mundt 208 Posted April 28, 2019 Share Posted April 28, 2019 Newly acquired nacra, foils have lots of little chips in the trailing edges. I'm cleaning them up and repairing but the question is how to finish the trailing edge, I seem to recall that the correct shape is a slightly assymetrical squared -off shape rather than sharp. Thoughts? Thanks. Quote Link to post Share on other sites
boardhead 213 Posted April 28, 2019 Share Posted April 28, 2019 That’s what I understood makes for silent/no vibration merging of the flow as the two tiny vortices overlap. Sharp is quiet but tough to maintain. On bigger foils I like to fully tape the trailing edge for a proper structural and waterproof closure which inevitably makes for a somewhat fat exit then I add a sacrificial, thickened resin, knife edge (read 1/32” rad) trailing edge. Quote Link to post Share on other sites
mundt 208 Posted April 28, 2019 Author Share Posted April 28, 2019 Thanks, as you said the taped edge is ideal but too fat for smaller foils. I'm gonna try thickened, toughened West system. Quote Link to post Share on other sites
dacarls 11 Posted April 28, 2019 Share Posted April 28, 2019 When you get really going fast, the humming is not your friend. Getting as close as possible to 1/32 radius sounds about right. Quote Link to post Share on other sites
KONeill 57 Posted April 29, 2019 Share Posted April 29, 2019 When I raced H16s many years ago the fast guys all had squared-off trailing edges on their rudders. Maybe about 1/16" or so across, maybe a bit less. No hum at all, the water broke clean off the trailing edge. You don't want a round trailing edge, it will hum and slow you down a tiny bit. If you're not racing the humming is still irritating. Quote Link to post Share on other sites
martin 'hoff 741 Posted April 29, 2019 Share Posted April 29, 2019 On 4/27/2019 at 9:53 PM, boardhead said: That’s what I understood makes for silent/no vibration merging of the flow as the two tiny vortices overlap. Sharp is quiet but tough to maintain. On bigger foils I like to fully tape the trailing edge for a proper structural and waterproof closure which inevitably makes for a somewhat fat exit then I add a sacrificial, thickened resin, knife edge (read 1/32” rad) trailing edge. Can you describe this a bit more? I might try on my recreational foiler. We're starting to find its limits in speed and handling, and I think drag on the rudders is a big factor. Quote Link to post Share on other sites
bacq2bacq 243 Posted April 29, 2019 Share Posted April 29, 2019 Apparently, not the first time this has come up here: Quote Link to post Share on other sites
F18 Sailor 288 Posted April 30, 2019 Share Posted April 30, 2019 On 4/27/2019 at 8:27 PM, mundt said: Newly acquired nacra, foils have lots of little chips in the trailing edges. I'm cleaning them up and repairing but the question is how to finish the trailing edge, I seem to recall that the correct shape is a slightly assymetrical squared -off shape rather than sharp. Thoughts? Thanks. Tricks of the trade: 1) Use toughened epoxy mixed THICKER than peanut butter consistency to fill the nicks 2) Bad nicks need to be filled with carbon, see Goodall website for a youtube video on the process 3) Older Nacra boards are gelcoat at the trailing edge so chip in about 3 seconds when stared at wrong. I don't bother re-filling with gelcoat, its easier just to fill with epoxy and call it a day. 4) When using the epoxy, I take clear packaging tape, rip a small piece off and put that down against the tape then wrap that around the board trailing edge. If you can then get some wood across both sides can clamp you'll have a perfect repair with very little sanding. Use less epoxy than you think. Boards make noise for more than just the trailing edge, yes thinner is better but its hard to get them thin enough and keep them in one piece. Specifically the area at the back of the board with them all the way down I wouldn't worry too much about, better to be too thick there. The other reason for board noise/vibration is vertical scratches, those need to be removed and that is A LOT of work to clean up. 2 Quote Link to post Share on other sites
mundt 208 Posted April 30, 2019 Author Share Posted April 30, 2019 My daggers have lots of stress cracks in the gelcoat. Are they bout to break? Should I grind off the gel and add a layer of carbon or just sail? Quote Link to post Share on other sites
