Erik O
Member Since 11 Mar 2010
Offline Last Active Today, 01:45 PM
In Topic: B&G compass sensor - fastnet cable ??
14 May 2013 - 07:30 AM
The Fastnet cable is completely different (and only uses 4 wires: 2 are power, 2 are data) and is a digital signal
The NETWORK compass uses 2 for power and 3 for signal (North/South, East/West and a common/neutral) and I think they use a SIN(sinus) function. Not 100% sure about that.
In Topic: B&G App W/A OFF
11 May 2013 - 07:43 PM
vhm = (v)mhu I guess =  (vertical) mast head unit
Set the offset to zero (0)
WIND -> MEAS W/A ==> CALIBRATE -> MHU ANGL   (or sometimes APP W/A)
then reset the 20/20
http://primus.bandg....et Function.pdf
"FA" should reset all 20/20 systems
11 May 2013 - 06:24 PM
Does anybody know if its possible to modify the black Compass(similar to halcyon 2000) to fit the standard fastnet cable?
http://ckdboats.blog...ass-wiring.html
This compass seems to be for the ACP1, the old h2000 pilot, check the manual
http://www.myleselec...pdfs/hpilot.pdf
page 4-11 lists the connections
It could also be the NETWORK type compass, Myles has the manual:
http://www.myleselec...susermanual.pdf
In Topic: opinion on instruments
20 April 2013 - 06:36 PM
I'm curious, can old B&G synchro analogs be used with the H3000?  We're looking to redo the instruments and wouldn't mind re-using some of the analogs if possible.
Joli, the analogs can't be used, the H3000 analogs are connected through the GFD and a SIMNET connection
In Topic: 2013 - Plotter, Routing & Racing Software
16 April 2013 - 07:25 PM
And what is the H-Link communication?
Thanks.
Rob
The H-Link is the serial protocol (on a USB port) to connect the Zeus to a H3000.
The commands are described in the H3000 manual, and are used to get the Polar data and TWA and TWS correction from the H3000 to the Zeus. The Polar can be loaded into memory, but isn't used by the Zeus for calculations.
Also all H3000 data is bridged I believe.
The Zeus Touch isn't capable of doing this, but could be connected to a Zeus to get the polar data.
Erik
