Vincent DePillis
Member Since 19 Jan 2005
Offline Last Active Today, 01:16 AM
Topics I've Started
Bonding to Faired Surface
01 February 2017 - 06:58 PM
Problem:  Am in the unfortunate situation where I have to bond to a faired surface.
Background:  Fairing compound is System Three Quick Fair, an epoxy based, premixed marine specific fairing compound.  The part to which I am bonding (trimaran beam) is structural and I can't afford (structurally) to grind off all the fairing compound.   The bonding I am doing is not super critical (post facto peace of mind reinforcement of rod in tube net rail).
Plan:  Grind off the fairing till the carbon shows in high spots, but without trying to get it out of the weave.  Rough up with hand sand 60 grit.  Coat with a toughened flexible epoxy adhesive (e.g. Pro-Set 175-276)  and then laminate on top of that wet on wet with compatible Pro-Set laminating resin.
Advice?
