captpiratedog 98 Posted April 21, 2018 Share Posted April 21, 2018 From the Ebike Thread Quote Link to post Share on other sites
Guitar 73 Posted April 21, 2018 Share Posted April 21, 2018 Both my nephews are racing at Virginia City next weekend, anyone here? Quote Link to post Share on other sites
DA-WOODY 1,274 Posted April 24, 2018 Share Posted April 24, 2018 Does the new Gold Wing have a big problem? Multiple motorcyclists asked me about the longevity of Honda’s new front suspension after seeing a video by Max McAllister, president of Traxxion Dynamics, an aftermarket suspension outfit. You might want to watch if you’re interested in reading this article and going full nerd on their new fork for a few minutes. Take a peek: McAllister has clearly had ample time with a 2018 Honda Gold Wing. At the time of this writing, he has about 30 videos uploaded to his YouTube channel dealing with the front end specific to this bike. If you’re unfamiliar with the 2018 version of the Gold Wing and Gold Wing Tour, you should know that Honda completely redesigned the fork, using a Hossack-style front end that they call a “double-wishbone,” a huge departure from the previous generation’s conventional telescopic unit. Honda, unsurprisingly, touts the benefits of its new system. McAllister thinks there are some flaws with Honda’s execution of the new design. That difference of opinion got me interested enough to investigate on my own. Obviously, both parties have some skin in this game: Honda wants to move units of their flagship bike, which has been plagued lately by flagging sales. McAllister, of course, is in the business of selling suspension components, and a customer who has both the budget and interest level in motorcycling to purchase a Gold Wing is probably a likely candidate to spend additional money to improve his mount. McAllister’s video is titled “2018 Honda Gold Wing front shock sags onto bumper! It's sad…” He continues to effectively describe how the suspension setup works: When the bike is loaded with a rider, the shock absorber is a few millimeters away from beginning to compress what he calls the bumper, and that compression occurs all the way until the shock reaches its maximum front wheel travel, as given by Honda. Honda created this demonstration so the suspension action is visible. Note that the spring is removed for visibility. Here is the shock at rest. Photo by Kevin Wing. McAllister sees this as a design flaw, so I approached Jon Seidel and Colin Miller of American Honda to get their explanation of the front suspension action. “The bumper is designed to be a working part of the suspension, much like a damper. Unlike a traditional shock design, where the bumper is used near the end of shock travel, the Gold Wing shock has a damper/bumper that is active during normal use. This design, unique to the Gold Wing’s double wishbone front suspension, allows for a more progressive approach to the end of shock travel,” they responded in a written statement. In essence, the bumper is not the traditional bump stop intended to reduce the sudden jolt (and clang!) that a bottomed shock delivers to a rider. Instead, it’s an integral part of the suspension designed to add progressivity to the spring by offering greater resistance as the shock approaches its maximum travel. ...and here is the same shock with the wheel in the position it would be compressed. Keep in mind there is no weight on this chassis, but also note the relative lack of deformity of the bumper. Photo by Kevin Wing. I asked McAllister how he felt the new Gold Wing rode. “The stock suspension on the new Gold Wing follows a consistent philosophy as has been applied to the bike for decades," he said. "It is extremely undersprung and underdamped for the intended use of the motorcycle." McAllister also doesn't think it's a good idea to use the bumper as an active part of the suspension. “Honda could choose to simply design a mechanical spring that has the progressive rate they are achieving with a spring and a bumper,” said McAllister. “Past that, modern springs hold their rate and don’t degrade over time. Elastomers do not last, especially if they are being pounded constantly. They degrade from environmental conditions as well.” Miller had addressed this very topic in a separate email to me. “As one would expect, we tested the shock with a higher-rate coil spring and higher damping force during the prototype development stage, but we decided not to adopt those settings because they had too many negative effects. The handling felt uneasy as the behavior of the chassis became too reactive, the stability performance decreased for the same reason and, most importantly, riding comfort suffered on normal roads as the rider felt small bumps through the handlebars more, resulting in decreased overall ride comfort.” McAllister shows the shock operation in the video, but the demonstration has potential to be misinterpreted, due simply to the fact that front wheel travel is not a 1:1 ratio with travel at the shock shaft. The suspension, acting as a lever, moves the front wheel quite a bit more than the shock shaft travels. “The ratio of vertical front wheel travel to shock piston travel is approximately 2:1, at 110 mm and 57.2 mm respectively,” according to Honda’s written explanation. McAllister himself agrees with those numbers, with only a tiny variance. “I believe that the front bumper will not survive the high mileage Gold Wing owners will subject it to. I believe