or a guess at one give or take 10?
I'd expect the boat to start at 12 secs slower than the Melges 24 due to the difference in LOA.
That's purely a guess.
We are aiming at the kit form with all the "pieces" (hull, deck, frames, rig, keel, rudder, hardware) coming in at around $30K.
But you won't have to buy all the parts upfront, so the first stage kit of hull, deck and frames will be around $20K.
The boat is quite a "lot-more-boat" than a Melges 20 or Viper, so a direct comparison to those boats isn't really valid.
The design is more powerful and stable and the construction more sophisticated.
#292
Posted 12 April 2010 - 04:32 PM
+1, you "Sized Idea" people are great! Keep it up and thanks for sharing.
Hi Mr Donovan
Sorry to intrude.
#293
Posted 12 April 2010 - 04:47 PM
Thanks to all of you for saying nice things
#294
Posted 13 April 2010 - 04:51 AM
I was discussing this with my friends who sail Melges 24s here in Hawaii.
All of these guys have sailed high powered dingies - one of them has an Olympic silver medal.
We've all taken M 24’s out in way too much wind and really "scary" conditions where wipe-outs are a certainty.
I asked them if they've ever even considered jumping out on the fin on their 24's - they said "never have, no need too".
In that video the M 20 looked fairly well pinned down and staying on it's side. That changed when the guy got out on the fin.
I've sailed some keel boats that have a similar low limit of positive stability, and the long recovery period from a wipe-out will take you out of the race.
#295
Posted 13 April 2010 - 05:03 AM
My friend Harold brought by an I14 mast a few months ago asking if I could fix it.
Fixing it "right" so it didn't have any hard spots caused by the repair would cost more than a new mast tube.
So Harold has his new mast and he has donated the broken top part to my boat project.
Today I started fitting it to the bow - I need to cut it down a bit and it will need reinforcing to handle the compression and bending loads.
I'm going to start with a 1.20m (4 ft) long sprit to see how that goes.
This gives me a TPS approx 8" longer than a Melges 24.
I figure I can always cut it down if it seems too long - I suspect we will like the length.
Footbraces (upside down) in the foreground - should glue down the fwd set tomorrow - the shorter aft set are adjustable and removable.
Posted 13 April 2010 - 01:15 PM
I need to add a thin strip of rubber gasket around the perimeter and I have to do a little bit of research to find the simplest way of locking it in place.
Posted 13 April 2010 - 01:29 PM
We've all taken M 24's out in way too much wind and really "scary" conditions where wipe-outs are a certainty.
The quick wipe out move on the M20 (dependant on why you tipped it over) is to blow the halyard (it comes up quick) then pull the halyard quickly.
#298
Posted 18 April 2010 - 05:21 PM
Blowing the halyard is going to dump the spinnaker in the water. Now you've got to drag the soaking wet thing onboard and try and rehoist it, hoping it didn't get too twisted up in the douse.
Not very "quick"!
I'd rather just ease out the spinnaker sheet and blow the vang, wait a few seconds for the boat to come up, then sheet in and get straight back into the race.
On the Melges 24 you NEED to unfurl the jib to get the boat's bow to come down out of a knockdown.
I plan to keep my jib up in the breeze - it'll sheet perfectly to the rail on the full width track, and self gybe without touching anything.
#299
Posted 18 April 2010 - 08:08 PM
However the tactical dude that was on the 20 with us said blow the halyard, I did. (he has won a few big events) The boat came up quickly followed by horking the spin right back up, before it totally shrimps. I think it was quicker than jumping on the keel. The boat didnt seem to have any desire to come up otherwise.
#300
Posted 19 April 2010 - 04:32 PM
I would think the same.
How much wind was there?
