freewheelin 162 Posted November 26, 2019 Share Posted November 26, 2019 This is likely a dumb question, but I have foot pump fresh water in the head and galley (cold only). I want to replace the head faucet with a retractable hose shower head. Will any work, or do I need something particular to hold the pressure? Right now I have whale faucets, which are great because you can easily shut them off. Link to post Share on other sites
SloopJonB 12,558 Posted November 26, 2019 Share Posted November 26, 2019 A foot pumped cold shower? WTF? Heat a kettle on the stove and bathe with a washcloth. Link to post Share on other sites
SASSAFRASS 765 Posted November 26, 2019 Share Posted November 26, 2019 Unless you are a competitive clog dancer pressure shouldn't be a issue. Just get a boat one with the least flow restriction. Link to post Share on other sites
freewheelin 162 Posted November 26, 2019 Author Share Posted November 26, 2019 40 minutes ago, SASSAFRASS said: Unless you are a competitive clog dancer pressure shouldn't be a issue. Just get a boat one with the least flow restriction. great. thanks. I suppose "boat one" was the question, considering they look to be much more expensive than the plastic component home depot cheapos. such is boat ownership i guess. Link to post Share on other sites
SASSAFRASS 765 Posted November 26, 2019 Share Posted November 26, 2019 The house ones are fine but the flow will be restricted, you can pull the sediment screens out and it's better. Just make sure they are 3/8" or more all the way through. Some of them drop way down in size at the counter fitting. Link to post Share on other sites
toddster 922 Posted November 26, 2019 Share Posted November 26, 2019 I'm a little dubious about that solution as a shower - maybe test the system before installing it in your boat? Anyhow, I got all-plastic (non corroding) sink fixtures for galley and head from an RV parts web site. Much cheaper than "marine" sources. (They also have ready-made kits for external camper showers that seem like a dandy solution for the cockpit shower, but I haven't got around to that project yet. I'm not sure that the RV kits I've seen have water-tight doors.) Link to post Share on other sites
Archived
