3 hours ago, Lat35sowth said:
So my understanding is that some part of the internal framing/stringer punched the hole due to water pressure on outside of hull as it hit side on?
That's not my understanding. As I understand it, the frame remained rigid. When the boat slapped the water, the thin skin collapsed inwards between the frames and gave way, which could explain the square edge (against the cross beam). That's why the boat would have coped with a vertical fall onto the 'keel', but not a fall onto the side.
  • Replies 15.2k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
And we have liftoff!!
I for one was happy to finally see an American team that didn’t just reek of assholes. Terry was a great bloke to have in front of the cameras and the intimate videos behind the scenes I found quite f
Posted Images
Obviously, to complete all of the work of replacing the electrical systems and the FCS, they will have to cut some huge holes in the deck of the boat.  TH said they will be using the local NZ contractors to build the “flat sections” and their own crew to build the more complex custom shapes.  So it seems obvious that the NZ folks will build the deck patches while AM will do the underside patching.  TH said they plan to set up everything just like it was, but it won’t be as pretty.
Missing
1 X AC75. American made. Last seen not far from Milford. Please, if you see this boat, please return to owner ASAP. There is unfinished business to attend to.
3 hours ago, 167149 said:
and here i was thinking it was a battery pack for the foils that just went mother in law and departed through that neat square hole
You must have a different mother in law.  Most of them stick around and won't leave.. or atleast mine wont.
12 minutes ago, Rushman said:
I don’t buy the pressure from landing punching a hole through the skin
The explanation offered by TH doesn’t pass the pub test
Imagine you are the Big Bad Wolf, blowing at the pig's house. If you blow hard enough, the relatively thin gib will give way between the framing. You'll get a hole in the gib but the framing will remain intact.
There is obviously some confusion here about what TH was referring to when he said "guillotine", and I actually searched this thread for the words "shear" and "stress riser" with no results so I thought I'd post. Much as the flying battery was a compelling concept, the guillotine idea explains both the size of the hole (assuming it wasn't cut much more) as well as why the hole is lower than you'd expect it to be if it was caused by excess forces from the FCS supports.
High shear forces can arise where there are stress risers, abrupt changes in the thickness of a part for example, which concentrates stress where change in geometry results in a change of thickness. A similar situation arises in scissors and indeed guillotines, where you concentrate all the force across a narrow space, creating high local shear. In this case, if you imagine a pair of bulkheads and a pair of  stringers surrounding a square area of plain hull, you can, depending on how it is constructed, have this frame be much stiffer than the panel. This may be fine unless the loads get too high, and you get a scissor like effect right at the change in stiffness. I have run a simple simulation in Solidworks' basic simulation package, using solid aluminum as the material. It's about 90cm square and the 50mm frame is fixed. The central panel is 15mm. Picture 1 has a sharp edge, picture 2 has a 40mm fillet and picture 3 has a 100mm fillet. These simulations are hard to interpret because they rescale the colour contours and you have to look carefully at the numbers, but as the transition from panel to frame is made more gradual, the  peak stress drops by almost a factor of 2. So if they were using the word guillotine, I strongly suspect they are thinking about this mechanism.
  • Like 9
7 minutes ago, gungabow said:
Sorry took so long
Got home late last night and had to work today
Which way up does this go?
Ok.. these pics show a piece that would fit the hole
I was struggling to picture it as the photos yesterday this piece looked triangular
Thanks
See that little white square on the foredeck
That's the air vent for the FCS
Wonder where the batteries are located?
Wonder what heavy thing experienced G's in deceleration going to Port?
My bet is there is a set of LiPo batteries on the seabed somewhere off Mission Bay
1 hour ago, zenmasterfred said:
Would be great if they did time lapse photography of the repair to show their grandchildren and we children here some day.  Going to be quite the project.  At least when they cut away the bad part it will be easier to run the new wiring.
