Mozzy Sails 951 Posted March 24, 2021 Share Posted March 24, 2021 You talking at hydraulic pressure versus surface pressure? I think they will have sensors for flap rotation a several points along the foil. Then probably some fibre optics giving wing deflection. Nathan said in that interview about measuring when the load was zero, to raise the foil. I guess you could use pressure on either surface or the deflection of the span... but probably just a load cell within the arm would be the most direct way. Quote Link to post Share on other sites
The Advocate 279 Posted March 24, 2021 Share Posted March 24, 2021 29 minutes ago, MaxHugen said: OK, you're talking about the hydraulic pressure for the flaps, sure, that would be up in the boat. I was referring to the water pressure over the foil wings. I doubt they measure that during racing. Quote Link to post Share on other sites
The Advocate 279 Posted March 24, 2021 Share Posted March 24, 2021 31 minutes ago, Mozzy Sails said: You talking at hydraulic pressure versus surface pressure? I think they will have sensors for flap rotation a several points along the foil. Then probably some fibre optics giving wing deflection. Nathan said in that interview about measuring when the load was zero, to raise the foil. I guess you could use pressure on either surface or the deflection of the span... but probably just a load cell within the arm would be the most direct way. Was unclear what Max was referring to initially. Why would they measure deflection during racing? Testing possibly. Which Nathan? If it is the parameter I think is being referred to, that would also be measured inside the boat. Quote Link to post Share on other sites
The Advocate 279 Posted March 24, 2021 Share Posted March 24, 2021 41 minutes ago, The Advocate said: 1 hour ago, MaxHugen said: OK, you're talking about the hydraulic pressure for the flaps, sure, that would be up in the boat. I was referring to the water pressure over the foil wings. I doubt they measure that during racing. Actually, we need to be less obscure with what we are discussing to add value to this discussion. Quote Link to post Share on other sites
Mozzy Sails 951 Posted March 24, 2021 Share Posted March 24, 2021 1 hour ago, The Advocate said: Was unclear what Max was referring to initially. Why would they measure deflection during racing? Testing possibly. Which Nathan? If it is the parameter I think is being referred to, that would also be measured inside the boat. I'm not sure what you would do with deflection along the wing during racing. But, I think it could be very useful for post sailing analysis. And if they're using fibre optics or something similar then it will be baked in to the foil. They're so light and low volume that I can't imagine you'd gain anything from having them be removable (even if it could be done non-destructively). Nathan Outteridge in his interview on PlanetSail. He was talking about making sure the foil was neutral (i.e no lifts or sucking down) before trying to raise it, to make a smooth lift. Quote Link to post Share on other sites
Basiliscus 615 Posted March 24, 2021 Share Posted March 24, 2021 12 hours ago, MaxHugen said: Rhino at USD 995 is way way beyond my budget, but I'll scout around for an alternative CAD app that can maybe do the same. Thanks for outlining the procedure. The important thing is not Rhino itself, but the workflow. I think just about any CAD package would have similar capabilities. You might look into Fusion360 fro Autodesk. It has a free version. 2 Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 24, 2021 Share Posted March 24, 2021 10 minutes ago, Basiliscus said: The important thing is not Rhino itself, but the workflow. I think just about any CAD package would have similar capabilities. You might look into Fusion360 fro Autodesk. It has a free version. Thanks, trying to do just that with FreeCAD, but it's a bit of a struggle at the moment. I shall persevere. Quote Link to post Share on other sites
The Advocate 279 Posted March 24, 2021 Share Posted March 24, 2021 6 hours ago, Mozzy Sails said: I'm not sure what you would do with deflection along the wing during racing. But, I think it could be very useful for post sailing analysis. And if they're using fibre optics or something similar then it will be baked in to the foil. They're so light and low volume that I can't imagine you'd gain anything from having them be removable (even if it could be done non-destructively). Nathan Outteridge in his interview on PlanetSail. He was talking about making sure the foil was neutral (i.e no lifts or sucking down) before trying to raise it, to make a smooth lift. Yes they could defiantly have some thin film tech or something like that I guess.. Sounds like NO is taking about tacking. Quote Link to post Share on other sites
