Restoration Ron Holland IOR racer Flirt of Paget (2)
Hi back from a 10 days trip... Progress is good and Flirt now has approx 1000 m of copper wires and interior is coming on fine. My dad has been working on the water tank installation and routing of water hoses and associated things. Here is just a small teaser of one of the supports to keep the water tank in place, made of Swedish spruce and epoxy coated, nice weight reduction was achieved by removing material... More to follow tomorrow.
  • Replies 786
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Long time since I posted on this forum. We have now finished our sixth season with Flirt of Paget and we are so pleased with her and the performance she give us as a fairly light vessel and her eagern
We are going for a new engine this winter. Old one is out and new one will be installed from next week.
FOP's work makes me feel like I'm doing my restoration with a stone axe and flint knives.
Posted Images
So many small items seems to be ready at the same time, first we managed to fix the water tanks and make really nice light and strong supports to the water tanks. The longer support is now fitted on the starboard side with a cable channel over the support for the port tank is shorter and will soon be joined by the exhaust hose.
Back in 2010 or 2011 I made the channels for the LED down lights, could never dream that is should take 3-4 years before I finally managed to complete the work -_-. Yesterday and today we marked and drilled for in total 18 white and 10 red down lights brand is Prebit.
The Alder wood (reasonable light and strong) we use for the panels is coming on nicely Göran is amazing when he cut and adjust only once per panel and the saloon is ready and painted just waiting to be assembled. The starboard side is ready to 90% and I believe that end of next week it will be ready for final sanding, filler and paint before we can install them permanently. Göran has made new stringers in Abachi and adjusted the distance between them so they now will be parallel to the sheer line and each other.
FOP, looks beautiful.
a random question for you. Do you know if there is a name for white boards that you are using for your cabin sides? Are they pre-made or are they being custom built for your project? I would like to re-do parts of my boat in a similar fashion.
I doubt they would be that hard to make, but sometimes if you know what something is called you can find it pre-cut for less than the effort of making your own.
Thanks!
Thanks!
Hi Slick, I don't if you can buy these boards or strips or ribs, part English part Swedish name for these items. We have made them ourselves in American Alder and unfortunately we are missing a few so I need to buy more of this light and form stable wood. After sawing, we sanded each piece in our neighbors giant belt sander. Two coats of primer and then topcoat.
I just can not imagine any thread beating this one for sheer brilliance, nostalgia = check, DIY = check, artisan skills = check, State of the art techniques and product to compliment project = check. Love it longtime!
Thank you very much, :rolleyes::rolleyes:
Thanks for letting me know. They could be any of those names or they could be something like battens, or slats, or something else entirely. I like the look and it is done on so many boats that there should be a name for them. Anyway, the finished product looks amazing. Keep up the good work and keep posting pictures.
Cesar has been working with the engine box this week and prepared the white panels as well as Zebrano trimming. We made some weight saving activities on the the top as you can see, probably more cosmetic then actual weight saving but it was fun. I will have a wind instrument in the aft cabin so I easily can check wind speed and direction.
We have used a similar product called Wayne's coating . Not sure of spelling but we used it on the interior of a Huckins yacht . I can't remember where we got it but a email to huckins in Jacksonville will sort you out
Wainscoting - it's the vertical staving below a chair rail on a dining room wall.
The "planks" on hull sides are called battens.
Ceiling, actually, is the word for the fore and aft strips on the inside of the ribs, often installed with a slight gap for air flow, and should be tapered toward the ends of the boat like carvel planking would be. Usually a lighter wood than the outer planking is used, such as cedar, spruce, or cypress (in North America).
A picture from yesterday, I had the opportunity to get up on a big cradle and take a few photos, not much new but she looks like she wants to hit the water this spring/summer. My boat builders are on another mission this week so there is not much to report on that side however we have painted a big number of the battens and will continue with the once in the fore peak.