F18 Sailor 288 Posted April 30, 2019 Share Posted April 30, 2019 Go sailing. I just ground into a stress crack on a rudder built in the same manner, right where it leaves the casting. The underlying laminate was intact. Sure I reinforced it with carbon as that+paint is smarter than gelcoat, but it was fine as-is and I suspect your boards are too. Does anyone have a good paint that can take flex in very highly loaded areas (t-foils on rudders)? I'm thinking Durepox as that is what the Moth guys use but something compatible with the Awlgrip/craft system would be nice. 1 Quote Link to post Share on other sites
mundt 208 Posted April 30, 2019 Author Share Posted April 30, 2019 thanks, I agree that if they aint broke yet the core is probably pretty strong but it's still tempting to add carbon wherever one sees signs of stress, including my frontal lobes... Quote Link to post Share on other sites
Waynemarlow 130 Posted April 30, 2019 Share Posted April 30, 2019 1 hour ago, samc99us said: Does anyone have a good paint that can take flex in very highly loaded areas (t-foils on rudders)? I'm thinking Durepox as that is what the Moth guys use but something compatible with the Awlgrip/craft system would be nice. Far cheaper and with all the benefits of flexible paint, think of what your car paint sprayer uses on plastic bumpers and trims, do you ever see cracks or paint peeling, nope. I've used 2K Acrylic automotive paint now for over 10 years and the benefits are huge, never discolours, never needs polishing like gelcoat, quite tough ( not as good as gelcoat ), easy to repair, flexible, bonds really well and if you use 2K easy sand primer it all even get easier and less expensive to build and repair. Quote Link to post Share on other sites
wlrottge 22 Posted April 30, 2019 Share Posted April 30, 2019 6 hours ago, samc99us said: I'm thinking Durepox as that is what the Moth guys use but something compatible with the Awlgrip/craft system would be nice. I know Lars has gone through a variety of products and Durepox was one of them (he finished my T rudders with it and they were NICE). I'd use that since you probably want to wet sand it instead of a glossy finish. Quote Link to post Share on other sites
martin 'hoff 741 Posted April 30, 2019 Share Posted April 30, 2019 9 hours ago, samc99us said: The other reason for board noise/vibration is vertical scratches ...yet, you get them back as every board up/down rubs them :-/ Quote Link to post Share on other sites
F18 Sailor 288 Posted May 1, 2019 Share Posted May 1, 2019 Not if the trunks are properly sorted.... Copy that gents. We shot 2K automotive paint on a set of boards and it worked pretty darn well, so I may go that route in the future. 1 Quote Link to post Share on other sites
martin 'hoff 741 Posted May 1, 2019 Share Posted May 1, 2019 1 hour ago, samc99us said: Not if the trunks are properly sorted.... Easier said than done. And how do you keep the sand out? Quote Link to post Share on other sites
F18 Sailor 288 Posted May 1, 2019 Share Posted May 1, 2019 Don't use carpet in the trunks...yes I know its easier said than done, 4 hours of filing later... 1 Quote Link to post Share on other sites
martin 'hoff 741 Posted May 3, 2019 Share Posted May 3, 2019 On 5/1/2019 at 3:33 PM, samc99us said: Don't use carpet in the trunks...yes I know its easier said than done, 4 hours of filing later... I def don't have carpet. Foil trunks have a big HDPE piece with the foil profile cut through. Minimal slop to allow for rake adj (top HDPE piece slides fwd and back) but tight otherwise. We're in Miami and launch from a beach so there's always some sand. Foils are bottom insert, which adds to the complications. Quote Link to post Share on other sites
F18 Sailor 288 Posted May 3, 2019 Share Posted May 3, 2019 Yeah, that is a tough situation, with no great solution but launch in downwind or reaching conditions until you can clear the sand from the board area. Quote Link to post Share on other sites
bacq2bacq 243 Posted May 6, 2019 Share Posted May 6, 2019 [Corsair F-31, aftermarket CCI/Phil's foils high-aspect dagger, rest of the boat mostly stock] I've got some slop between the daggerboard case and the foil. I was thinking of procuring a big 4x8' sheet of thin HDPE and fully lining the slot, then if needed, shim it from behind to both tighten things up (stop side/side clunk) and get smoother up/down (cocked board binds slightly glass-on-glass when under load). Any advice/guidance/reminders? Does anything stick to HDPE if one wanted to bond to it? Cheers, ben Quote Link to post Share on other sites
