Shroud diamond wire removal???
Anyone have any idea how this wire gets removed from the shroud? It doesn't slide at all thru the hole and the tip isn't removable as far as I can tell. Unless it's glued on somehow and polished smooth around it. You can see the difference in color between the tip and shroud tubing but otherwise it's very smooth around it and looks integral to the tubing. This is a corsair sprint 750 mast from 2006 and they are still using the same shrouds today.
Dave.
Looks like it is epoxied in....  If you are replacing the spreaders do to an unforeseen circumstance, I'd just replace the diamond wires too.  Throw it all away and start over....
1 hour ago, gbkersey said:
Dave.
IF it is epoxied in, then you can loosen it with a hot air gun.