erdb 550 Posted March 24, 2021 Share Posted March 24, 2021 Hey @MaxHugen and @Basiliscus , check out ImageJ - a free image analysis software developed at the NIH. It has a line graph analysis tool that does exactly what you want. Long long time ago, I used it to digitalize paper recordings from physiology experiments. Just tested it in the current version and it works like a charm. Converts a line drawing straight into a csv file or copy to excel. You will have to do the top and the bottom separately, because it's looking for a line graph, you can't have two Y values for the same X. Download Fiji (Fiji is just ImageJ - literally ), it has all the plugins already packaged in the download file: https://imagej.net/Fiji/Downloads Follow instructions under Analyze Line Graph: https://imagej.nih.gov/ij/docs/menus/analyze.html#graph 3 Quote Link to post Share on other sites
Kiwing 509 Posted March 24, 2021 Share Posted March 24, 2021 This thread is amazing! While I don't contribute I still read avidly, not always following, until maybe a few days and bouncing around I catch up with the over all ideas. Thank you all for your contributions! 3 Quote Link to post Share on other sites
Basiliscus 615 Posted March 25, 2021 Share Posted March 25, 2021 3 hours ago, erdb said: Hey @MaxHugen and @Basiliscus , check out ImageJ - a free image analysis software developed at the NIH. ... Thanks for the tip - I installed Fiji. The thresholding tool is very powerful. However, I think it may be expecting a cleaner image than is often the case. This drawing is not AC or hydrofoil related, but it is typical of the kinds of things I'd like to convert to CAD. I'll play around with it some more, and actually import something into CAD to see how that works. 1 Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 25, 2021 Share Posted March 25, 2021 5 hours ago, erdb said: Hey @MaxHugen and @Basiliscus , check out ImageJ - a free image analysis software developed at the NIH. It has a line graph analysis tool that does exactly what you want. Long long time ago, I used it to digitalize paper recordings from physiology experiments. Just tested it in the current version and it works like a charm. Converts a line drawing straight into a csv file or copy to excel. You will have to do the top and the bottom separately, because it's looking for a line graph, you can't have two Y values for the same X. Download Fiji (Fiji is just ImageJ - literally ), it has all the plugins already packaged in the download file: https://imagej.net/Fiji/Downloads Follow instructions under Analyze Line Graph: https://imagej.nih.gov/ij/docs/menus/analyze.html#graph Thanks erdb, I'll check it out! Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 25, 2021 Share Posted March 25, 2021 2 hours ago, Basiliscus said: Thanks for the tip - I installed Fiji. The thresholding tool is very powerful. However, I think it may be expecting a cleaner image than is often the case. This drawing is not AC or hydrofoil related, but it is typical of the kinds of things I'd like to convert to CAD. I'll play around with it some more, and actually import something into CAD to see how that works. That's a pretty hefty looking profile, what is it for? Quote Link to post Share on other sites
Basiliscus 615 Posted March 25, 2021 Share Posted March 25, 2021 20 minutes ago, MaxHugen said: That's a pretty hefty looking profile, what is it for? SM.55. I'm working on the design of a 1/12 scale model. Quote Link to post Share on other sites
Kiwing 509 Posted March 25, 2021 Share Posted March 25, 2021 One of these? 1 Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 25, 2021 Share Posted March 25, 2021 2 hours ago, Basiliscus said: SM.55. I'm working on the design of a 1/12 scale model. Cool! First searches produced "sand mixers"... Quote Link to post Share on other sites
strider470 2,142 Posted March 25, 2021 Share Posted March 25, 2021 9 hours ago, Kiwing said: This thread is amazing! While I don't contribute I still read avidly, not always following, until maybe a few days and bouncing around I catch up with the over all ideas. Thank you all for your contributions! I totally agree. Thanks guys! Quote Link to post Share on other sites
Xlot 1,162 Posted March 25, 2021 Share Posted March 25, 2021 13 hours ago, Basiliscus said: SM.55. I'm working on the design of a 1/12 scale model. You might then want to check against the real thing - in the Italian Air Force’s excellent museum in Vigna di Valle, near Rome I saw the only other surviving plane in the Bandeirantes Museum, São Paulo Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 25, 2021 Share Posted March 25, 2021 16 hours ago, Basiliscus said: Thanks for the tip - I installed Fiji. The thresholding tool is very powerful. However, I think it may be expecting a cleaner image than is often the case. This drawing is not AC or hydrofoil related, but it is typical of the kinds of things I'd like to convert to CAD. I'll play around with it some more, and actually import something into CAD to see how that works. I created a foil profile from this img in XFLR5, although I did not tidy it up using inverse design: SM.55.dat Quote Link to post Share on other sites
