BobK
Member Since 05 Jan 2004
Offline Last Active Today, 02:28 AM
In Topic: Adding shore power
15 May 2013 - 03:20 AM
Thank you all.
Boat has never had refrigeration but good block ice is getting hard to obtain and we are cruising more so it's time to add it.  In typical boat project scope creap this means we need to add battery charger, 110, etc.
Plan is to add 40A or 50A battery charger to charge the existing 2 4D's and Group 31 starting battery and hot water heater when at dock. Refrigration will be powered thru the 4D's.
Bob K
In Topic: Emergency running lights
13 April 2013 - 06:08 PM
We added tri (red/green/white) at top of mast and use the old running lights down on bow pulpit and stern under power. Admittedly we added some weight with th wire in the mast but in big seas the lower lights couldn't be seen