For the Muricans not familiar with British DIY, to raise a smile while we all hold our breath
Not for the first time in this thread, it wasn't a battery. TH explains it in his pretty clear response to a question from a journalist who specifically asked if a battery had caused the hole. Jump to 9:03 in the video for the question and TH's answer:
https://youtu.be/4-yvEmEqdBc
granted you do have a point there, however, when they do eventually erupt it'll be in a fashion that is quite spectacular (to a spectator) and often they'll fucking return,  this return sequence is the truely scarey part as she aint done with you yet  and is determined to put on a masterclass for your wife on how to behave and reduce any thoughts you had of complacency or security,
TH is clearly not an engineer and his answer to the question is his interpretation of what he has been told.  For some reason everyone seems to have forgotten that there is/was a watertight space, required by the rules, in the bow area which should easily keep the boat afloat.
The "internal structure" that came loose damaged the watertight space as well as making a large hole in the hull. I am sure that all competitors will be reviewing their "internal structures" to make sure that they are secure in all situations.
Nice story but it's bullshit. There's a lipo battery on the sea floor. Why else were divers out there this morning?
6 hours ago, Priscilla said:
Maybe an opportunity to have Te Rehutai fill Amways spot in the Prada Cup:P
3 hours ago, jaysper said:
But then we'd the challenging ourselves in the match, no? ;)
Ah, I've spotted the obvious downside, we'd be guaranteed to lose...
What is the purpose of them lying about it?
As for the divers, could be any number of reasons
11 hours ago, DryAxE said:
Well, ETNZ stated it took them 8000hrs to build the hull. So if you have 50 man and 12 days, each man working 16hrs per day its 9600hrs.
Ah, the Mythical Man Month. Someone wrote a book about it. Two women cannot have a baby in 4 1/2 months.
6 hours ago, tDot said:
While you're at it, please explain how opening the top of a fat head doesn't spill power.  If there's no power up there, whats the point of a fat head main?
It's like when you go down the mine in a skiff: You've spent the whole race with the apparent wind less than 60 degrees off the nose; then you stuff the bow in a wave, the boat slows right down, and suddenly the apparent wind's 60 degrees off the stern. Opening out the top of the main isn't going to help; if anything it'll power it up and make the situation worse.
The situation's a bit different here; it's the loss of control that causes the boat to slow down, but once it starts slowing down, the apparent wind's coming from well behind the beam, and it's going over.
  • Like 4
Yep, similar happened to NZ, an abrupt slow down of the boat, wind beam on, and over they go.
One point that doesn't seem to have been mentioned in the cause of the accident. AM have on 3 (?) occasions ended up pointing at the sky, whereas I don't recall an of the other 3 B2s doing that. NZ capsize forex was a nose in job (more conventional).  Is AM designed in such a way that the leaping salmon is more likely to happen?
Because even in this incident, they had done the bear way (or at least past 90 TWA) so the force from the sail would have been tipping the boat forward, not back, so the squall hitting should have increased that tipping moment.
What that design difference might be, I'm not sure, but the T on the rudder and its controls would be my first point of interest- Is there a condition or set of conditions when that T generates massively too much downforce, in a way that doesn't happen on other boats?
1 hour ago, gungabow said:
Sorry took so long
Clearly, that portion of the hull was not designed for slamming. If it had, it would be single skin with ribs, like Cherokee, or adopting thicker, lower modulus foam core to absorb energy - like in offshore powerboats. But then, the weight limit may have prevented it
2 hours ago, The_Alchemist said:
Watch TH press conference for the correct take.
Terry was clear no battery came out. But I ask you to have a think if every thing that you are told is true ? Wile I dont know the true answer , it would not be great PR for the cup if they at dumped a battery in the Gulf. What is more likly is the battery did brake lose and did punch out the hole but remained inside. Ive not  watched anything since the race but it seamed strange at the time that they were not able to lower the starbord foil to help right her. And then they opened the hatch up which makes me think they thought there might be an internal conection problem that was stoping the foil moving. No one in that posishion would chouse to open a sealled hatch when on there side unless they thought it was the best was to solve the problem.
