Good stuff, watch out for that guy, he is good!, 'specially down wind!
How many AC in North America?
05 October 2012 - 12:21 AM
28 September 2012 - 07:58 PM
Hmm buy the Hoot's tooling and modify it for diagonal surface piercing foils and add an I14 gantry to the back!!! DONE
19 September 2012 - 04:36 PM
It's not a matter of computing power, much more a matter of a suitable sensor and power for whatever control is used to adjust the height. I can't tell you how many times I've run aground in a Ross 780 (draws 1.8m) and the depth sounder alarm (set at 3.5m) has gone off a few seconds later. We actually run aground less often when sailing with it turned off.
I expect it's a similar problem for any sensor looking for a boundary layer between media. At a speed differential of say 20kn between Moth and wave, the time to respond is extremely short. The bow to foil distance is perhaps 1.2m which will be covered in about 0.1 seconds.
An additional issue is the momentum of the boat—even if you can make instantaneous adjustments (which a mechanical wand does reasonably well), the boat takes time to respond. So the sensor has to be able to look forward and make adjustments in anticipation of surface level changes—sensing at the strut is too late unless fast, large adjustments can be made to (over) compensate for momentum.
And then there's the power to activate whatever control is used (main foil flap, centreboard AoA, pitch, whatever). The forces involved can be quite high, I hate to guess but likely 3 to 5 kg of compression/tension until some physical limit is reached, which might be some device (say a tether or wingbar) or whatever breaks first (probablly a pushrod or fitting but maybe the wand or flap hinge). So the servo providing the movement probaby needs to be able generate the equivalent of 10kg of force more or less instantaneously over perhaps 20 to 30mm (theres' some units here I'm missing, probably Newton metres).
Note that current mechanical devices work just fine in most conditions, it's only when the breeze gets toward 20kn and whips up 1m chop or more that they start to have problems. Even the best height control in the world isn't going to overcome low sailing ability in those conditions.
18 September 2012 - 02:10 AM
It is a great thread.
Just wondered with current development of Iphone/IPad, and other GPS/smart phone devices, is the electronc control getting much simple.
iPhone has gyro and accelerometer embedded. Is that possible an Apps with some sensors able to control a foiler Moth?
In some emails, Clive said the main problem was the actuator to drive the flap on the rudder foil, not the sensors.
He used a large RC servo ( from RC sailing/airplanes) and it would stall out.
15 September 2012 - 11:25 PM
Find content
