How do use the Latitude and Longitude Plotting Interpolator?
So, looking at the chart that I just posted on my wall of my most recent bareboat charter, I see it has a "latitude and longitude plotting interpolator".  I've never used this, never came up in any navigation instruction, and google is providing little, unless you want to get into MatLab (not a MatLab guy).
We're talking paper charts, here, and I realize we're laying out some spherical on a 2D flat rectangular surface.  How would one use this?  Would you need to?
Thanks.
9 minutes ago, SemiSalt said:
The reason you need it is the distance associated with a degree of longitude depends on the latitude.
That part I understand.  I just don't know how to use the interpolator.
I would think it'd used in a similar way to the longitude scale on the celestial "Universal Plotting Sheets." Use dividers to move up the vertical axis an amount proportional to the latitude and strike a horizontal line. (or park your ruler there) Then, use that line as the longitude scale.  On the UPS, the bottom of the scale is 0° Latitude and the top is 70°... here, maybe it represents the latitude range of the chart?  Seems a little extreme?
"A latitude and longitude plotting interpolator serves as an aid in plotting geographic positions on Great Lakes polyconic charts at scales of 1:50,000 or smaller. The interpolator,  similar to the LORAN-C interpolator and others, is designed to compensate for the converging meridians on polyconic charts. A number of interpolators are available and the proper size should be selected for a given chart depending on the spacing of projection lines. One interpolator is required for each chart. For charts and insets at scales larger than 1:50,000, the convergence of meridians is small enough so that a subdivided plan border will suffice for plotting geographic positions. Interpolators will remain on the designated Great Lakes charts until the charts are reconstructed and converted to Mercator projections."
In English - the lines squish together too much on small scale charts because we used an inferior projection.
https://ocsdata.ncd.noaa.gov/mcs/02_ncm_vol1.pdf