Agreed! There is more footage in the AM Video - they are not hiding much! Good on them.
But man I have watched the crash down over and over again, and it still seems amazing, almost freak-incident level situation that such a touchdown could cause such a catastrophic failure...
this boat is no tractor! It's as fragile as LE's ego!
27 minutes ago, WakaNZ said:
wow
Great video, hats off for the transparency from the team!
Still below seems to show a tubular framework to support the loads, covered by a relatively thin outside shell. The part that came off seems to have folded over the diagonal brace, which in turn prevented the now detached panel from entering the hull, which explains why it then floated away
I think it's a complex set of conditions - boat speed, AoA, boat pivoting when rudder lost, etc. The sky leap seems to occur when the boat speed is relatively high, stabilator loses lift so the stern falls down, resulting in a high AoA of the foils.
NZ and LR have also headed skyward, although the clips I have were in the B1 boats:
Luna Rossa take off
ETNZ
When a boat pivots sharply on rudder loss, they seem to dive, like this one:
Ineos
The area that would worry me is that above the hole, directly in front of the foil arm. It looks like the boat basically folded. The big issue was probably caused by the foil leaving and reentering the water, the sudden unloading and loading sending loads forward that caused the internal structure too fold, popping a bit of hull out. The internal structure above the hole is going to be the big ask.
I also suspect that the eventual hull fix will be a lot bigger. My last trip to NZ:
image.thumb.png.f6f0a3b1a6b5570536bb013353effb9f.pngimage.thumb.png.9dc021177b286331cc23f8462263bcc2.png
Nice take on it and I’d say that’s close to what TH was referring to.
I crunched the up and down numbers, AWA looks to be around 13-14 degrees both upwind and down so if a boat is set up to fly stable at that AWA then opening it up to even 25 degrees will create massive forces looking to both heel and cartwheel the boat.
This overhead shot shows the effect of the backstay on the mainsail. But given loss of speed and a beam on wind, I'd guess they would have gone over regardless.
Luna Rossa take off
ETNZ
Ineos
But as you say the others only did it with B1s. Have the others got something to resolve the issue? Or have AM just been 'unlucky'?
Kudos to American Magic for getting such an honest vid up so quickly. Initial thought from some of the other teams is a large foil control systems box weighing 60kg (132lbs) may have broken free and punched out through the hull when it slammed down on tis side.
Hoping AM will disclose what caused the hole soon.
video from the bow cam....this looks like long after impact, a bit of carbon in the wake already. Seems like the the windward arm settles and stops at the same time the fibres pop. Maybe.
Pictures are worth a shitload of words.
Speculation of course, but... AM were still at quite a high speed, whereas in NZ's dive recently they had already slowed down some before they turned and lost control.  I tend to think AM was unlucky to get hit by a gust when they did, almost instantly accelerating the boat at a difficult point in the maneuver.
Maybe the only way to "resolve" the issue is to avoid it in the first place, with excellent user-friendly control systems, and 100% concentration from flight controller, mainsail trimmer, tactician and helmsman?
Maybe. :unsure:
I noticed that too, but dont have explanation. This occured at the same moment foils slammed the water hard. The second impact was when boat hit the water. Im think most of the damage was done with second impact.
28 minutes ago, Neverwas said:
1477720948_ScreenShot2021-01-18at10_27_59.thumb.png.17504eb6c4f6fbde5ae3bda2e83c7230.pngIs that something popping through the hull? Thats on the way down
I dont know if i drawn it totaly accurate but to me shape of American Magic Patriot has the weakest hull section in case of flat impact like it happened. It has preety flat sides with just slight curvature outward, in case of impact forces can flex this curve from outward to inward and that might cause that long crack that continues from hole towards the bow. ETNZ Te Rehutai might land even flatter since it has concave hull side, but hull is already turned inwards so it would spread forces more evenly, some cracks might still occur. Luna Rossa and Brittania have more curve to handle such impacts.