A couple of years ago I bought, what I thought then, a pair decent working Lewmar 50 Racing winches. I turned out that someone had used them for pulling a lot bigger things then they where intended for, the gears on the shaft was all meshed and it was not possible to use them. I took them to my machine shop friend and asked if he could make new once in Titanium, of course he could so I got the material and they machined them by copying the old once, another company made the gears and suddenly I probably have the lightest Lewmar 50 winches in the world?
There was only one small problem, titanium/titanium does not like each other.... I believe the word is galling you turn and instantly there is more then normal friction between the materials. So now we have started to make bushings and sleeves of bronze as well as some other stuff to get these beautiful pieces to like each other. This is suddenly important since I for the first time this late in the year still believe that she will be ready :rolleyes:
The more I read the more amazed I am. You make me feel woefully inadequate.
You're not alone. I remember a time when I was actually kind of proud of my boat restoration skills.
That was before this thread.
Agree, I might have done a few crazy things on this project and here is another one... The release valve knob on the Navtec panel was badly damaged and ugly so I asked my friend Peter if he could make a better one.
The boat builder boys are back again and progress is picking up, next week will be really good, a lot of lose ends and gadgets will be installed.
FOP:
Incredible work. Looking at your Navtec release knob, I realized that (1) the boat details are better than new, but also (2) the CNC machining technology to mill the inside of that knob probably didn't exist when the boat was built. And probably only top-secret aerospace was working with titanium back in the day.
Thanks (again) for the lessons. It's fun to watch.
P
This is almost 50 years of restoration behavior materializing in this vessel, starting with bikes, furniture, cars, houses. This is the ultimate restoration project however it is kind big and as mentioned before I would probably not go all in at all areas at the same time if I ever get a chance to restore a boat again...
Here is the distribution knob for the Navtec panel made of Ti Gr 4 machined and pampered by Peter Lekberg and his fabulous CNC machines.
My dad has installed the breathers for the water tanks. Maria and I have polished the cover plate to the lower diagonal chainplates. Finally Cesar and I installed the inner jib track on port side, took most of the afternoon and evening, lack of space under deck made it really difficult to get it in place.
Tomorrow we will continue to get the last track stops and cars in place. The old man will continue with the water tanks. I will try to prime the new stringers since they have been permanently installed and glued/screwed in place.
I would be to scared to get salt spray over any of THIS ARTWORK!!!
Truly beautiful and and inspiring, thank you!
Here is a new update; Göran and Per has been working really hard to get things in place. Göran has made a wardrobe for the aft cabin, Honeycomb 3-axial glass, epoxy and Zebrano veneer. Next step will be to fit the new battens on port side. Per has finished the tech-room behind the aft cabin with more or less everything in place it looks pretty good and today he almost hooked up the batteries but it turns out that we miss a 100 mm cable ladder.
Enjoy//FOP
Thank you very much, I have a feeling she will be a good looking boat in a not too distant time.
I have a to do list of 82 topics and I believe that once the list is closed out she will be ready, the status of today is as follows;
16 done and closed
16 started but not finished
50 not started
When I realized this I was pretty happy and felt the progress but when I told Maria she started to rolling her eyes and talk funny... :unsure::unsure: Anyway I will close out a number of topics this week. One soon to get on the "done and close" list is installing the white fronts in the galley and close to the stair. The electrical system is looking really impressive and Per has hooked everything up in the aft and has now started to put marking in the electrical cabinet.
We have also almost finished the water/tank system last pic today is the valve system to select port or starboard tank.
//FOP
We are currently working on a number of items and once they are ready we will take a big step forward, possible I can close out 5-6 items next week and START on a few substantial once as well. Finally we have made a decision to make table tops in Divinylcell-epoxy and Awlgrip paint. Material will arrive next week and then... we start to laminate and sand.
I am on my way to the shop now to bring out the good old Stern mast, spreaders and fittings, nice spring day here so it will be nice to stay outside for a change.
I believe that DIN rail is common, we have it on our other boat and since my boat builders come from Najad I think that also new boats use it.
