retroSail 8 Posted September 1, 2020 Share Posted September 1, 2020 Looking to make my row boat into a little sailing dinghy by outfitting it with a windsurfer sail on the bow. I have all the supplies to build a transom, rudder, and mast step. I'm wondering if this build will work if I don't have a daggerboard/keel. Just planning on using this thing for fun around the bay. Cheers Quote Link to post Share on other sites
thengling 105 Posted September 2, 2020 Share Posted September 2, 2020 Better keep the oars on board. Without a daggerboard, centreboard or leeboards, I'm thinking you'll get little more than a run, though I see the hull does have a bit of a keelson. A pair of leeboards might be simple to contrive. 2 Quote Link to post Share on other sites
Admiral Hornblower 219 Posted September 2, 2020 Share Posted September 2, 2020 it won't really sail without a some sort of board. A leeboard would be the simplest option. Quote Link to post Share on other sites
JBOATTROUBLEMAKER 38 Posted September 3, 2020 Share Posted September 3, 2020 On 9/1/2020 at 6:09 PM, retroSail said: Looking to make my row boat into a little sailing dinghy by outfitting it with a windsurfer sail on the bow. I have all the supplies to build a transom, rudder, and mast step. I'm wondering if this build will work if I don't have a daggerboard/keel. Just planning on using this thing for fun around the bay. Cheers Get an old set of 2 by 4s, some load bearing bolts, Bondo and a 505 rig. Retrofit the 505 rig with a mast head spinnaker and stay wings. Finish the job with trapeze wings and associated trapezes.... Peer pressure rules. 1 Quote Link to post Share on other sites
JBOATTROUBLEMAKER 38 Posted September 3, 2020 Share Posted September 3, 2020 Rename it "Lil Dripper". I apologize in advance. Quote Link to post Share on other sites
retroSail 8 Posted September 3, 2020 Author Share Posted September 3, 2020 1 hour ago, JBOATTROUBLEMAKER said: Rename it "Lil Dripper". I apologize in advance. Honestly not bad, the boat had a bad leak until last week when I did some glass work on it. Quote Link to post Share on other sites
Kenny Dumas 294 Posted September 3, 2020 Share Posted September 3, 2020 No fun without a board in the water. You’ll just drift down wind. Even with a board it would barely go up wind but would be fun on a reach 1 Quote Link to post Share on other sites
JBOATTROUBLEMAKER 38 Posted September 3, 2020 Share Posted September 3, 2020 1 hour ago, Kenny Dumas said: No fun without a board in the water. You’ll just drift down wind. Even with a board it would barely go up wind but would be fun on a reach Thats what the 2 by 4s are for (; Quote Link to post Share on other sites
Alan Crawford 280 Posted September 3, 2020 Share Posted September 3, 2020 @retroSail here's something similar to your idea. https://seattle.craigslist.org/sno/boa/d/camano-island-sailing-dinghy/7185421640.html 1 Quote Link to post Share on other sites
retroSail 8 Posted September 3, 2020 Author Share Posted September 3, 2020 So the boat has a slot on the bottom for a dagger board but the seat is covering the top of that slot. I'm not sure how I could get a board in there with out cutting the seat open. Quote Link to post Share on other sites
Grestone 34 Posted September 3, 2020 Share Posted September 3, 2020 23 minutes ago, Alan Crawford said: @retroSail here's something similar to your idea. https://seattle.craigslist.org/sno/boa/d/camano-island-sailing-dinghy/7185421640.html We calling that a 7' Trimaran? I love the ingenuity and back to topic, yeah, those leeboards will dramatically change how you can use that little rowboat. Quote Link to post Share on other sites
Grestone 34 Posted September 3, 2020 Share Posted September 3, 2020 2 minutes ago, retroSail said: So the boat has a slot on the bottom for a dagger board but the seat is covering the top of that slot. I'm not sure how I could get a board in there with out cutting the seat open. Personally, I would test your concept out without a central dagger (swing or slot) first by using leeboards. A dowel or board that spans across the gunwales with a simple mount on each side could let you fashion leeboards without cutting into your hull below waterline. I'd test that first and see if you like it. 1 Quote Link to post Share on other sites
Coquina012 51 Posted September 3, 2020 Share Posted September 3, 2020 Much easier to build a sailing skiff. Quote Link to post Share on other sites
retroSail 8 Posted September 3, 2020 Author Share Posted September 3, 2020 30 minutes ago, Coquina012 said: Much easier to build a sailing skiff. Do you have a free skiff to give me? Quote Link to post Share on other sites
Coquina012 51 Posted September 3, 2020 Share Posted September 3, 2020 Sort of. See below. It has the same problem as your boat, however, because it is a rowboat and not set up for sail. Your skill set may be either different or superior to mine, but I could retrofit a rowboat for sailing if it were wood, but I don't think I could if it were a glass rowboat. The above answers to your questions are either an indirect "no" or people joking around. The rowing skiff in the picture is somewhere around a 36" beam and would not sail well. Though some have done it. Quote Link to post Share on other sites