erdb 550 Posted March 25, 2021 Share Posted March 25, 2021 18 hours ago, Basiliscus said: Thanks for the tip - I installed Fiji. The thresholding tool is very powerful. However, I think it may be expecting a cleaner image than is often the case. This drawing is not AC or hydrofoil related, but it is typical of the kinds of things I'd like to convert to CAD. I'll play around with it some more, and actually import something into CAD to see how that works. There is another plugin: https://lukemiller.org/index.php/2011/09/digitizing-data-from-old-figures-with-imagej/ With this, you have to click on data points you want to save, so you're back to manual drawing, but the nice thing is you can calibrate your image to export coordinates in the 0 - 1 range right away. Cool project BTW! Quote Link to post Share on other sites
Kiwing 509 Posted March 25, 2021 Share Posted March 25, 2021 Wow who needs the AC? Quote Link to post Share on other sites
Stingray~ 2,259 Posted March 25, 2021 Share Posted March 25, 2021 Apologies for a hopefully brief interruption, but since this great thread is so active I will post the Q here: How do you navigate to Private Messages, in this new format please? My ‘theme’ : Quote Link to post Share on other sites
jaysper 1,264 Posted March 25, 2021 Share Posted March 25, 2021 24 minutes ago, Stingray~ said: Apologies for a hopefully brief interruption, but since this great thread is so active I will post the Q here: How do you navigate to Private Messages, in this new format please? My ‘theme’ : I get the same on my android phone and haven't been able to find away. Strangely it works on my android tablet as well as my windblows laptop. Quote Link to post Share on other sites
Rennmaus 3,060 Posted March 25, 2021 Share Posted March 25, 2021 31 minutes ago, Stingray~ said: Apologies for a hopefully brief interruption, but since this great thread is so active I will post the Q here: How do you navigate to Private Messages, in this new format please? My ‘theme’ : 6 minutes ago, jaysper said: I get the same on my android phone and haven't been able to find away. Strangely it works on my android tablet as well as my windblows laptop. Scroll to the very bottom of the page, click "Themes", choose "IPS default", scroll back to the top, click the sandwich and look at the right upper corner. There you'll find the envelope. 4 Quote Link to post Share on other sites
jaysper 1,264 Posted March 25, 2021 Share Posted March 25, 2021 7 minutes ago, Rennmaus said: Scroll to the very bottom of the page, click "Themes", choose "IPS default", scroll back to the top, click the sandwich and look at the right upper corner. There you'll find the envelope. Awesome! Works perfectly. Thanks Rennie! Quote Link to post Share on other sites
Stingray~ 2,259 Posted March 25, 2021 Share Posted March 25, 2021 1 hour ago, jaysper said: Awesome! Works perfectly. Thanks Rennie! +1! Glad to have found the PM, from one of the great denizens in this thread. Thanks, Rennie. Quote Link to post Share on other sites
Basiliscus 615 Posted March 26, 2021 Share Posted March 26, 2021 7 hours ago, Xlot said: You might then want to check against the real thing - in the Italian Air Force’s excellent museum in Vigna di Valle, near Rome I saw the only other surviving plane in the Bandeirantes Museum, São Paulo Yes, I found a good set of photos from the Brazilian plane taken when it was undergoing restoration. I thought it was the only intact surviving one. It's an M model and I'm going with the X model, but lots of good detail. That's probably enough of a digression from the AC. There's another forum where I'll be logging the build when I get going on it. Quote Link to post Share on other sites
Basiliscus 615 Posted March 26, 2021 Share Posted March 26, 2021 7 hours ago, MaxHugen said: I created a foil profile from this img in XFLR5, although I did not tidy it up using inverse design: SM.55.dat 5.38 kB · 1 download Thanks. I'll take a look at it. I've already extracted some section shapes from that and other drawings, and slightly modified them to be suitable for model Reynolds numbers. Quote Link to post Share on other sites
Basiliscus 615 Posted March 26, 2021 Share Posted March 26, 2021 5 hours ago, erdb said: There is another plugin: https://lukemiller.org/index.php/2011/09/digitizing-data-from-old-figures-with-imagej/ With this, you have to click on data points you want to save, so you're back to manual drawing, but the nice thing is you can calibrate your image to export coordinates in the 0 - 1 range right away. Cool project BTW! Thanks. It's sounding like ImageJ could be another hobby all in itself. 1 Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 26, 2021 Share Posted March 26, 2021 4 hours ago, Rennmaus said: Scroll to the very bottom of the page, click "Themes", choose "IPS default", scroll back to the top, click the sandwich and look at the right upper corner. There you'll find the envelope. Thanks Renni! Thought it was me going senile, after searching every corner of the forum for that link to PMs. Quote Link to post Share on other sites
