Gunboat G4 Foiler
Doug Lord
Ya know, if you out someone on ignore, their posts don't show up anymore? So if you are truly offended by the drivel they are posting, rather than just looking for an internet fight, you can ignore their comments in perfect contentment
  • Replies 1k
  • Created
  • Last Reply
Why does every god damn thread here devolve into "shut up doug"! Can we all just accept that he's a frequent contributor and he'll keep calling them UptiP, and just move on?
Because he says things like this is "actual speed". He's not a contributor. He's a moron.
Another video of Williwaw-actual speed. Proof positive that you can cruise a foiler:
yes all the wankers that criticise Doug continually are way more annoying than Dougs posts.
Were you all bullies at school??
I feel sorry for you all, you must have shitty lives but it is still bloody annoying.
Meanwhile, the first G4 has shipped. Here you find some more images and a stress testing video.
https://www.facebook.com/pages/ST-Yacht/188021944549351
https://www.facebook.com/hollandcomposites
https://www.facebook.com/188021944549351/photos/a.561197570565118.125821.188021944549351/950569791627892/?type=1
Just did the final VPP, and yep, she is going to fly.
My buddy Boyle works for GB and has been telling me how cool the G4 is going to be since back in October when he told me that it was going to fully foil. I didn't believe him then, but seeing that foil load test video on facebook... man... that looks like good stuff.
I was surprised how far down the vertical that they replicated the bottom bearing surface (hull exit point for simplification),
It translates to being just immediately left of the central vertical yellow steel piece that has Test Rig Foil written on it in black lettering.
The tip of the L shape is not a long way below where the bottom of the hull is, suggesting it will ventilate early upon the boat lifting out on its foils.
The foil length (or ratio) looks short compared to what we are used to seeing in AC cats, FP's and Nacra FCS etc....
It is all well and good showing the foil in increasing but ultimately static loading - but is it not the shock loading that will kill the foil or case structure first?
I'd want to be pulling that chain through a small opening of serious steel plating - I even flinched when the cameraman walked around the tip end of the rig - he would be FUBAR if the foil, rig or chain block had failed.
I still want one..... even if it doesn't foil.
M/M is not involved in the project. Shape and engineering is by DNA design team, of which ST is proud to be part of, starting with this project. The man in the hard hat is Pieterjan, director of Holland Composites. He and I developed the laminate of these foils in close collaboration. It is safe to say, he is not just some guy pulling the chain, he literally made that foil by hand.
As for safety, we know how it would break if it were to break. He is in a pretty safe spot.
Nice work!
Hey Doug (ST Yacht) nice to see your input here - Have I interpreted the overall length of foil correctly?
Is the point of contact on the test rig, the approximate hull exit point?
Can you share any details of foil control mechanism - both range, rate of adjustment and frequency etc. Any bearing details that you can share with us?
As you are not running an onboard diesel - how long will the battery system provide foil control power for? Or is this a manually powered system?
All the details you can share please?
Cheers & Good Luck.
I'd still have some sort of steel containment mesh welded all around that test jig, thats just me though. :unsure:
Still, a great example of engineering and building in composites :)
Is this a theoretical knowledge or did you do experiments to find out? Do you have any clips of those? The adjective "pretty" is not a happy one in this context. Do you know what it would take hitting and deforming the leading edge of the foil to change its hydrodynamic characteristics such that it would change the boat's pitch, yaw or roll suddenly enough to warrant "seat belts" at speed? Thank you in advance.
A combination of theory, on-board experience, simulation and physical testing. Sorry no clips for distribution, that is others IP.
The lead edge will not deform as you describe, short of hitting a container. Deceleration is a real concern, but seat belts? Foot straps is more like it.
Cheers & Good Luck.
That is the lower bearing yes. The boards were tested at the point of extension for which we intend to use them at flight when boat is fully loaded. They are marked accordingly. But, the "downhaul" strap did stretch a bunch, so it looks a little different than it actually will be on board.
Cannot share on controls.
Cheers & Good Luck.
Do you have a particular antifouling coating in mind for these foils so that the surface stays very smooth and can still repel marine growth?
No sea trial at the factory?
A bunch of closeup pics were posted yesterday to the GB FB page
Looks pretty cool
https://www.facebook.com/gunboatcatamarans
Two things:
1) The hatches have a lot of windage when open!
10432155_10153131622663490_1288395351251
1451396_10153131623103490_48461464414462
2) The galley in the middle of the cockpit has very little protection from the weather!