this will be a problem for Honda,” McAllister stated. I asked him about his video title, which seemed a bit incendiary, to which he replied, “The front suspension bottoms very easily. The mechanical spring is extremely soft. The bumper comes into use at 40 percent wheel travel. Most shock bumpers come into play around 70 percent wheel travel. “It is obvious that Honda did this intentionally, but I find it sad that there is a piece of foam that cost Honda less than $1 acting as an actual spring on an 800-pound motorcycle that will have 500-700 pounds of riders and gear on it typically. “The bumper will spend virtually all of the time the motorcycle is moving with a load on it, and it will be cycled to 100 percent travel (bottomed) constantly. The only time the bumper will not be under pressure will be under hard acceleration or when the wheel dips down into a low spot or pothole in the pavement.” Honda’s Miller emphasized that the compound the bumper is made of is a proprietary urethane blend. “Of course we produce and sell motorcycles and expect to make a profit, but we will not do so at the expense of our customers’ satisfaction," he wrote. "Nor do we build motorcycles with the intention of just getting through the warranty period. That is not how Honda has built its brand reputation.” I pinged my buddy, Evan Aamodt, who’s a mechanical engineer, to see if he could give me any more info that might not be evident to a layman. “There's a notched section about a third of the distance from the end of the bumper that tells me it's intended to compress in that area relatively easily. As for the durability of the bumper, that really comes down to the properties of the material and how hard it's being worked. There are plenty of examples of polymers holding up over high cyclic loading, like the boots over the CV joints in your car's axles, or the boot around the stick on a manual transmission car. In both cases, there are folds in the rubber that allow it to move easily under light loading. The notched section in the bumper is likely doing something similar.” Traxxion Dynamics' president believes that the wear seen here will be detrimental to the life of this bumper. See the ring at the top of the urethane bumper? Photo by Max McAllister. McAllister says that the shock shaft’s dust cover is compounding this issue. “The gap in the dust cap around the shock bumper cuts into the bumper constantly. Eventually, it will continue to cut core samples from the bumper, and the foam will fill up under the dust cap, and begin to damage the seal.” The photos of a bumper you're looking at came from a motorcycle with allegedly very limited use (375 miles). McAllister claims the damage stems from the shocks body's dust seal, which appears to be made of sheet metal. Here is the shock body itself. The sheet metal at the end of the body is evidently what's impacting the bumper and wearing in what appears to be an unconventional manner. Photo by Max McAllister. McAllister had one final problem. “Given that the entire weight carrying capacity of the new Gold Wing is 423 pounds, Honda didn’t just miss the mark, they didn’t even enter the ballpark. After 43 years of Gold Wings, the engineers at Honda clearly refuse to build a bike for the typical people that ride it. The typical male rider of a Gold Wing in the United States is 250 pounds, and a typical wife is 180 pounds. Together, they weigh 430 pounds, and have exceeded the GVW of the new Gold Wing. That is before they put on a helmet!” Honda’s Miller had a rebuttal to that. “We usually don’t list the GVWR (gross vehicle weight rating) in the traditional sense but we do give curb weight (wet weight) and max weight capacity (load capacity). These two values combine to yield the GVWR. Most bikes in the touring area have a weight capacity in the 400-pound range, so we are not out of the norm on our weight capacity. The GL1800 GVWR can be a little deceiving. It appears to be lower when comparing other models from previous years and that is due to the lower wet weight of the motorcycle. It’s important to note that the 2018 Gold Wing has a higher load capacity than the ’17 year model, by 34 pounds.” For reference, a 2007 Harley-Davidson Ultra Classic Electra Glide has a weight capacity of 471 pounds, a 2005 BMW K1200LT has a weight capacity of 470 pounds, and a 2013 Yamaha FJR1300 rings in with a 476-pound capacity. Honda is low, but not crazy-low — and the reality is that many bikes are regularly overloaded. This problem is not isolated to Honda. Lem’s take I’ll take a moment to inject my own opinion, because it’s the very thing that got me interested in researching the article. I rode this bike. I’ve told you what I thought about it in our review: The suspension rides nicely! The brake dive is reduced. (Though BMW’s implementation of this system is, to me, better.) I do think McAllister has made a few good points, though. The front of the new Wingy is definitely undersprung for a man of my portly stature, and loading (and overloading) these bikes makes it worse. Naked Lem (yick!) and naked Mrs. Lem (whoo!) ring in at basically the Wing’s load capacity. Since we make a habit of riding dressed (and bringing additional items along on our little adventures), we were overloading this bike slightly every time we took it for a ride. To me, the best evidence Honda’s system works is… that it works. This new Gold Wing is a vast improvement over the previous-gen Wingy I reviewed back in 2015. But that