S MacLeod
Member Since 21 Apr 2008
Offline Last Active May 19 2013 10:33 PM
In Topic: Where do you put the cameraman ??
21 May 2010 - 03:42 PM
The problem I see with a monohull is the position of the cameraman in order to get face shots of the sailors WITHOUT interfering with their work. If the new AC boat is designed with TV in mind, how do you solve this problem?
On the trimaran, you put the grinders and the cameraman on the central hull. Any ideas?
easy - you require a small hatch way by the mast.  we put all our cameramen in the campanion ways on the WMRT and it worked fine.  A few got hit at the wrong moments but mostly it worked fine and we got the best shots.  Cameraman onboard is much better than a remote and cheaper!