Give me a heads-up once you get to Gothenburg this summer, it would be fun to hang out and show FOP irl, we have not yet set a date but it feels absolutely possible to let her hit the water this summer.
Photo show some minor details from this week.
My dad made a few Zebrano details in solid wood, we removed material to get them lighter and more appealing, yet strong and looking solid. The long piece weighed in on 1349 gram and when we were done the weight was 1009 g :D in total we removed 349 g of wood. Today they have been epoxy treated and hopefully tomorrow we can start varnish them.
Maybe not so fun photos but more to come in second post.
Today Göran put all the white and shiny battens back in place after Cesar's massive paint job, including filler, primer sanding and finally white semi gloss paint. Plan is to install the new wardrobe tomorrow after varnishing it. Last photo show the old locker...
Weekly update;
Wardrobe in aft cabin: done
Electrical wiring to galley and head: done
Bilge pumps: done
Material to counter-tops (divinylcell) delivered: done
Vent to fuel tank: done
Vent to water tank: done
Counter-tops in aft cabin: done
Photos show some details like the divider between the electrical panel and a bookshelf, with a lot of weight saving work done. The frame for the back rests are installed permanently, wardrobe and the front to be installed below the stove.
Mate the quality of workmanship and your attention to detail is mind blowing. To have the courage to take on this sort of project is to be applauded, to stay committed in the way that you have over all this time just takes it to a whole new level.
I suspect there a very few people in the world that would have the strength of character to do this.
Cheers
Mojo
Cheers
Mojo
or the money!
Third and final for tonight
I did not spend too much time on Flirt tonight but I managed to paint the bilge in the aft cabin and around the prop-shaft. Tomorrow I will start with the counter tops...
Last pic is from 2008 when we dismantled everything, we have made so much work and spent literally all available time on this project.
I vote for the second location of the faucet, in the corner. I guess the location is as special and non mainstream as the rest of the yacht.
Hey, someboby have taken the beutiful stair and replaced by a ordinary/simple aluminum ladder.
We have already Medströms in the sea, but we are almost the only one...
Hej,
Yeap it looks like the corner position is best. Things happen now in a pace which is difficult to keep track of :wacko::D:D I received two roll-tops for the new wardrobe and the old one as well, one 600 and one 500 mm, really light and looking good. Today there has been up to four guys working on her.
There might be a post later tonight.
Medströms looks cool and I am jealous that you are like 2-3 months ahead...
I hope you get the boat out here next year for the one ton cup revival. I will be racing on Result, a 1979? Lidgard. I would love to see your boat in the flesh. I have found, while dismantling parts of my boat, just how well it was built. There is no voids in the laminate, and all joints are close to perfect. A credit to Brin Wilson Boatbuilders.
I have been preparing for the anti-fouling paint, we painted the bottom with 2-coats of Hempel light primer back in January 2012 for the boat show to get something that looked like a finished result, now it is time to finish this and Cesar sanded the bottom with 240 grit paper and then we cleaned it and masked the entire boat. Removed the rudder and finally this afternoon I applied one coat of off-white light primer, nice and thick layer and no paint curtains.
The first two show the preparation and the last photo show the final layer of white primer, tomorrow I will try to finish it off by one coat of grey and then one coat of anti-fouling paint.
Bad day, Cesar finished the white coat of light primer and I was supposed to do the grey and anti-fouling this evening. When I got over to the shop I saw the spray gun and that it had been smashed. I tried to fix it but it is total waste. Need to buy a new one tomorrow in order to finish the job :angry:
Fell off the table? Can you massage it back into shape?
Yeap it fell into the concrete floor, I tried to get it back to shape but then then thread was damaged so I spent USD 250 on a new one. Good enough if paint job would have been good unfortunately it was not. I will make a new attempt tomorrow.
