Amateur couple rebuilds salvage cruiser
2 hours ago, Alaris said:
Is there a reason not to put any type of adhesive underneath the grid before the glassing?
Depends on what you mean by adhesive. If a stretchy glue like 5200, I'd say no point. The structure won't flex enough before glass bonds start failing before the 5200 starts getting engaged.
If you mean Plexus, Spabond or another rubber toughened epoxy, I'd say yes, it would be worthwhile.
  • Replies 530
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Like watch it before commenting? Have you no respect for internet traditions?
Sure I would. It's the Chevy of the seas, not a Pininfarina. If you drive it like a rental (Which it was) you'll get wear and tear like a rental. Hitting rocks with boats is bad, as I understand it th
To be fair, most keels are bolted on, the question is, what are they actually bolted TO...
Posted Images
Because they ground the flanges off of the grid.. Nothing to put peanut butter under. The scary thing is they jacked the grid down to the hull. The snap crackle pop noises should tell you something.. It's trying to tear itself apart before the glue dries!!
Curious why they decided that was the correct approach.  The grid should be very rigid.  Did they have evidence that the grid had moved up from the hull?
Pushing the hull up to the grid while holding the grid in place relative to the coachroof might have made more sense.  Or drilling holes through the hull and clamping the two together.  Easy to fix the holes afterward.
Isn't that just going to point-load the hull in the various points of random contact? What the hell, staple the edge bits down and call it good.
6 hours ago, GH41 said:
... The scary thing is they jacked the grid down to the hull. The snap crackle pop noises should tell you something.. It's trying to tear itself apart before the glue dries!!
If you actually watched the video you would have seen their explanation that the force required to push the grid back down was not that high, in fact she could push it back herself with all of her what, 90 pounds?
They didn't mention the cracking noises when she was bouncing on it. They said she almost got it down with her 90#. I imagine the cracking sound was from the grid trying to be pushed somewhere it hadn't been before. Remember the thickness of the original bonding agent? Remember them deciding the grid forward and aft of the bulkheads was GTG? Don't you think the grid was one piece running front to back with the bulkheads tabbed in after the grid was set? What was the mysterious force that raised the grid?
The new glasswork is going to really distribute the loads well. The extra glue probably will be a bit stretchier than the glass/resin (epoxy resin I hope) so it might not do much than hold the grid in position before glassing. Short answer: probably won't matter too much.
6 hours ago, Alaris said:
The ridiculous morons with the wooden schooner just put up a new video and — hold on — that boat is only 13 years old?
edit: https://youtu.be/P17JwkVhgPM
Against my better judgment I watched most of that one, minus the last forth which appears to be a video selfie. Assuming there was no epiphany, they really don't get it. Big holes in the hull surrounded by worms. There must be thousands of pounds of flora and fauna stuck below the waterline, but they seem to have decided not to scrape the entire hull, to save time and not have to bottom paint? As if there is any antifoul left, if it was ever applied in the first place. I usually want to see projects like this succeed, but someone needs to take them aside and have the comming to Jesus talk.
Ummm, it's a wooden boat. In the tropics. It doesn't have copper sheathing. They're not going to scrape the hull and apply a lot of antifouling?
Has anyone mentioned the word 'teredo' to them yet?
To be fair, though, it's probably way, way too late. The hull is likely riddled with them - and gribble - and no way of getting them out really.
So it's a bonfire waiting to happen. Or a new dive site.
FKT
They described how they were going to find the holes and fill the holes ... but they didn't ask why those holes existed.
The whole thing was scarily naive. There was no sign of them considering the possibility that there may some factor causing these holes to appear.   No consideration of the possibility that more holes may exist which have not yet broken through.  They asked no questions about the integrity of the structure.
When the holes are plugged, they plan to take the boat on an open sea trip down the coast.  When that bug-ridded hull starts getting stressed in a seaway, I fear that those weakened structures may open up more and bigger leaks, and may even have a catastrophic failure.
A bonfire would be the best ending for the boat, but I think we are heading for a sinking on passage.
I have a book here - can't remember the title/author ATM - about a voyage from China to the USA in a junk, apparently to prove that the Chinese could do it. We'll skip over the fact that I have at least 3 other books written by people who actually did this decades prior and skip to the good bit.
They had the boat built in 'traditional' fashion. No antifouling apparently.
Half way across you could *see* nice bright blue pinpricks of light through the planks - and funnily enough it was leaking like a sieve. Great pix showing the problem.
Eventually they had to be rescued. The worms (well, bivalves) won.
FKT
And it had never been hauled out, go figure...
(I know it was beached at least once, but still)
In addition to being in scary bad shape, this boat's design is odd. At first I thought it was some type of local or traditional craft, but the completely open stern area, short spars, and overall look of the thing, does not add up to an ocean going boat despite it's size. A little internet research yielded some photos of very similar looking Brazilian party boats used in the tourist trade. That might explain it's build quality, and why it has two 500 gallon diesel tanks. I hope someone with local knowledge will chime in, but I suspect it is a day use motor boat with an almost decorative rig not meant for offshore work.