doesn’t negate McAllister’s experience — he’s been around the block before, and this isn’t the first fork he’s ever pulled apart. Here is another angle of the irregular wear pattern shown on that 345-mile bumper. Photo by Max McAllister. Relying on a little squishy rubber piece rather than simply installing a progressive spring from the get-go seems maybe a bit chintzy. The dust cover on the shock does seem to be beating that urethane bumper up prematurely, and that could be detrimental to the service life of the bumper in question. My suspicion is that Honda’s main goal differs a bit from that of Traxxion Dynamics. Honda wants to make money, and they can do that by using inexpensive suspension pieces that are engineered to work very well, which I think they did. They operate under the assumption that no pieces need to last indefinitely, and that suspension component replacement is a reasonable expectation for a customer who intends to ride the bike for a significant period of time. Traxxion Dynamics also wants to make some coin, but they are doing that by producing excellent suspension components. Given that most people would find an increase in price on such a costly bike rather objectionable, McAllister is simply catering to customers with higher budgets and higher expectations. I think the Honda solution works fine and will make it through the warranty period no sweat. I also feel that since rebuilding this shock isn’t likely to be financially prudent, replacement with a superior aftermarket offering makes sense if the customer finds value in such an upgrade. It’s almost a non-issue for many people, because the bumper is part of the shock assembly; it’s not offered separately nor is it meant to be replaced. Most riders who are truly interested in the best ride comfort for their particular payload will respring and revalve this bike anyway, so it’s a moot point for them. Once a heavier spring is fitted, even if the stock shock is retained, the beating the bumper takes will be greatly lessened. (Though it would likely prove too progressive, so a shock and spring swap at the same time would probably the more intelligent way to to approach a fork upgrade.) Me? If I bought one of these, I’d probably leave it alone. It worked brilliantly for Mrs. Lem and I. Could it be improved? Sure. Did I have that high on my list of needs? Nah. Long story short: Honda's arrangement will probably work (and work well) for a reasonable time period, but as McAllister shows, there are other, better (and more expensive) ways to skin a cat. Of course, Honda may simply update or improve the part — if it proves to fail prematurely, which we have yet to see. OEMs are generally good about refining designs, especially on important models with long model runs… just like the venerable Gold Wing. If they don’t, odds are good Traxxion Dynamics will have an alternative on their shelves. Quote Link to post Share on other sites
SloopJonB 12,545 Posted April 24, 2018 Share Posted April 24, 2018 Looks like an updated version of a 30's girder fork. Quote Link to post Share on other sites
PuffyJman 21 Posted April 24, 2018 Author Share Posted April 24, 2018 Well just like Harley, Honda has left a “deficiency” for the aftermarket to remedy. Keeps folks gainfully employed. Quote Link to post Share on other sites
A guy in the Chesapeake 1,679 Posted May 7, 2018 Share Posted May 7, 2018 Hey Woody - do me a favor, please - stop polluting the thread with the video selfies of self-important whiners... Quote Link to post Share on other sites
Merrill Levi 148 Posted May 7, 2018 Share Posted May 7, 2018 ahh, the wind in yer face .................. Quote Link to post Share on other sites
SloopJonB 12,545 Posted May 7, 2018 Share Posted May 7, 2018 Time to accept reality and buy a car. Quote Link to post Share on other sites
PuffyJman 21 Posted May 8, 2018 Author Share Posted May 8, 2018 5 hours ago, SloopJonB said: Total Darwin candidate. This guy was faster and stupider. Looked like he was wearing shorts. What a moron. Quote Link to post Share on other sites
SloopJonB 12,545 Posted May 8, 2018 Share Posted May 8, 2018 Total Darwin candidate. This guy was faster and stupider. Don't know why the vid didn't take before. Quote Link to post Share on other sites
DA-WOODY 1,274 Posted May 8, 2018 Share Posted May 8, 2018 9 hours ago, A guy in the Chesapeake said: Hey Woody - do me a favor, please - stop polluting the thread with the video selfies of self-important whiners... are you implying that was/is off topic ?? Quote Link to post Share on other sites
A guy in the Chesapeake 1,679 Posted May 8, 2018 Share Posted May 8, 2018 6 hours ago, DA-WOODY said: are you implying that was/is off topic ?? Not at all Woodrow - please, carry on. Quote Link to post Share on other sites
Dorado 918 Posted May 8, 2018 Share Posted May 8, 2018 14 hours ago, DA-WOODY said: are you implying that was/is off topic ?? I think he is implying that you post all that is lame and moronic about motorcycling instead of posting the good stuff Quote Link to post Share on other sites
bmiller 1,140 Posted May 9, 2018 Share Posted May 9, 2018 3 hours ago, Dorado said: I think he is implying that you post all that is lame and moronic about motorcycling instead of posting the good stuff Exactly! Quote Link to post Share on other sites