11080933_10153131622623490_6626646246213
1503965_10153131622638490_73701037059709
Hey, this is VERY COOL!!! Peter Johnstone bought the CLC proa Madness!?
11052374_10153175032224521_6838738814414
found this cool detail for adjusting G4 foil pitch in this December, 2014 Yachting World article:
Gunboat G4: the first flying cruising yacht could hit 40 knots. “It’s the baddest-ass coastal cruiser ever”
http://www.yachtingworld.com/blogs/toby-hodges-blog/gunboat-g4-the-first-flying-cruising-yacht-60719
The first G4 is due to launch in time for the Miami show in February. It is hoped that Antigua Sailing Week in May will be her first event.
Big call seeing as the first one hasn't hit the water yet?
Could wait a week or two and see what happens with boat 01, as with all boats big changes are made once they start moving! (Plus it'd be nice to see it in motion before splurging for one)
Sorry Peter Johnstone that's my $0.02
PS. You might be a week off having (In my opinion) the best, coolest boat ever made.
There are a few more pics - this time on PJ's FB page
Hide and seek, eh? WTF is up with that unprotected galley in the middle of the cockpit?
it is much easier to unbolt and leave on the dock. This is not a craft for deep ocean transits. Think cafe racer. Only more daiquiri racer.
Is it removable?
For a race all you would need is a jetboil down below
Is it removable?
Again, full disclosure - I have been working with DNA on the design and engineering of this boat, but I am not its designer. Yes the galley is removable. No there is not a whole lot down below - certainly no stove. The boat has structure and stability for Cat B - offshore, like any TP52, but it is really not the kind of boat you are going to take 6 hungry souls on a 600 nm offshore race. Be realistic about what the galley is there for.
Looks pretty cool
Two things:
It is a logical progression, captain.....
:wub:
Is it removable?
So this boat is a day sailer, not a "cruiser"? The cockpit galley will be useful only when the boat is anchored or on a mooring and when it's not raining. At a dock, wind from anywhere other than the bow will make the galley stove useless. Makes me wonder why they bothered with a salon and galley at all?.
If it's removable, it's probably an option
I think the galley concept makes sense - at least for some owners
You are probably not going to use the galley underway and once you are anchored you can set up a boom tent or something. This is not meant to be a luxury cruising cat - if you think you might need something underway, a removable jetboil as I suggested above will work perfectly well
It's obviouly not a boat for everyone
To me it's a performance day sailer with minimal overnight capability - there is a big market for boats in that category
It will also probably be a great boat for coastal distance racing - races up to a few days
I guess we will see whether it's a good offshore race boat - it might be
Proa, go to Peter Johnstone's FB and look at the pictures. You decide what you want to call it. I don't think it is a cruiser in the same vein as the Gunboat 60. But it is a damned good looking boat, you can stay on board for some time. oh and is very light and sails well in excess of 30 knots. Just not around the world.
The boat makes me wet but it has not gotten wet. Maybe you could wait until it actually get on the water and goes sailing before making such claims?
I don't know about 30kts, but it has gotten wet...
https://www.youtube.com/watch?v=dw-oBqn725I
Oh goodness me. Not the proa. The G4. I'm not a hippie.
Ah, got it... I misinterpreted your post :wacko:
From what I'm used to sailing, Madness is a huge step up and looks luxurious :)
nope. Apparently not.
Well, there are plenty of pics of the G4 in the water and wet on FB, but so far no pics of it sailing
Hulls look like 50 footer that got the last 5 feet chopped off. May just do a reverse pitchpole and fall over backwards!
Remember the first ac45 that flipped? Lunch break while sailing, tripped over transoms while inadvertently sailing in reverse. Not the coolest capsize story out there.
Soma, that was exactly the incident that prompted my comment. At least the G45 doesn't have the scoops to further dig in. Did the AC 45 go all the way over? I thought that they recovered from that one. I have flipped over the sterns on my Prindle 15 during a tack when I couldn't flip the trap ring off the harness hook.
looks like gunboat has some competition.
The Leopard 40F is our first in the line of foiling cruising cats. The Leopard 40F can reach a top speed of 40 knots, making ocean crossings both comfortable and fast!
670x456xLeopard-40-foiling.JPG.pagespeed
You're a day late...
I would keep it on a lift(s) or haul it every time. Looks like a wild ride!
^ here is one of it in the water. Can't be long now.
10519179_10152676372307056_7033775155073
Looks terrific ,Doug!