FOP, since I found this thread I have been following it avidly and continue to be amazed by the updates, I'm disappointed when I have to wait to feed my intrigue on your progress. I'm so pleased that you have managed to find some people to help you get the boat ready for this season, and considering how excited I am about seeing the finished project I can only imagine how excited you are. Please, please, please can you make an post a video of her, inside and out, when she's done, I would love to see the finished result.
Keep up the good work, Thijs
Hi Thijs, you are sooo right, it is a good feeling to know that she will be ready this year and it is not in November, more likely in May or early June. I am on my way to the shop now to paint the bottom once more, result is acceptable but not according tom my plan. I will make a few videos soon be sure.
//FOP
Here comes a small update, the genua cars I have bought on ebay does not work well with the stop/end fitting I need and they are really expensive if at all possible so I have a plan to make a custom fitting to be installed over the existing sheave. The design is just the first attempt and Fredrik will work something out this week and hopefully we can start making something in aluminium.
Second post, we managed to finish the anti-fouling painting and cleaning the water line, it looks OK but not more, my plan to spray the entire bottom did not work-end of story!
Cesar has been working on his kayak and he has done an incredible work restoring it and he is now putting on the new cotton sail-cloth skin, looks nice.
Small update from last week. I have started with the counter tops, first one is ready for lamination with glass and epoxy and I started with the galley top last night. Göran is making shelf's, ceiling, and currently working with the navigation/electrical panel.
This is a short week for my boat builders since May 1 is a holiday in Sweden but I will on the other hand get 4 full days if I take Friday off. We are moving over to exhaust, bilge pump systems and closing out small but time consuming thing on our SOW list. We have this 80 item punch list to close out prior she will hit the water;
31 closed out
23 started not finished
28 not yet started
My biggest concern now is the counter tops made out of Divinylcell 15 mm thick and density 60. I cut the outline of the galley top today and it fitted without even ONE adjustment :rolleyes: last photo show the bracket to keep the galley fan in place, maybe not so raceish to have a fan but the brackets will be sooo cool and low weight.
We have been working really hard this weekend, so hard that I am too tired to upload photos, they have to wait until later this week. I have closed out a few things on the list. There are three big areas I need to close out before launch day, floor, counter tops and rigging. We have set a date but I need to confirm with Göran and Per that it is possible achieve.
More to follow :mellow:
  • 2 weeks later...
Hi, the progress is good, I have been away for a week and is now waiting for my flight back to Sweden. We have light all electrical systems are up and running and from the photos I have received it looks really cool. I will submit an update latest on Friday if you guys want to see it.
is there still any doubt? ;)
Does a bear shit in the woods?
Is the Pope Catholic?
Here is today's first update on the last weeks progress, it is amazing to see that my storage rooms step by step get empty and things actually get installed on the boat. We are currently arguing about which day/date we will launch Flirt and as it looks today are we now talking about the last weekend in June or the first in July. Things will be much easier to do on the hard but it is tempting to let her hit the water and just work on the last details while she is in the water.
I don't know if I mentioned it before but I have four major areas, rigging, flooring, counter tops and finally the remaining small stuff. It is easy to start making short-cuts now just to finish but I try to do it my traditional way, whatever that means.
First photo show the brackets we made for the galley fan and the finished result.
Second and third photo is the big counter top in the galley, it looks kind a cool and they are so much lighter then Corian
Fourth photo show the sketch for the main hatch arrangement and the dimensions.
Second update
First and second photo is for another small weight saving action just for fun, initial weight was 1415 gram and after making this beam hollow the weight was 1105 gram.
The third photo show my dad making wood plugs in the honeycomb bulkhead to install the manual valve for the bilge.
The fourth photo show one of the electrical bilge pumps.
Fourth update today
First photo show the fore-peak the light is actually quit good, I was afraid that it should be dark but it looks really cool if you ask me.
Second and third show more details of what we did today.
More to follow about the galley and flooring later this week.
Wow, your work is really amazing, FOP.
Congratulations and hope you splash her soon (with many pics ;) ).