Xlot 1,162 Posted March 26, 2021 Share Posted March 26, 2021 From Max, sequential logic related to small T- foils: - T-foils work only if they are small - but then to facilitate take-off, you need to give down rudder for a moment - the bow goes down, and take-off happens on the rebound - as a consequence, bow volumes are not ideal for other aspects Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 26, 2021 Share Posted March 26, 2021 1 hour ago, Xlot said: From Max, sequential logic related to small T- foils: - T-foils work only if they are small - but then to facilitate take-off, you need to give down rudder for a moment - the bow goes down, and take-off happens on the rebound - as a consequence, bow volumes are not ideal for other aspects Interesting, except there was an excellent side-on video of NZ's take-off, which clearly showed that they maintained a very level pitch throughout the maneuver. It would seem that the foil AoI of 2° (my estimate) plus flap angle were quite sufficient to get NZ foiling. Note that at 0° pitch, NZ's canoe shaped bustle presents a minimal wetted area, and with less total drag, would enable NZ to get onto the foils no slower than any other team. IMO. As to why "T-foils work only if they are small"... that claim has me stumped. Quote Link to post Share on other sites
erdb 550 Posted March 26, 2021 Share Posted March 26, 2021 47 minutes ago, MaxHugen said: As to why "T-foils work only if they are small"... that claim has me stumped. I think it's reversed. If you want small foils, you have to go with T foils. Quote Link to post Share on other sites
sfigone 391 Posted March 26, 2021 Share Posted March 26, 2021 So what would happen if for the next AC the boat was entirely open? No class rules are all! Would the boats that turned up all be pretty much AC75 anyway? There are boats that would beat them in a straight line, but not around a W/L course and not even they have to match race and win starts. I'm not sure a bigger boat would go much faster as these boats are at cavitation limits anyway. The costs would probably astronomical, but the results would be interesting. Quote Link to post Share on other sites
jaysper 1,264 Posted March 26, 2021 Share Posted March 26, 2021 5 minutes ago, sfigone said: Would the boats that turned up all be pretty much AC75 anyway? I doubt that. Firstly the sail plan would become open slather. You would have to assume that at least one of the teams would consider different foils for up and down wind - and yes that would mean some mechanism for switching which foil gets submerged. The grinders would be replaced by batteries or an engine. Pumped ballast would become a consideration. The foil trim would be fully automated with a complete set of sensors to optimise this. Plus whole bunch of other crap that I can't think of right now. Quote Link to post Share on other sites
gigi 6 Posted March 27, 2021 Share Posted March 27, 2021 On 3/24/2021 at 9:38 AM, MaxHugen said: Do you know of any way to convert SVG to coords, or a different spline-based app that can export to x-y coords? There is litle program caled CONCORD. Stands for Coordinate- convertter, it is tool for airfoils. If Ibremember it can do dxf, this shoud be close enough. On javafoil website. Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 27, 2021 Share Posted March 27, 2021 1 hour ago, gigi said: There is litle program caled CONCORD. Stands for Coordinate- convertter, it is tool for airfoils. If Ibremember it can do dxf, this shoud be close enough. On javafoil website. Thanks Gigi. This appeared to be a very handy tool: However, it was written a couple of decades ago, and it can't read newer CAD file formats such as AutoCAD R12 or R14. These are the options I have of saving an Inkscape SVG file as a DXF file, from which I'd hoped to convert to a 2 column DAT file. Still, it might be useful for some other members here? Quote Link to post Share on other sites
coercivity 6 Posted March 28, 2021 Share Posted March 28, 2021 One of the issues with the current design is their rather poor or have tricky performance in the marginal light conditions. I think they could have an out board only foil above the current foil that would lift the boat at a lower speed say at 10knts once the wetted area declines and the speed builds it would rise above the surface sort of a ladder foil from old. the benefit would be smaller main foils possibly and much less foil fall of angst. The light wind sailing was great but marred by some wind holes that reversed entire races in what was a bit silly at times. ETNZ had smaller foils it was an advantage at bigger speeds probably optimized to 30knts if they were 10% smaller and the outboard foil was say 50% of the full area but built for 15knts for max lift these boats would engage more in the starter area and would be game to go slow as a tactic. luffing, or daring a hook it would be fun and light winds with patchy air did extract a good sailing race. 1 Quote Link to post Share on other sites
