Platty
Member Since 10 May 2005
Offline Last Active Yesterday, 06:17 AM
In Topic: Oracle Swipes More N.Z.'ers
16 March 2008 - 05:10 AM
Yes it is an old/non story. Neither of them have been involved with the current ETNZ campaign at all.
In Topic: High Speed GPS aerial
15 January 2008 - 08:40 PM
unless they are talking about a leica/mx marine unit. This is an active antenna and can output at 5Hz. This is too fast for a standard Hercules to do anything with (can take 1hz max from memory) but if you feed it straight into your computer (which may be tricky with a Racevision since its bluetooth feed comes straight from the B&G box), you can get improved accuracy espec around startlines etc when you are manouvering a lot.
Pretty expensive but go on lots of top end boats. http://www.mx-marine...ducts/mx521.htm
In Topic: Racin' is Racin'
11 January 2008 - 09:32 PM
http://www.theonion....reveals_winning
In Topic: Joyon heading for Brest, Coville to follow
11 January 2008 - 08:03 PM
Here is a GRIB.US view for 1200 UTC on Tuesday, and a snagged image from StormSurf for 00 UTC on Wednesday.  Pick a spot where you think Joyon will punch into and out of the high in order to get to the westerlies associated with the low coming off of NA.  Note, it's still pretty early but the models continue to show the high ooching east and flattening out at the same time...which is good thing.
just for your info, the models you are looking at are different plots off the same data - I'd be worried if they didn't show the same thing! Both are plots from the GFS model.
In Topic: Great sailors for dinner...
08 January 2008 - 04:20 AM
looks like Nick Maloney (Skandia pic)