DA-WOODY 1,274 Posted May 9, 2018 Share Posted May 9, 2018 should we pad up and wear leathers, helmet, boots and branding to post in this proper (all of a sudden) thread I had a thread intended to be for Harley riders to spare others the indignites But it was Riddled with BS Trolling to the point it was just killed posts about MC's in the MC thread are on topic, skip on past the ones you're not interested in this is not filtered thought forum it's ANARCHY and as such Others may Not share your personal preferences NNTIATWWT Quote Link to post Share on other sites
A guy in the Chesapeake 1,679 Posted May 9, 2018 Share Posted May 9, 2018 I just don't understand your interest in self-important whiners, and there's no way to tell whether or not what you've shared is going to be that, or something worth spending a couple minutes watching until I've spent the time to watch. Anarchy also means that I get to tell you when I think that what you're doing is fucking stupid. The only thing motorcycle related about the last 2 vids you posted was that the whiners were riding motorcycles. Carry on - I asked, you refused, no worries. I just know now to avoid wasting time on anything you post, and that's a shame, 'cause you do provide many enjoyable contributions. Quote Link to post Share on other sites
DA-WOODY 1,274 Posted May 9, 2018 Share Posted May 9, 2018 2 hours ago, A guy in the Chesapeake said: I just don't understand your interest in self-important whiners, and there's no way to tell whether or not what you've shared is going to be that, or something worth spending a couple minutes watching until I've spent the time to watch. Anarchy also means that I get to tell you when I think that what you're doing is fucking stupid. The only thing motorcycle related about the last 2 vids you posted was that the whiners were riding motorcycles. Carry on - I asked, you refused, no worries. I just know now to avoid wasting time on anything you post, and that's a shame, 'cause you do provide many enjoyable contributions. I watched the videos but didn't listen to them I am amazed at what idiots people can be like doing 140 in traffic mph or Km I live in a world of Traffic, most of the time as a MC but sometimes as a 45' Box we all have different interests Thank Gawd !! Quote Link to post Share on other sites
captpiratedog 98 Posted May 11, 2018 Share Posted May 11, 2018 On 5/10/2018 at 1:33 AM, DA-WOODY said: should we pad up and wear leathers, helmet, boots and branding to post in this proper (all of a sudden) thread I had a thread intended to be for Harley riders to spare others the indignites But it was Riddled with BS Trolling to the point it was just killed posts about MC's in the MC thread are on topic, skip on past the ones you're not interested in this is not filtered thought forum it's ANARCHY and as such Others may Not share your personal preferences NNTIATWWT "....Harley's not a bike....it's a cult"..... RIP Pico rider in the Sky...Bro 1 Quote Link to post Share on other sites
PuffyJman 21 Posted May 11, 2018 Author Share Posted May 11, 2018 On 5/9/2018 at 12:33 PM, DA-WOODY said: should we pad up and wear leathers, helmet, boots and branding to post in this proper (all of a sudden) thread I had a thread intended to be for Harley riders to spare others the indignites But it was Riddled with BS Trolling to the point it was just killed posts about MC's in the MC thread are on topic, skip on past the ones you're not interested in this is not filtered thought forum it's ANARCHY and as such Others may Not share your personal preferences NNTIATWWT There will always be Harley haters Woodrow, I just shake my head and laugh at their ignorance. Harley builds nice cruisers and tourers at the moment and have that market cornered. I really like my Electraglide for my currant riding style, however thing are going to change for me soon as I will be doing alot of traveling in the future via RV. I'm looking at different ways to bring a bike with me. Right now Kelly wants to get a motorhome, and tow a car. I want to get a 5th wheel toy hauler and tow with my F250. If we go the motorhome route I have seen motorcycle haulers that attach to a hitch. However they are limited to a 600lbs max rating so I'm keeping my eye on a few different models of adventure tourers. I want something that handles well on the pavement and gravel, sand roads that can handle two up at times, that is also under 600#. I wonder if there is such a unicorn. 1 Quote Link to post Share on other sites
SloopJonB 12,545 Posted May 11, 2018 Share Posted May 11, 2018 A Sportster? Quote Link to post Share on other sites
PuffyJman 21 Posted May 11, 2018 Author Share Posted May 11, 2018 Sportsters are to heavy by about 100#. Suzuki, Honda, and Yamaha make a dual sport that might fit the bill they are around the 750cc range, however I just learned of the Ducati 950 Multistrad that comes in at around 450#. that looks like it might be what I'm looking for. Quote Link to post Share on other sites
Dorado 918 Posted May 11, 2018 Share Posted May 11, 2018 3 hours ago, PuffyJman said: There will always be Harley haters Woodrow, I just shake my head and laugh at their ignorance. Harley builds nice cruisers and tourers at the moment and have that market cornered. I really like my Electraglide for my currant riding style, however thing are going to change for me soon as I will be doing alot of traveling in the future via RV. I'm looking at different ways to bring a bike with me. Right now Kelly wants to get a motorhome, and tow a car. I want to get a 5th wheel toy hauler and tow with my F250. If we go the motorhome route I have seen motorcycle haulers that attach to a hitch. However they are limited to a 600lbs max rating so I'm keeping my eye on a few different models of adventure tourers. I want something that handles well on the pavement and gravel, sand roads that can handle two up at times, that is also under 600#. I wonder if there is such a unicorn. It's for sale. What's it gonna take to have you drive this home today ? Quote Link to post Share on other sites