Amati 1,847 Posted March 28, 2021 Share Posted March 28, 2021 46 minutes ago, coercivity said: One of the issues with the current design is their rather poor or have tricky performance in the marginal light conditions. I think they could have an out board only foil above the current foil that would lift the boat at a lower speed say at 10knts once the wetted area declines and the speed builds it would rise above the surface sort of a ladder foil from old. the benefit would be smaller main foils possibly and much less foil fall of angst. The light wind sailing was great but marred by some wind holes that reversed entire races in what was a bit silly at times. ETNZ had smaller foils it was an advantage at bigger speeds probably optimized to 30knts if they were 10% smaller and the outboard foil was say 50% of the full area but built for 15knts for max lift these boats would engage more in the starter area and would be game to go slow as a tactic. luffing, or daring a hook it would be fun and light winds with patchy air did extract a good sailing race. I was talking to a Bell at a pre COVID wedding ( yes, that Bell family, as in Alexander Graham ) who was intrigued with ladder foils, to the point of designing and having some built and tested, and while they did offer lift in lower wind speeds, he felt drag was a penalty, kind of like Willawaw experienced in lighter wind. Whether that regime lift was more than Archimedes regime hull drag, friction and wave, he wasn’t sure. Surface tension entered into things, IIRR. We got into that during the reception, so you’ll forgive a suspect recollection. 1 Quote Link to post Share on other sites
Tornado-Cat 1,082 Posted March 28, 2021 Author Share Posted March 28, 2021 On 3/15/2021 at 12:18 AM, Tornado-Cat said: TNZ - My first meeting with TNZ was in 2009 - I begain to work in 2010 - I have aneye on everyting on the boat but works part time because busy on other projects - I give ideas but it’s a lot of work, you have to develop it each idea - I like a small team because it’s efficient, we are even too many, lots of people coding, too many, we have to keep a global vision AC75 - One day day Ray Davis asks me to meet Howard Spencer, willing to get a fun 40 ft. - I design a foiling mono - Ray says that the keel is too much - I tell him it’s possible, however we need stability - I remember that a french architect, Martin Defline has made two queels boats who are pretty efficient, so we can do the same thing with ballast at the end of the foil - It’s counter intuitive to put weight where we want a lift but calcules show it is 50% more efficient that with the keel for the same mass. - The project doesn’t work as too expensive - The Italians want a big mono for AC36, we could have a had a smaller boat for economic reasons - Ray Davies puts my drawing on the table, everybody laugh. He tells us: I give you one month to test the concept to test If it works in a simulator. I was not there, I did not test, Bobby tested the design and they said it was a fun concept and it works - They tried other concepts but came back to the initial one AC75 rule - I was willing two rudder foils for better stability to avoid diagonal heel instability like the hydrotère. - I was against it but we went to one rudder for a good reason: to avoid cutting a crew falling in the water. That is also why the rules prevent going on the bow. - I did not write the rule, Dan Bernasconi did it, I gave my advices. - We chose a close rule to avoid mistakes, it took us a year - We were very reassured to see that the british model worked, simulation works but is not always reassuring. - We surely took some advance compared to the other teams but I don’t think it was so much - Once I chose a concept I like to push it to the end. - We got symetric foils at the end only in order to learn as much as possible - The bulb at the end of the foil arm is just to put ballast, it has nothing to do with hydro but with the rule Our AC75 - We are given a rule that I hate, the inertial stability in the harbour that imposes a wide flotation beam - I understand it but it was not required with the ballasted foils in the water, we did not need that. 10’17 - I understood that it was obvious that we have to make a central tube like a trimaran hull and a wide ass for the rule and stability, I don’t think other teams understood it right away: narrow hull and wide as far on the back as possible. - So we have a narrow hull in the front like a trimaran and a wide ass for static stability in the harbour. - Not a big evolution between B1 and B2, B2 is even more like a multi - We want a boat easy to foil that lift the stern first and get early on the foils for lower drag asap - The brits were