I wonder was it a smaller puncture further aft that weakened the structure enough that when it slammed the force travels along a crack and then blew the large section out! the pics of her in the cradle do show a longer crack traveling aft of the hole.
Christ... This is one terrible situation for a challenger to be in and not good for the cup. I really hope this team do get the boat back together and manage to to do so in a competitive nature...
Post situation I have two takeaways;
  • Something did come out of the boat, if you watch the video in slow mo its clear something burst through the hull. TH knew this and sidelined the question simply saying both batteries came off the boat.
  • Deano is a a great guy and I for one have felt for him over the year - But where was he in that lastest video!?!
Best of luck to the team, I hope they get back out and are competitive.
Third small point..... INEOS must be rubbing their hands together that this has taken the media press off them......... No way is their sudden performance a surprise, this has been the game plan!
Sorry I take that back the photo I was looking at its just reflections going aft not a crack, I dont think
They admitted they were slow before, doubt they would particularly mind the very positive media attention they would be getting.
I think they might be more happy about the fact that they have more opportunity to push in the next set of updates having got some great data about where they are. Lets face it there might have only been 3 days but it covered a pretty wide range of conditions!
Sure, media now for the team is mostly good....But there are a lot of questions regarding them hiding their performance back at Christmas, I think they were training with winter tyres on and knew that when they put the slicks on they would show a % increase which they had bench marked.
But, back to AM...... Again, lets hope these guys come back fighting rather than limping.
This is a bird... believe it or not
  • Like 8
Has anyone the expertise to measure the deflection in the foil arm as it hit down? is that a lot further aft than normal? Possible this defection load on the arm popped the skin in front of the foil arm off the structure and then the impact and the water pushed it back against the structure caused the Guillotine effect TH talked about?
Neverwas,
That is the worrying area, right in front of the foil and where there must be significant structure. Something has let go in that area and it won't be a few layers of carbon to replace/fix it. The hole in the hull is just a flesh wound, that is an organ.
It was horrible seeing Hutch by his lonesome at the press conference.  That sucks, and I really feel for the guy.  Sure, I can understand why he was there by himself, as he's the skipper.  He probably made the call to represent the AM team at the conference and to give the team the time to take stock of what needs to be done, and to have a plan in place.
Not seeing Dean in the AM video posted above is concerning.  I hope that the team haven't led him out to pasture.  That would invalidate the whole statement Hutch made: We win as a team, and we lose as a team.
Someone said that Dean is a Jonah.  This is so wrong, on so many levels.  He's been in the unfortunate position of being given dodgy platforms (2003), poor tactics (2007), a platform that wouldn't/couldn't be improved upon to beat Oracle, not to mention that horrible decision to give Oracle a lay day (2013).  I still believe that he's an excellent sailor and can, at some point, win the AC; just not AC36.
If Patriot is successfully repaired and is competitive, I think that she should be renamed to Phoenix.
5 minutes ago, JeronimoII said:
Did anyone notice that Dean Barker does not appear in the video. Potentially his sacking going to happen?!?
I suspect he is devastated. I hope he can come back because he is world class.
Just looked at the aerial footage again. I noticed that the boat landed pretty much going sideways and heeled over. I think that the forces are pushing the foil down quite hard at that moment. The FCS and surrounding structures will be almost certainly not designed to handle down loads especially not type of loads with the whole boat doing the pushing at 30knots. Could this be why there is this much damage ?
Of course I'm rooting for AM in the grand scheme of things, but I can't help to think that only having three competitors in the Prada Cup makes each and every race utterly useless.  Not only do AM not have to sail this upcoming weekend, they never had to sail this weekend or even last weekend for that matter.
Just one more competitor would have held everyone to account for each and every race.
As much as I know they are going to get back in the water and be competitive, it would really cheapen the entire thing if AM wins the Prada Cup while missing out on an entire weekend of racing.
