Freshening Up Interior Teak
Looking for best recommendations for freshening up interior teak... what's the best return on effort for a good cleaning and brightening?  Lots of products and opinions our there.  What does the world of SA think?
Is the current teak oiled or varnished? What do you mean by "freshening up"? Is it too dark? Is it dirty? Is it stained, scratched, or otherwise abused? Not enough to go on here...
Great questions. Currently, the teak is only oiled. No varnished. Not looking dark, just showing it's age with a few high traffic areas which are dirty/scuffed and a couple areas where past leaks/drips are showing streaking.
First you must clean the surface .... then apply oil
warm water ammonia mix .. gentle mix
very fine scotchbright ,  sponge and terry cloth towels
wipe down with thinner before coating
Remember to thin the oil before application .. perhaps ten percent ... to speed cure time of the oil .. oil dries very slowly
apply  the oil with a heavy coat ....then wipe  50 percent  of the oil off
use a lint free rags
many times two coats are needed
Wood oil  soaked rags will spontaneously combust
be alert ... drop soiled  rags in a metal bucket and get it out of the work space
I did the interior of a 43' that was all 35 year old oil - filthy but otherwise in good shape.
I used TSP in a spritzer. The old oil & grime literally ran out of the wood initially.
After cleaning mine pretty thoroughly, I used Watco Teak Oil. Very nice finish. I could have left it there, but I did a few coats of Minwax Wipe On Poly Gloss because I wanted to seal it. It has a nice satin finish.
