Actually, with a Max prop, the reverse is true.... the prop has the same thrust and torque in reverse as it does in forward, since the leading edge of each blade rotates to remain the leading edge whether in forward or reverse. Panic stops are a Max prop's strongest point; our 22" coupled with an aqua drive and a Perkins 4-236 has no problem hauling our 50,000 pounds from 7.3 at 1600 rpm to full stop in little more than a couple of boat lengths. It's like having a massive set of air brakes, and one of my favorite parts of the whole install.
Which is why I stated max prop set the standard for reverse performance. I said ungeared folding props were iffy in reverse....
Ah, I get it now. OK.
Find content