Coquina012 51 Posted September 3, 2020 Share Posted September 3, 2020 Woodenboat Magazine, some years ago had an interesting article about building a flat bottomed skiff by eye. The hull was a weekend build. Sailing bits would add significantly, but no different than what you propose. Although the below is a Virginia Deadrise, meaning V bottom, it follow the same logic. That is a rack of eye, no plans build, btw. 19'6". Quote Link to post Share on other sites
Coquina012 51 Posted September 3, 2020 Share Posted September 3, 2020 Quote Link to post Share on other sites
retroSail 8 Posted September 3, 2020 Author Share Posted September 3, 2020 2 minutes ago, Coquina012 said: Yea was joking, thanks for the advice. And nice boat. Quote Link to post Share on other sites
Coquina012 51 Posted September 3, 2020 Share Posted September 3, 2020 Here is a photo of young Dollie Parton, who is nothing if not relevant to boatbuilding. This photo was taken right after I informed her I was building a skiff rack of eye. 1 Quote Link to post Share on other sites
thengling 105 Posted September 4, 2020 Share Posted September 4, 2020 Quoting Tom Clancy: "Now there's one gal who'll never drown" Quote Link to post Share on other sites
Kenny Dumas 294 Posted September 4, 2020 Share Posted September 4, 2020 4 hours ago, Grestone said: Personally, I would test your concept out without a central dagger (swing or slot) first by using leeboards. A dowel or board that spans across the gunwales with a simple mount on each side could let you fashion leeboards without cutting into your hull below waterline. I'd test that first and see if you like it. Put the board in from the bottom and go sailing 1 Quote Link to post Share on other sites
retroSail 8 Posted September 9, 2020 Author Share Posted September 9, 2020 On 9/3/2020 at 5:38 PM, Kenny Dumas said: Put the board in from the bottom and go sailing I'm gonna try that first thanks! Quote Link to post Share on other sites
retroSail 8 Posted September 14, 2020 Author Share Posted September 14, 2020 Stuck a dagger board in the bottom and it seemed to work good. Quote Link to post Share on other sites
retroSail 8 Posted September 14, 2020 Author Share Posted September 14, 2020 Need more wind Quote Link to post Share on other sites
thengling 105 Posted September 14, 2020 Share Posted September 14, 2020 I'm curious about the mast leaning into the picture from the right. Quote Link to post Share on other sites
retroSail 8 Posted September 14, 2020 Author Share Posted September 14, 2020 1 hour ago, thengling said: I'm curious about the mast leaning into the picture from the right. The mast is bendy as its an old fibreglass windsurfer mast. A little big too. Quote Link to post Share on other sites
ziper1221 16 Posted September 14, 2020 Share Posted September 14, 2020 seems like you could use a boom or at least move the sheet point a little aft Quote Link to post Share on other sites
Dart96 22 Posted September 14, 2020 Share Posted September 14, 2020 Fit the boom from the windsurfing rig as well. Quote Link to post Share on other sites
retroSail 8 Posted September 14, 2020 Author Share Posted September 14, 2020 1 minute ago, Dart96 said: Fit the boom from the windsurfing rig as well. it's too heavy and bulky also not in my possession anymore . Quote Link to post Share on other sites
retroSail 8 Posted September 14, 2020 Author Share Posted September 14, 2020 I'll be looking at adding a boom to the setup. Quote Link to post Share on other sites
Dart96 22 Posted September 14, 2020 Share Posted September 14, 2020 Simple fix. Bit of wood from the sail cut out on the mast to the back corner of the sail, lashed on. Sail will press against it on one tack and not on the other. Doesn't matter. You need a boom for this rig. boat is not long enough or wide enough to use a loose footed one like in your picture. Bit of 2" by 1" should do. 1 Quote Link to post Share on other sites
Kenny Dumas 294 Posted September 14, 2020 Share Posted September 14, 2020 Sweet! Fucking around with donor rigs is great fun. Make sure your out haul or snotter is easy to adjust. That sail is designed for a bent mast (usually provided by the strong wishbone boom and a ton of luff tension/ downhaul) which is why it’s so baggy mid height right behind the mast. It will never look good, but outhaul tension is your only tool. Downwind in big air is swimming time with all the sail on one side. Get rid of the boom and let the sail fold around the mast, holding the sheet by hand, for running in survival mode. Practice in lazy light/ medium winds. 1 Quote Link to post Share on other sites
Trovão 483 Posted September 14, 2020 Share Posted September 14, 2020 5 hours ago, thengling said: I'm curious about the mast leaning into the picture from the right. 3 hours ago, retroSail said: The mast is bendy as its an old fibreglass windsurfer mast. A little big too. i think he is refering to this 1 Quote Link to post Share on other sites