PuffyJman 21 Posted May 11, 2018 Author Share Posted May 11, 2018 11 minutes ago, Dorado said: It's for sale. What's it gonna take to have you drive this home today ? Lol! What’s that beemer weigh? Where is it located? Quote Link to post Share on other sites
DA-WOODY 1,274 Posted May 11, 2018 Share Posted May 11, 2018 I have put 3K+ miles on me REBEL 250 It's just too small for anything other than short trips/solo that said neighbor had a '05 REBEL 250 and asked me to look at it after sitting 5 years his old batt would go to 11V in no time BUT No Amps (Only Fooling him) would Not power anything I put a jumper on it and it Lit=Up and spun over he got gas in it and Nothing I tried on Reserve and got it to start w Choke on but only @ Idle he took the Carb apart years ago and thought he Fixed it = Gas was pouring out around carb I suggested he buy a New Carb ($250) and Batt (<$100) he asked me If I wanted to buy it Sew I asked how much = $350 Sold on the spot he rolled it to my warehouse, I made a phone-call, nextdoor neighbor came and rolled it home for $750 I owned it 20 min and never touched it = Happy Ending I'm looking for my Next HD But also now looking for the same thing you are looking for (surely Not same bike but same idea) I want something Easy to lug around But that will get me Arse around when I stop somewhere I would like to have something that can go on a trail yet take a detour of 60 miles down the road & back and able to haul a Large Breasted Cougar back from a Country/Hick-Town Bar Next to sell me '08 SuperGlide Custom & '08 REBEL 250 Quote Link to post Share on other sites
A guy in the Chesapeake 1,679 Posted May 11, 2018 Share Posted May 11, 2018 http://www.suzukicycles.com/Product Lines/Cycles/Products/DR650SE/2018/DR650S.aspx - these are good bikes, but a little "buzzy" at highway speeds. This one might scratch the itch, weighs around 460lbs, and is drop dead sexy https://scramblerducati.com/en/bike/desert-sled Quote Link to post Share on other sites
SloopJonB 12,545 Posted May 11, 2018 Share Posted May 11, 2018 2 hours ago, PuffyJman said: Sportsters are to heavy by about 100#. Harley say 258K wet - under 570 Lbs. https://www.harley-davidson.com/ca/en/motorcycles/2018/sportster/superlow/detailed-specs-and-pricing.html Quote Link to post Share on other sites
A guy in the Chesapeake 1,679 Posted May 11, 2018 Share Posted May 11, 2018 4 minutes ago, SloopJonB said: Harley say 258K wet - under 570 Lbs. https://www.harley-davidson.com/ca/en/motorcycles/2018/sportster/superlow/detailed-specs-and-pricing.html Buell had a Duall Sport variant called the Ulysses that was a decent street bike, and a fair-middling fire-road traveller, but, it was too heavy to be considered for any serious off road work, IMHO. Picking that thing up on a steep hill would be a serious PITA. Quote Link to post Share on other sites
warbird 937 Posted May 11, 2018 Share Posted May 11, 2018 4 hours ago, SloopJonB said: Harley say 258K wet - under 570 Lbs. https://www.harley-davidson.com/ca/en/motorcycles/2018/sportster/superlow/detailed-specs-and-pricing.html Best to check Cycle Guide, Motorcyclist, Cycle etc.... which ever survives to see what independent testers actually weighed one up at. Manifactures literature are notoriously optomistic. Quote Link to post Share on other sites
Dorado 918 Posted May 12, 2018 Share Posted May 12, 2018 6 hours ago, PuffyJman said: Lol! What’s that beemer weigh? Where is it located? 461 dry weight, 110 hp Calaveras County, CA You're just in time for the frog jumping contest. Some of the best mountain pass riding in the world starts at my driveway . What a deal ! Quote Link to post Share on other sites
PuffyJman 21 Posted May 12, 2018 Author Share Posted May 12, 2018 19 hours ago, A guy in the Chesapeake said: http://www.suzukicycles.com/Product Lines/Cycles/Products/DR650SE/2018/DR650S.aspx - these are good bikes, but a little "buzzy" at highway speeds. This one might scratch the itch, weighs around 460lbs, and is drop dead sexy https://scramblerducati.com/en/bike/desert-sled I do have my eye on the Scrambler. We will be in Charlotte in two weeks to pick up the grand kids. There is a BMW/Ducati/ MotoGuzzi Dealer there. I have plans to test ride a few models that may fit my needs. Quote Link to post Share on other sites
PuffyJman 21 Posted May 12, 2018 Author Share Posted May 12, 2018 13 hours ago, Dorado said: 461 dry weight, 110 hp Calaveras County, CA You're just in time for the frog jumping contest. Some of the best mountain pass riding in the world starts at my driveway . What a deal ! I can fly in and ride it home. I don’t know if I would be up to a frog jumping contest on a bike I just threw my leg over for the first time though. Quote Link to post Share on other sites
captpiratedog 98 Posted May 12, 2018 Share Posted May 12, 2018 Quote Link to post Share on other sites
captpiratedog 98 Posted May 12, 2018 Share Posted May 12, 2018 1 Quote Link to post Share on other sites