Assuming it can foil..., Is there any other foiling cat wit overnight accommodations?
Hydroptere - a tri - but it's not as if you can just order one.
This is meant to be a production boat - not a one-off
:lol:
Peter... any news?
If you've never sailed where he is right now, it's prime ground for foiling. Can't wait to see the numbers this ride puts up. It's like the J130 sport boat - crazy fast, with simple accommodations, but built to be crazy fast...
If you are trying to sleep on this thing, make sure your feet are facing the bow :D
So does it sail well in excess of 30 knots with the galley?
Is the blender 12 volt, 24, or 110 with inverter? How many batches between battery charges? Does the 30 knot speed allow for enough ice for all those batches?
How do you keep the salt for the Margarita's from blowing around at those speeds?
Inebriated minds want to know.
I don't think it will foil. Maybe for very short burst but not more.
Well, we will see
If I am understanding correctly, styacht is saying that his engineering study indicates it will foil
In any case, it takes a certain amount of courage for a builder to attempt something like a foiling cruising boat, in such a public fashion.
Not everything works the first time and it's no shame to not get it right on the first try- although I am sure plenty here will not be very kind if it does have difficulty foiling
Cool
Video will be interesting
Did we ever learn the price of one of these things?
I'm guessing $2M ready to sail
I believe your guess is way high. I guess sub $1M maybe even $750k.
Maybe...
I'm basing that guess on my assumption that there is a huge amount of skilled labor involved in building one of these
It's probaly built out of some kind of high-modulus carbon- not the normal boat building carbon...
Even a ker 40 can be $700k ready to sail
I woulnt be shocked to hear that the G4 mast is $250k
Wow is that cool! Another "can't be done" down the drain. Congratulations to the whole Team!
The first production cruising foiler in the history of mankind!!!!
11053353_10153211757018839_3882637284647
Cool
Maybe...
Sig 45 starts around 1.1, so this one definitely going to be 2 or more.
Cool
Maybe...
It is normal modulus carbon fibre prepreg on nomex core. Not too exotic. Design is for full production to keep unit costs low. Big investment of course. Foils require a fair bit of carbon and work.
I think Peter will rock your assumptions when it comes to price.
By the way, it foils. Grin.
Willing to bet those pictures are boat speeds of 28 to 32 knots.
I can see 36 hours of cruising/racing between ports. Beyond that would be less and less fun for a full foiling team.
Well you don't have to foil the whole time- if you are cruising and it gets uncomfortable, you can always just sail it in the water
Looks plenty fun to me!
Foiling is way more comfortable than sailing through the swells.
As long as it is stable - if it's up and down like I ve seen other boats do, it might get kind of tiring after, say , a day or so
Anyway - I'd love to do a Vineyard Race on one of these- 240 miles seems like a good distance for the boat
You are right, it might get tiring, however at these speeds whether foiling or not, its no longer relaxing cruising. Its hold on to your socks sailing requiring a skilled crew. :)
I was thinking of having a crew of six (or more?) on the boat for 48 hours or more ... Not concerned about the motion through the water but the semi-spartan conditions below for sleeping and cooking while foiling. Cruising ("bluewater") implies sailing 24/7 for long passages, so how many on-watch crew are needed to foil this boat? Double or triple that for 24/7 full compliment? Will the positions and weights of the off watch crew affect the foiling?
This boat is amazing and super cool, no doubt about it. Calling it a cruiser though is a bit of a stretch for me.
Cool
Maybe...
Fricking awesome. Congrats!
Just off the phone with one of the test foilers...she flies just beautifully. Downwind full foiling @ 25-30 knots in the usual trade wind conditions, upwind not quite foiling but very much displacement-reduced and a gentle ride @ 14-17 knots. Total newb driving reminded me of my own report after sailing the GC32: "So easy to drive!"
High res photos coming in a couple hours along with a quick report.
Bravo, PJ and team.
From A-Catter Ben Hall (Hall Spars):
"An epic day of sailing the new Gunboat G4! The orange rocket handled the 18-20 kt breezes off St Maarten with ease. Foiling was fast and steady. I got to drive upwind and hit 15.4 kts...incredible!
Downwind with R1 we peaked out at 25.7. On the foils we had really good VMG with TWA of about 160. On the final burn into the harbor with the solent and full main the top speed was 29.7.
Probably one of the best days of sailing ever for me...all on a boat with a cruising interior, a nice fridge and stove, electric sail drive and cockpit for the best of parties.
Truly remarkable."
Archived
Announcements