capsizing when bearing away as they could not get enough lift from the foil vs the pressure. They were afraid of the transition and they were right to have a first boat with more stability. - B1 was an hydro dynamic concept, B2 an aero + hydro The foil - The dihedral is more equlibrated and does not require a big “shaft” that maintain the foil and which creates drag - On the other hand a flat design is simpler and has lower drag. Both concepts are good. B I did not have time to finish the translation, here it is, really worth reading it. Link: https://voilesetvoiliers.ouest-france.fr/regate/coupe-de-l-america/america-s-cup-guillaume-verdier-du-vendee-globe-a-la-coupe-de-l-america-sur-tous-les-fronts-16505d9a-7daf-11eb-a530-8257a05e6295?fbclid=IwAR1NxsAj3wAuWdzn6_P7iVTxshZyq76ZeZcZfnogKPj0O9F0JBzZQrROne8 What the secret of TNZ success - When I begun in 2010 what really asthonished me was the horizontal organization, people can speak, there is no real boss. It has advantages but it can be the mess sometimes too, nobody is responsible of anything and everybody responsible for everyting. It works with a small structure, it is not a pyramidal but horizontal structure. - The is no restriction to possibility to speak, sailors are integrated to the design team. They often take the decision. They are part of the design meetings. - When we decide the piece to design we give ourself a time table and we don’t come back on our decision, we finish the construction as decided. In other places people sometimes come back on their decisions and want modification before finish which causes further delays, not here. - We don’t subcontract the construction of the boat, it’s integrated in the team to we control it directly The simulator - The simulator took less place that in the previous edition - We did less design on the simulator than the last time, we did more fondamental design - We modified the simulator - Some speak about artificial intelligence, in fact it’s not ture it’s everything but intelligent and very artificial. However we have many persons working on scripts in order to automatize the calcules - We use the artificial intelligence for foil profile. We give an objective of lift on a section of the foil, or an objective of ratio of lift vs drag + a few variables. We let the computer work all night, it will draw a part of the section. Then the computer tells what section is best when we give it a criteria. So in fact the machine does what we ask it but if we think well ourself we can do the same. We have to think and not let the machines do stupidly any objective or it can be very dangerous How do you find your ideas? - We learn the different knoledge in different fields like paragliders who need loft of lift or wing profile of aerobatic plane who need a lot of tolerance to the requirements. - We mix all that, we have to look at what is done in other fields of aerodynamics. We are lucky as we can find everything on the net now, NASA studies, European Space Agency. - Everything is here and for free. When I remember that when I began to work I had to go and try to buy some book in bookstores. We can even fin Excel sheets with lift/drag, cavitation calcules. All students work on that in all universities Is there a Verdier method ? - No, I work from home, we are a group of architect working from home, the lock down had had no impact. I don’t like working in an office with people around, I prefer working alone. Do you have a way to approach a project ? - Yes, but I can’t tell it is the good one. When I am asked to work on a design I like to work on the full project and I have a feedback loop very quickly, I draw my design very quickly. In some other methods differents persons work on different bricks of the pyramid and it takes months. For me I draw the AC boat in 3 weeks, I judge it, I see the caveouts and do another loop immediately. I want to go quickly otherwise we spend too much time on a detail and another, and another, for me I want to work on the global vision and refine it at each loop. 4 Quote Link to post Share on other sites
MaxHugen 1,136 Posted March 28, 2021 Share Posted March 28, 2021 1 hour ago, coercivity said: One of the issues with the current design is their rather poor or have tricky performance in the marginal light conditions. I think they could have an out board only foil above the current foil that would lift the boat at a lower speed say at 10knts once the wetted area declines and the speed builds it would rise above the surface sort of a ladder foil from old. the benefit would be smaller main foils possibly and much less foil fall of angst. The light wind sailing was great but marred by some wind holes that reversed entire races in what was a bit silly at times. ETNZ had smaller foils it was an advantage at bigger speeds probably optimized to 30knts if they were 10% smaller and the outboard foil was say 50% of the full area but built for 15knts for max lift these boats would engage more in the starter area and would be game to go slow as a tactic. luffing, or daring a hook it would be fun and light winds with patchy air did extract a good sailing race. You may have noticed that NZ had no more issue getting onto the foil than other teams, despite their smaller foils. They had a slightly higher AoI, around 2°, compared to ~1.5 for Ineos and LR (IMO). No doubt they had to use more flap angle too. The problem is that more lift produces more drag. One part of the equation is acceleration, and the inertia from a mass of 7.8t plays a significant part. That's why a Moth can get on the foils at a much lower take-off speed. Quote Link to post Share on other sites