Dorado 918 Posted May 12, 2018 Share Posted May 12, 2018 2 hours ago, PuffyJman said: I can fly in and ride it home. I don’t know if I would be up to a frog jumping contest on a bike I just threw my leg over for the first time though. Ok What's your flight # ? Quote Link to post Share on other sites
PuffyJman 21 Posted May 13, 2018 Author Share Posted May 13, 2018 9 hours ago, Dorado said: Ok What's your flight # ? Lol. We haven’t discussed prices. And BTW does that include a full tank of gas? Quote Link to post Share on other sites
DA-WOODY 1,274 Posted May 14, 2018 Share Posted May 14, 2018 1992 Quote Link to post Share on other sites
PuffyJman 21 Posted May 14, 2018 Author Share Posted May 14, 2018 Lokks like you were always a dapper dresser Woodrow.... 1 Quote Link to post Share on other sites
A guy in the Chesapeake 1,679 Posted May 15, 2018 Share Posted May 15, 2018 Shorts? On a Sportster? You must like burning your legs on the pipes and oil tank. Quote Link to post Share on other sites
Black Jack 581 Posted May 15, 2018 Share Posted May 15, 2018 On 5/11/2018 at 10:04 AM, Dorado said: It's for sale. What's it gonna take to have you drive this home today ? A harder working wife. With a bike like that - I won't have time to work. Quote Link to post Share on other sites
A guy in the Chesapeake 1,679 Posted May 16, 2018 Share Posted May 16, 2018 Shoot - just realized a previous reply didn't make it - Woodrow - thanks for the kid vids - gave me something to smile about, remembering teaching MY kids how to ride when they were younger. My now 25 yr old son's 1st time out on his Honda 50 (he was 5) he ran it right into the deck steps. We picked him up, settled him down, and 15 minutes later, he rode it up a pine tree out back. By the end of the week, he was asking me to build him a ramp. 1 Quote Link to post Share on other sites
WCB 775 Posted May 16, 2018 Share Posted May 16, 2018 On 5/11/2018 at 12:18 PM, A guy in the Chesapeake said: http://www.suzukicycles.com/Product Lines/Cycles/Products/DR650SE/2018/DR650S.aspx - these are good bikes, but a little "buzzy" at highway speeds. This one might scratch the itch, weighs around 460lbs, and is drop dead sexy https://scramblerducati.com/en/bike/desert-sled Love that Scrambler. Saw one at the local Duc shop while checking out the Panigale V4 the other day Quote Link to post Share on other sites
A guy in the Chesapeake 1,679 Posted May 16, 2018 Share Posted May 16, 2018 15 minutes ago, WCB said: Love that Scrambler. Saw one at the local Duc shop while checking out the Panigale V4 the other day I'd be tickled to add ANY of the Ducati lineup to my collection. The Diavel is hot, the Monster just begs you to sharpen its footpegs. I don't have anything like the Scrambler, and where I live in the northern Shenandoah Valley? it'd be a practical addition. Quote Link to post Share on other sites
WCB 775 Posted May 16, 2018 Share Posted May 16, 2018 39 minutes ago, A guy in the Chesapeake said: I'd be tickled to add ANY of the Ducati lineup to my collection. The Diavel is hot, the Monster just begs you to sharpen its footpegs. I don't have anything like the Scrambler, and where I live in the northern Shenandoah Valley? it'd be a practical addition. There is something about them. They "finish" the bike better than japanese companies and they are so much more pleasing to look at. I had a 1098 from the first year that they came out and I loved it but it was a lemon so I sold it in 2010. I've been thinking about another Duc since then. That Scrambler Desert Sled would be fun for around town here in Park City including some of the canyons. Quote Link to post Share on other sites
bmiller 1,140 Posted May 17, 2018 Share Posted May 17, 2018 Great late afternoon ride yesterday, a couple friends and no one else on the single track sections. No vehicles in the staging area. In fact the only evidence of other human activity was a little dust cloud off in the distance. We have miles of two track and 50" or less but not a ton of motorized single track, at least the so called "designated" routes. FS is opening up a few more miles but still not even close to what this area could support. The forest managers around here believe the best access is no access. All in all still a great place to live and recreate. Quote Link to post Share on other sites
DA-WOODY 1,274 Posted May 21, 2018 Share Posted May 21, 2018 APE Quote Link to post Share on other sites
DA-WOODY 1,274 Posted May 21, 2018 Share Posted May 21, 2018 JUAN Lucky MoFo proving when it Ain't yer time it Ain't yer time Quote Link to post Share on other sites
SloopJonB 12,545 Posted May 21, 2018 Share Posted May 21, 2018 29 minutes ago, DA-WOODY said: APE That is very probably the single stupidest motorcycle I have ever seen. And that includes things like this. Quote Link to post Share on other sites
DA-WOODY 1,274 Posted May 22, 2018 Share Posted May 22, 2018 16 hours ago, SloopJonB said: That is very probably the single stupidest motorcycle I have ever seen. And that includes things like this. in the mid 70'z there were XXXXL solid fork tubes with 1/2 leaf springs welded to the end as Far from having a fork brace as you can get DANGEROUS !!! oh ya No ft brake too Quote Link to post Share on other sites
DA-WOODY 1,274 Posted June 10, 2018 Share Posted June 10, 2018 Quote Link to post Share on other sites
