varifold prop removal
anybody else have a varifold prop ?
I need to remove the prop and hub to change the cutlass bearing.  There are 2 set screws that keep the   metal pins  which holds the blades onto the hub.  These pins don't seem to want to come out...is there a trick, or is this just some corrosion that I need to removes and then just tap the pins out?