coercivity 6 Posted March 28, 2021 Share Posted March 28, 2021 yes but what about getting on and up quicker so you can slow the team behind into the entry or know that in a light patch you can stay up. they were very careful they had the the smallest jib possible for the high speed runs so the slow stuff was tricky Quote Link to post Share on other sites
coercivity 6 Posted March 30, 2021 Share Posted March 30, 2021 I think there were no teams that would not have welcomed an extra 100% foil lift at takeoff, all the racing would have been different. A high AoA smaller but upper foil would have allowed a much harsher approach to racing. We want aggressive competition not this pansy can't do a hook to risky in the lee BS we want passing upwind and being mowed down again downwind wild mode differences. We had a glimpse I want more. Sail changing, brood reaches at 50knts, dummy tacks all that stuff and more. To much paint drying for masses. Quote Link to post Share on other sites
TazLikesBoats 6 Posted April 17, 2021 Share Posted April 17, 2021 On 3/26/2021 at 4:13 PM, MaxHugen said: Interesting, except there was an excellent side-on video of NZ's take-off, which clearly showed that they maintained a very level pitch throughout the maneuver. It would seem that the foil AoI of 2° (my estimate) plus flap angle were quite sufficient to get NZ foiling. Note that at 0° pitch, NZ's canoe shaped bustle presents a minimal wetted area, and with less total drag, would enable NZ to get onto the foils no slower than any other team. IMO. As to why "T-foils work only if they are small"... that claim has me stumped. Looking at the videos and race data ETNZ looks flat pitch=0 for take off and then -2 to -4 when sailing. That seems to make sense. +2 to +4 AOA for take off plus tab would be sufficient. If its a cambered foil flying at -1 to -2 AOA can give a higher performance Cl/Cd than sailing at 0 or +2. Which video of the take off have you been looking at? There is a good capture of take off from ETNZ in the Finals Race 1. I want to look at the ride height data to confirm how long it actually takes for take off. Quote Link to post Share on other sites
TazLikesBoats 6 Posted April 17, 2021 Share Posted April 17, 2021 Hi @erdb or anyone else on this forum. Can you get me race data from the Finals R1 in a .csv file? I want to look at the take off in more details. Plus the downwind speed in the AC Finals is impressive compared to the Prada RR. in similar breeze (12-14kn) the downwind speed has gone from 37kn to 40-42kn downwind. That's a huge improvement. So I want to use the finals data to compare with my VPP. As for the boats working in a wider wind range. I wonder if allowing the foils AOA to be set at the beginning of the race day instead of being fixed when the measurement certificate is issued would allow tuning of the boat depending on the weather conditions. I.e. AOA=2 for wind speed above 12knots and increase for wind speed below below is my VPP models comparison of an AC50 to an AC75 in 16kn. big difference in upwind performance. Quote Link to post Share on other sites
MaxHugen 1,136 Posted April 17, 2021 Share Posted April 17, 2021 49 minutes ago, TazLikesBoats said: Looking at the videos and race data ETNZ looks flat pitch=0 for take off and then -2 to -4 when sailing. That seems to make sense. +2 to +4 AOA for take off plus tab would be sufficient. If its a cambered foil flying at -1 to -2 AOA can give a higher performance Cl/Cd than sailing at 0 or +2. Which video of the take off have you been looking at? There is a good capture of take off from ETNZ in the Finals Race 1. I want to look at the ride height data to confirm how long it actually takes for take off. I did see an excellent side-on video of TR taking off, I think not long after B2 was launched. It looked very level throughout. Can't find this video, but another forum member found this one: https://youtu.be/ccpq7MeoSFk. It's not entirely side-on though. TR foils at an average of -2° pitch, so I believe that the foil is at +2° Angle of Incidence. Once the boats are up to 30+ knots I think the foil AoA is very close to or at 0°, and only needs to use a small amount of flap angle to manage flight height. This is my estimation of an AC75 foil profile, which I use in XFoil. I set the flap hinge at 60% from LE. Quote Link to post Share on other sites