On 11/28/2020 at 3:03 PM, GH41 said:
They are at it again >> I know nothing about the epoxy they used but I hope they know what amine blush is. Maybe they used slow enough hardener and worked fast enough to avoid problems.
I think they said they laid up 10 lams of 1700 in what looks like a single day - probably less since they started in daylight.  So maybe 1 hour per lam - 2 at most.  Amine blush should not be an issue.
If you use that kind of glue (Plexus, Spabond), is glassing useful  ???
How did they determine it needed 10 layers ??? Not 8 or 12 ??
Even worse there was little to no overlap bonding out onto the old structure. It should have been layered out progressively probably beyong the next stringer out, instead it was just butted alongside the old stringers port and starboard. That means the layers bond in a single layer of glass at the meeting of the new to the stringer in the old structure, is the total strength and not the total new lams.
Or did I miss something ?
There are a few glimpses of notes with details of the layup they wanted, and they actually pre-cut their glass in accordance this schedule. I don't know how much professional input they had in determining this, but they did not slap it on haphazardly.
From the overall tone of their videos, I would understand that they did not elaborate on that subject. After all, their not aiming to be a boatbuilding channel, more of the 'cruising lifestyle' kind. This technical stuff is probably not very interesting for the target market of such channels
They explained somewhere that they have advice from professionals at least on the serious issues. This guys are amateur but not stupid, I think.
Everything looked  very well planned, prepared and executed, IMHO. Everything pre-cut, resin carefully selected, and so on.
The repair is probably going to be strong, but what a fucking idiots! "This is the hardest thing we've ever done!" Are you kidding me? How hard is fiberglassing? Doing it right is hard, but that would be a different league than what they are doing? And they had no idea it would be this challenging? Oh come on.
Why did I watch that episode after I already decided to stop watching this nonsense? Makes me an idiot too.
On 11/30/2020 at 2:09 PM, MiddayGun said:
There's going to be a lot of very disappointed people in this thread if the keel doesn't fall off the second they motor if off the slings.
I understand what you're saying.....once complete she should be a 'dock queen' and they should keep her in a slip.  If I recall correctly, they have plans on sailing around the world once their project is done.  I'm interested to see what happens once they hit the open ocean gales, storms, etc.....  Seems like a lot of work they're doing with not much of a chance of getting Vessel Insurance.
Come on! Insurance is for squares and "those who live lives of quiet desperation" in their cubicles.
Some of you guys do make me laugh.
Yeah, we're going to sail oceans.... with our two dogs aboard.  Right.
I’m actually impressed by the amount of work these two have gotten done in a short period of time.  They have had more than a few opportunities to get depressed and give up.  They have made rookie mistakes, but they have ground down to the bottom of the bad news and appear to be building back in a credible way.
They are going at the laminating in a fully professional way. They have schedules, stack cuts with tapers and it seems a bit of skill.  I questioned Raka epoxy because it is stuff I don’t ever consider, but they have a good reason for selecting it.
I expect they will be fine.
SHC
  • Like 5
48 minutes ago, Alaris said:
Judging by the most recent episode, this happened quite a while ago (sunset at 8pm). Interesting to see if they got the boat (and their presumptive home) in the water before it started getting cold.
Well it's snowing here (they are a 20 minute drive) today. Its stopped now. We're looking at high 30s to low 40s in the next 6 days.Warmish but wet weekend.
2 minutes ago, George Dewey said:
Well it's snowing here (they are a 20 minute drive) today. Its stopped now. We're looking at high 30s to lo4 40s in the 6 days. Warmish but wet weekend.
In the vid they dropped today she was complaining about the heat and humidity slowing her ability to dry the FG cloth that got rained on. Don't know about you guys but I have never had any luck wetting out cloth that had been wet using polyester resin. Don't know about epoxy.
2 hours ago, SloopJonB said:
Is that like studying thousands of designs?
I don't know what you mean, but I'm sure they asked someone how many layers to put there.
That was a reference to the Flyin' Hawaiian thread.  The guy building the Home Depot plywood catamaran by studying thousands of designs.
Heat and humidity????? Hmmmmm
Whatever, they have a West Marine right near by, and also Salks which has a a lot of that stuff too.
Wet is not the good for the binders as Zonk says but it’s not water soluble. so, unless it is physically washed out of the ‘glass, it should be able to dry out and retain it’s integrity in taking up resin into the cloth or mat.
Not that I would use it myself since it’s so inexpensive compared to the other materials.
One difference I noticed between this boat and my Catalina 42 is the structure - or lack thereof - around where the keel attaches.  With the Catalina, the hull dips down a couple feet to form the top of the keel and provide an attachment point for the lead.  This forms a proper bilge.  On the Beneteau, it looks like the keel is just bolted onto a relative flat surface.  In a hard grounding, it seems like the forces would be much more difficult to contain with a flat keel attachment vs something like Catalina's approach where the attachment is supported by a vertical component.
Another question... How did the keel displace the grid upward without compromising the hull beneath it? The keel is hung from the hull not the original grid. Why did the piece of FG come off with the keel? Maybe it was part of a patch job done while the keel was still attached. The whole project looks like an exercise in throwing good money after bad.