retroSail 8 Posted September 14, 2020 Author Share Posted September 14, 2020 5 minutes ago, Trovão said: i think he is refering to this Oh yes. Long story short they had a stern anchor out during a storm and sank their boat... At the moment there are 7 sunk boats that I know of in the bay. This is one of two with the mast still attached. 3 Quote Link to post Share on other sites
retroSail 8 Posted September 14, 2020 Author Share Posted September 14, 2020 21 minutes ago, Kenny Dumas said: Get rid of the boom and let the sail fold around the mast, holding the sheet by hand, for running in survival mode. Practice in lazy light/ medium winds. So I don't have a boom yet but are you saying it won't be useful at all or that it'll cause more issues? I will only be in light winds until I feel really comfortable. Quote Link to post Share on other sites
thengling 105 Posted September 15, 2020 Share Posted September 15, 2020 4 hours ago, Kenny Dumas said: Make sure your out haul or snotter is easy to adjust. If you don't have Todd Bradshaw's book Canoe Rig, get it. Lots of ideas, including leeboards, snotter adjustment, etc., small boat friendly. Sketch from his book. 1 Quote Link to post Share on other sites
Kenny Dumas 294 Posted September 15, 2020 Share Posted September 15, 2020 Yeah, try it now before you put a boom on. Free fly the sheet by hand. Flip it so it wraps either side. Instant reef. Great for downwind landings. And totally safe jibes. Quote Link to post Share on other sites
retroSail 8 Posted September 15, 2020 Author Share Posted September 15, 2020 14 hours ago, Kenny Dumas said: Yeah, try it now before you put a boom on. Free fly the sheet by hand. Flip it so it wraps either side. Instant reef. Great for downwind landings. And totally safe jibes. Yea I was thinking last night that to reef this sail all I have to do is roll it up. I'll give it a shot next time I go out and report. Quote Link to post Share on other sites
retroSail 8 Posted September 30, 2020 Author Share Posted September 30, 2020 Was able to really test out the rig the other day. Can go upwind so I guess it works. I wrapped up the sail to make it a bit smaller. I think I need to cut through the seat so the dagger board is easier to put in and take out. 1 Quote Link to post Share on other sites
Grestone 34 Posted October 12, 2020 Share Posted October 12, 2020 congrats, man! Looks like you've got yourself loads of fun in that little cobbled-together dinghy. Quote Link to post Share on other sites
retroSail 8 Posted February 3 Author Share Posted February 3 Tree decided to crush my dingy dreams Quote Link to post Share on other sites
fastyacht 1,601 Posted February 3 Share Posted February 3 Well gvod dmamnit Howeve all mot losI had a nice Bell bicktail crushed by a common carrier. ( Was sigmed foe wiithou inspect) Irepaied it good is new with little trouble. Quote Link to post Share on other sites
Amati 1,507 Posted February 4 Share Posted February 4 On 9/3/2020 at 12:42 PM, retroSail said: So the boat has a slot on the bottom for a dagger board but the seat is covering the top of that slot. I'm not sure how I could get a board in there with out cutting the seat open. As long as the covering is above the waterline? Quote Link to post Share on other sites
Amati 1,507 Posted February 4 Share Posted February 4 On 9/13/2020 at 9:01 PM, retroSail said: Need more wind It’s the PNW. That is wind. Quote Link to post Share on other sites
Bruno 119 Posted February 4 Share Posted February 4 With that tall a rig you need more twist. Quote Link to post Share on other sites
retroSail 8 Posted February 4 Author Share Posted February 4 1 hour ago, Amati said: It’s the PNW. That is wind. Yea I was able to get out on some nice days in the fall when it was blowing 15kts and blue skies. Had to play around with the sail shape a lot as the winds increased but I was able to go up wind with the setup so I think that is a success in my books. 1 Quote Link to post Share on other sites
CapnK 109 Posted February 16 Share Posted February 16 That'll buff out. Seriously, if you get it free from the trees it may well assume most of its former shape. If so, a little crack sealing with 5 minute epoxy, and Bob's your uncle. Go for it - don't give up the ship! 1 Quote Link to post Share on other sites
retroSail 8 Posted February 16 Author Share Posted February 16 2 hours ago, CapnK said: That'll buff out. Seriously, if you get it free from the trees it may well assume most of its former shape. If so, a little crack sealing with 5 minute epoxy, and Bob's your uncle. Go for it - don't give up the ship! Yea it has been rescued and will be fixed in the spring when the weather is a little nicer. 2 Quote Link to post Share on other sites
Kenny Dumas 294 Posted February 17 Share Posted February 17 Bummer Retro. Turn her over and hang from the gunnels and Make stone soup. she’ll be right by spring. Time is your friend to avoid cracking on the rebend. Quote Link to post Share on other sites