Rasputin22 3,483 Posted April 17, 2021 Share Posted April 17, 2021 On 3/24/2021 at 3:33 AM, The Advocate said: The program that Rhino was developed from (I think) was free and available last time I looked. Buggered if I can remember the name of it though, haven't had it on the last few laptops. Rhino3D was not developed from Freeship. If you can't afford Rhino at its price then you should take up crochet. Quote Link to post Share on other sites
TazLikesBoats 6 Posted April 18, 2021 Share Posted April 18, 2021 12 hours ago, MaxHugen said: I did see an excellent side-on video of TR taking off, I think not long after B2 was launched. It looked very level throughout. Can't find this video, but another forum member found this one: https://youtu.be/ccpq7MeoSFk. It's not entirely side-on though. TR foils at an average of -2° pitch, so I believe that the foil is at +2° Angle of Incidence. Once the boats are up to 30+ knots I think the foil AoA is very close to or at 0°, and only needs to use a small amount of flap angle to manage flight height. This is my estimation of an AC75 foil profile, which I use in XFoil. I set the flap hinge at 60% from LE. Good video. Agree with an angle of incline set around +2 degrees 1 Quote Link to post Share on other sites
Mikko Brummer 84 Posted April 21, 2021 Share Posted April 21, 2021 I added a simulation in Youtube about the bad air zone/wind shadow behind the AC 75: Upwind, there is not that much difference to the sub-wind speed case, even if the bad air zone is wider and lasts longer behind the boat. Downwind, however, the bad air zone is totally different: When foiling at several times the wind speed, the wind shadow is left in the wake as a persisting wind shift, extending nearly right behind the boat and for a long time. There is no effect to the side or to downwind of the boat, as would be in the case of a traditional yacht, sailing at sub-wind speeds. You cannot speak at all of a wind shadow in the traditional meaning. In both cases, the influence of the bad air on the wind speed is small, while the influence of the direction of the wind is significant, nearly 30 degrees. The performance data courtesy of AC36 telemetry https://ac36.herokuapp.com/map. The simulation was performed by WB-Sails on Dassault Systèmes XFlow XFlow | High Fidelity CFD - Dassault Systèmes® https://www.3ds.com/products-services/simulia/products/xflow/. Comments/critics/interpretations/explanations are most welcome :-) 6 Quote Link to post Share on other sites
Zaal 694 Posted July 21, 2021 Share Posted July 21, 2021 https://sumtozero.com/about-2/ Really interesting to see that rather than using the same simulation / CFD firm, ETNZ and LRPP actually founded it together, or something like it. 1 Quote Link to post Share on other sites
Zaal 694 Posted July 21, 2021 Share Posted July 21, 2021 1 hour ago, Zaal said: https://sumtozero.com/about-2/ Really interesting to see that rather than using the same simulation / CFD firm, ETNZ and LRPP actually founded it together, or something like it. Sorry to quote myself, maybe I got it wrong, maybe LR hired two of the founders, Mark de Gids and Davy Moyon, while Bernasconi and Jean Claude Monnin are ETNZ's. Anyway, I think this firm is "the" simulator everybody were talking about. If I remember correctly, ETNZ developed it for the 35th AC, along with some LR people (after LR retired). So maybe it's possible that they founded the company together. Anybody knows what happened ? Quote Link to post Share on other sites
Zaal 694 Posted July 21, 2021 Share Posted July 21, 2021 https://sumtozero.com/2021/02/gomboc-vs-gomboc/ 3 Quote Link to post Share on other sites
MaxHugen 1,136 Posted July 22, 2021 Share Posted July 22, 2021 14 hours ago, Zaal said: https://sumtozero.com/about-2/ Really interesting to see that rather than using the same simulation / CFD firm, ETNZ and LRPP actually founded it together, or something like it. Very cool software, I've asked SumToZero what they might charge an amateur hobbyist for access to Gomboc! 1 Quote Link to post Share on other sites
Lakrass 174 Posted August 13, 2021 Share Posted August 13, 2021 Interesting comments about early take off and cavitation, we are not done with foils development and we might see the result for the next AC cycle. And they admit taking some ideas from AC into Ultim. Wish we could have similar visit of an AC75 (which is highly unlikely to happen). 3 Quote Link to post Share on other sites
Sailbydate 3,604 Posted August 13, 2021 Share Posted August 13, 2021 3 hours ago, Lakrass said: Interesting comments about early take off and cavitation, we are not done with foils development and we might see the result for the next AC cycle. And they admit taking some ideas from AC into Ultim. Wish we could have similar visit of an AC75 (which is highly unlikely to happen). A very fran(c)k, Cammas. ;-) Quote Link to post Share on other sites