Not in foilers he ain’t.
of course let’s just leave the multiple moth world champ on the main and deano on the helm
Makes sense.
It was great to see American Magic team willing to show some views of the interior of the bow.
I think I can see outlines of the transverse ring frames and the longitudinal stiffeners
Red - longitudinal; yellow - transverse ring frame; green - centre plane tubular stiffeners
Then again the resolution is low, it is dark inside the hull so it's possible I'm just seeing things.
Very little has been shown, but I'm getting an impression that the manner in which the hull bow is stiffened/reinforced is different to what Alex Thomson showed on the inside of Hugo Boss when it suffered stiffening structure cracking. And that of course makes sense as his IMOCA60 is expected to slam into massive waves in Southern Ocean...!
Then again the height from which the bow of Patriot slammed into water yesterday may just resemble a slam of ocean-going monohull..
Makes sense.
He was one of the first foilers. I agree you have an after guard problem. The weakness if you ask me is TH. Move Goodison to tactician just like Giles and take TH off the boat and replace . The set up on INEOS seems to be about the best way of doing things.
Did Flight Controller Andrew Campbell Cause AM's Capsize?
I've re-watched the capsize of AM numerous times, including at 0.25% speed, and then frame by frame. Questions arose. Was loss of control over the stabilator (rudder foil) the cause of AM's "sky leap" and subsequent capsize? Perhaps not.
It may be that rudder rake was set back a touch too far, bearing in mind that at these speeds, rake would be measured in 10ths of a degree or maybe even less. If that was the case, the stabilator AoA is reduced, which increases the boats pitch. Using the video linked at the end, this is what can be observed:
At 0:17.0 secs in the video, AM is rounding the mark in a stable state
At 18.0s, AM has begun to heel a fair bit, but flying with quite a level pitch, only slightly higher.
19.0s, rudder is well immersed, and despite the heel, still looks reasonably stable... but from here things rapidly deteriorate
19.5s pitch has suddenly started to increase, while rudder still well immersed
20.0s AM is bearing away and flying higher, but approx 0.5m of the rudder is still immersed. From here, note the height of the boat, using the leeward foil as a reference
For reference, the entire rudder can be compared using the logo on it, which appears to indicate that the stabilator is still low enough to assert control. Despite the angle, it is still roughly proportional.
20.7s Control is lost. Pitch is now rapidly increasing, height is roughly the same judging by the lee foil, and the stabilator should still have authority
21.0s Sky bound and beyond recovery
21.5s
22.8 Apogee... just before AM crashes back down
Although at high speed through this maneuver and a high degree of heel, at 19s the boat still looks like it has longitudinal stability. Within a second, control is lost, the boat's pitch becomes unrecoverable, and the rest is history.
If pitch had been controlled, AM may well have made it through the bear away.
Or perhaps not... there could have been other contributory factors that haven't been taken into consideration?
Reference video: The Capsize of American Magic - YouTube
Ok, fair.play. I understand that.  We are talking about two moments in time several seconds apart... When they first ease the main, put traveler down and it first hits the backstay, they are accelerating during the bear away.  They hadn't yet lost the rudder...
Why did they put trav down and dump the main? If they weren't trying to dump power during the acceleration.
If they didn't want to dump power, then they messed up their trim settings.... again, this is all before they lost the rudder.
Easing the traveler and the main causes the boat to bear away with minimal rudder input.
Once pointed more than 90 degrees true, sheeting in the main causes it to de-power.
2 hours ago, Chimp too said:
Neverwas,
From the long angle you can see a clear circle around the foil arm, they're lucky the hole arm didnt come off!
The fuck does “first to do it” have to do with performance? Goodie is one of the most talented 3 foiling helmsman on earth yet the aged guy who has never won a foiling event as a helmsman is driving.
  • Like 5
And Goodie is a Brit. So bound to be better than a Kiwi.
Obvs
<exits room, whistling softly>