DA-WOODY 1,274 Posted June 15, 2018 Share Posted June 15, 2018 reply below Posted 24 minutes ago Motorized beach cruiser bike mechanic 2 stroke only (Escondido) condition: good I offer you my free stuff you fucking freeload. But when I am looking for work you don't reply nor on my cheap price Echo leaf blower. You need you're asses beat with a bloody baseball bat. I'll take a hammer straight to your ungly face jotos lol u little hutos!!!!!!!!!!!!!! I can meet you at Albertson lol u little puss ass cowards and beat your ass tonight. LoL lmao at y'all. Ypure all be laying there knock the fuck out crying. You're going to be like a seal flopping around in the parking lot knocked the fuck out. Ypu little pussy boy huto guey. I ani't giving you jotos nothing for free every again. I'll just scam you freeloader real fucking talk. Fucking retards learn how to work and be sober in life. Nutcase people. . . . . do NOT contact me with unsolicited services or offers post id: 6617482379 posted: 24 minutes ago Quote Link to post Share on other sites
DA-WOODY 1,274 Posted June 15, 2018 Share Posted June 15, 2018 A cruiser fit for a Russian strongman Lance Oliver May 30, 2018 44 Comments Imagine a motorcycle built for a Russian strongman and you probably would come up with something like the bike above. And you'd be right, apparently. The Russian corporation Rostec, working with Kalashnikov, the company better known as Russia's largest small arms maker and the maker of the AK-47 rifle, built this concept motorcycle. News reports last week from the International Economic Forum in St. Petersburg, Russia, quoted Rostec CEO Sergey Chemezov as saying the Izh motorcycles will be part of Vladimir Putin's official escort beginning next year. Seems appropriate. For a manly head of state known for being photographed riding horses without a shirt and for occasionally benefiting from the sudden disappearance of his critics, a long, low, black motorcycle projects an appropriately sinister air. The Izh being tested on the track. Kalashnikov photo. The spec sheet is sparse (maybe it's classified?), but Kalashnikov, which built the prototype, did provide a few numbers. The motorcycle is nine and a half feet long and weighs a ground-hugging 1,124 pounds. I'm sure the weight has to do with the fact that like the other vehicles in Putin's motorcade, the Izh is built to be bullet-proof, and I'm referring to ballistics, not mechanical reliability. Despite the heft, Kalashnikov claims it will do 0-60 (well, 0-100 kph, actually) in 3.5 seconds, thanks to its 133 foot-pounds of torque. Top speed is reported to be 155 mph. Kalashnikov gives no details on what's under the shrouds covering the engine, except to say it's an "opposed," gas-powered engine. The latter is worth specifying, since the company has also produced electric motorcycles for police and military use. I'm presuming the engine is liquid-cooled, based on the appearance, and perhaps a flat four-cylinder design. This video, shot by Kalashnikov, shows the bike on the track that hosted the Formula One Russian Grand Prix. Chemezov, a long-time ally of Putin's who has been subject to U.S. economic sanctions in the past, said Rostec could potentially put the motorcycle into mass production. But for now, the only way you'll be riding one is if you're clearing the way for the president of Russia. Quote Link to post Share on other sites
Mid 4,381 Posted June 15, 2018 Share Posted June 15, 2018 ^ butt fuck ugly Quote Link to post Share on other sites
PuffyJman 21 Posted June 15, 2018 Author Share Posted June 15, 2018 Check out the new Honda Monkey 1 Quote Link to post Share on other sites
chester 1,243 Posted June 15, 2018 Share Posted June 15, 2018 I wanted a Trail 70 soooooooo bad when I was 11. Quote Link to post Share on other sites
DA-WOODY 1,274 Posted June 15, 2018 Share Posted June 15, 2018 4 hours ago, PuffyJman said: Check out the new Honda Monkey Shweeet Quote Link to post Share on other sites
WCB 775 Posted June 15, 2018 Share Posted June 15, 2018 10 hours ago, PuffyJman said: Check out the new Honda Monkey I want one of those...6'3" may not look good on it though. 1 Quote Link to post Share on other sites
captpiratedog 98 Posted June 17, 2018 Share Posted June 17, 2018 And then....along comes Benelli.... Quote Link to post Share on other sites
PuffyJman 21 Posted June 17, 2018 Author Share Posted June 17, 2018 1 hour ago, captpiratedog said: And then....along comes Benelli.... The way the pipes come down in front of the motor looks like you could damage them easily. 1 Quote Link to post Share on other sites
SloopJonB 12,545 Posted June 17, 2018 Share Posted June 17, 2018 3 hours ago, PuffyJman said: The way the pipes come down in front of the motor looks like you could damage them easily. That's what I thought - those tires look like it's supposed to be a dirt bike and then they put the pipes at the lowest point. Needs a skid plate as well. Quote Link to post Share on other sites
warbird 937 Posted June 17, 2018 Share Posted June 17, 2018 5 hours ago, PuffyJman said: The way the pipes come down in front of the motor looks like you could damage them easily. That is a "Tracker" style, think smooth dirt ovals!. Quote Link to post Share on other sites
Dorado 918 Posted June 17, 2018 Share Posted June 17, 2018 Lose the knobbies and you got something. Quote Link to post Share on other sites
DA-WOODY 1,274 Posted June 19, 2018 Share Posted June 19, 2018 Quote Link to post Share on other sites
PuffyJman 21 Posted June 19, 2018 Author Share Posted June 19, 2018 Yikes that wallet chain is really close to the bike chain. Hope he is an organ donor. Quote Link to post Share on other sites
GER308 66 Posted June 19, 2018 Share Posted June 19, 2018 Had a nice ride to Bitche saturday :-) Having a blast with my new old F650 Quote Link to post Share on other sites
Dorado 918 Posted June 19, 2018 Share Posted June 19, 2018 Very cool. Local tourism board slogan " Hike Bitches" Renting a K1600 and riding a bunch of the TDF stage routes is on my bucket list. Quote Link to post Share on other sites
DA-WOODY 1,274 Posted June 19, 2018 Share Posted June 19, 2018 Spotted on the road while towing me new Tent Trailer home does'nt look cumphy for the Long Haul and hard to get a Big Titted Cougar on the Back image: http://powersports.honda.com/images/montesa/2018-hero.jpg Trials riding requires a subtle touch. It’s all about precision, and a precise connection between rider and machine. Honda and Montesa have teamed up for a perfect balance too, delivering a bike with Montesa’s legendary trials knowhow and Honda’s equally legendary engine technology. Top it off with state-of-the-art suspension, and you get two of the best specialist motorcycles available in the world. Check out these two great options: The Cota 4RT260 is a cutting-edge trials bike, the perfect combination of Honda’s engine technology and Montesa’s world-championship trials experience. Want to ride what the champions ride? Then check out the Cota 300RR Race Replica. With its 288cc engine, it’s even lighter than the feathery Cota 4RT260. Both Cota models offer twin ignition maps for varying riding conditions, a perfect example how Honda brings cutting-edge engine technology to the trials class. No matter which Cota you choose, you’re getting one of the best pure trials bikes ever built—a marriage made in motorcycling heaven. specsGet Yours Nowspecs New for 2018 image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/Chassis_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/PGM_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/advanced_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/brakes_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/dual_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/Kickstarter_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/Premium_Sus_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/PISTON_thumb.jpg Media Gallery PHOTOS ●● image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_01_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_02_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_03_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_04_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_05_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_06_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_07_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_08_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_09_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_10_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_11_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_12_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_13_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_14_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_15_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_16_thumb.jpg image: http://powersports.honda.com/assets/flash/model/gallery/MontesaCota300RR_01.jpg ◀ PREVNEXT ▶ European Models Shown Read more at http://powersports.honda.com/trials.aspx#VqgPhSbkt9fML3zs.99 Quote Link to post Share on other sites
SloopJonB 12,545 Posted June 19, 2018 Share Posted June 19, 2018 17 hours ago, DA-WOODY said: A Darwin candidate in multiple categories. Quote Link to post Share on other sites
warbird 937 Posted June 20, 2018 Share Posted June 20, 2018 13 hours ago, PuffyJman said: Yikes that wallet chain is really close to the bike chain. Hope he is an organ donor. Do you really lo for a card??? Quote Link to post Share on other sites
warbird 937 Posted June 20, 2018 Share Posted June 20, 2018 7 hours ago, DA-WOODY said: Spotted on the road while towing me new Tent Trailer home does'nt look cumphy for the Long Haul and hard to get a Big Titted Cougar on the Back image: http://powersports.honda.com/images/montesa/2018-hero.jpg Trials riding requires a subtle touch. It’s all about precision, and a precise connection between rider and machine. Honda and Montesa have teamed up for a perfect balance too, delivering a bike with Montesa’s legendary trials knowhow and Honda’s equally legendary engine technology. Top it off with state-of-the-art suspension, and you get two of the best specialist motorcycles available in the world. Check out these two great options: The Cota 4RT260 is a cutting-edge trials bike, the perfect combination of Honda’s engine technology and Montesa’s world-championship trials experience. Want to ride what the champions ride? Then check out the Cota 300RR Race Replica. With its 288cc engine, it’s even lighter than the feathery Cota 4RT260. Both Cota models offer twin ignition maps for varying riding conditions, a perfect example how Honda brings cutting-edge engine technology to the trials class. No matter which Cota you choose, you’re getting one of the best pure trials bikes ever built—a marriage made in motorcycling heaven. specsGet Yours Nowspecs New for 2018 image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/Chassis_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/PGM_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png image: http://powersports.honda.com/images/montesa/features/advanced_thumb.jpg image: http://powersports.honda.com/images/montesa/zoom.png