A fiberglass hull has some flex. Keel hits, flexes hull while grid stays in place: crack! Grid separates from hull.
Not sure about the piece of FG you mention. I did not see that part I guess (I already watched way too much).
In the video titled "Keel Gets Ripped Off" between 16:15 and 17.25. Probably a piece 16"x16".
I believe that is called a keel sump. Very stable attachment point for a hull
I have one of these on my Jeanneau.  It is a very different design compared to what I had on my previous boat (Dash 34) which had a keel stub.  It serves as a sump, accumulating any water in the bilge, and so it is where the bilge pump is located.  Were it not there, the floor is very flat in that location and any water in the bilge would distribute itself all over the place and be difficult for the bilge pump to remove.
Aside from that, I can't see any reason for it to be there.  It may help position the keel when it is being attached.   The rest of the keel sits flush on the bottom of the hull and is simply bolted through the hull with backing plates and large washers.  There are large lateral stringers glassed to the hull to distribute the load.  It looks strong enough to me, and there is no evidence of any movement at the joint.  If anything there is a shortage of longitudinal stringers in this design.
Bene's & jen's have the same system. The sump is just to collect water in a hole that makes it easier to pump it all out. The recess in the keel is about 3/4" larger than the sump box all around, so does nothing to locate the keel. However, it does allow a lot of bonding surface for the keel/hull joint caulk (usually 5200) to adhere the the box. This is why the glass stripped back when they dropped the keel
Wet glass is the kiss of death with polyester.  It's not good with epoxy either, but some resin systems are more tolerant than others. Fucking G Flex cures with glass underwater.  Not that I would do that as anything other than a jungle repair.
It's clear that these videos are months behind real time. Hot and Humid hasn't been sighted since early September. If you take the 8 o'clock sunset to mean anything, this last video was shot in August.  It was dry enough this summer that the actual rainy  night could really identify the date if you cared to.
SHC
So the mechanical bond of 5200 to fiberglass is stronger than the laminated structure of the hull. If that is so why even use keel bolts? Just glue it on. It's obvious the kids are repairing it for the second time. I am betting the original owner's insurer paid for the first repair and the yard that half ass fixed it insurer bought the boat as a total loss.
SHC
The delay is suspicious. Especially considering they only took a week to post after man bun left for training and her finishing the layup. Maybe they had to go back to work.
5200 does have incredible bonding ability. Judging from some keel removals I've seen, it might be enuff without bolts. We (or the kids) will never have any definitive statement on previous repairs. Caveat emptor, indeed. And we do not know the details of the prying/cutting that was done this time dropping the keel, they might have damaged the lam in the process.
I will keep a few used strings from my bass guitar around to cut the 5200 in case I ever have to remove the keel.  The round wounds should do the trick.  Similar to how they cut up wrecked ships into smaller pieces.
You can do it with the braided cord they use to layout construction sites. Probably not as fast as the guitar string but as cheap as it is you could do longer strokes.
3 minutes ago, stayoutofthemiddle said:
Can someone with boat building experience summarize where we are at...
1. How much was do you estimate the purchased this salvage for? $30K?
2. Is their rebuild sufficient or is there inherit risk of a keel loss and capsize in the middle of the night under large seaways?
It was auctioned as a salvaged vessel because the insurance company couldn't repair it for less than the replacement value without assuming liability for the repair. Sorta like when a car is totaled because the frame is bent. I have no idea what they paid for the wreck. Probably more than what it is worth if you consider they probably cannot insure it. " Is their rebuild sufficient or is there inherit risk of a keel loss and capsize in the middle of the night under large seaways" I'll put it this way.... I wouldn't sleep on it if it wasn't tied to the dock! Dreamers rarely win... Karma almost always gets them first.
I once used something called "debond" to dissolve 5200. Came in a spray can like WD40 and it actually worked. But yeah, 5200 is strong stuff and people use it everywhere, mostly places it shouldn't be used.
My rule with 4200 vs 5200 is that 5200 should only be for structural items. Through hulls are not structural! 4200 all day, even under the waterline like the sounder.
wasn't it determined that this was close to 100k. idiotic!
Since it should be stronger than the original, then no I don't think it will fall of.
We call 5200 “Fuck the next guy.”  I hate the stuff.
I don’t know what they paid.  I would have paid scrap value for the equipment and deducted the disposal cost of the hull, but that is just me.  I think they bought too large a boat with too many luxury systems and long term they are going to hate it.  Air conditioning, TV, pressurized hot water are all things to break and the cost of everything else goes up at the cube of the length.  If your goal is a sustainable adventure lifestyle, read Lin and Larry Pardey.  Go small go simple.
I think  10 layers of 17 oz Biax adds up to most of 3/8 of an inch.  Double that in the laps where the webs are bonded to the hull.  This should pretty much kill it.   Epoxy, because it has a higher elongation before yield, is better than the GP polyester of the original construction.    If there is a problem, it is that the hull thickness directly under the hat sections cannot be repaired and may be compromised.  They will know for sure if when they strip all the paint off the bottom they discover a legion of spider cracks.  In which case they will enjoy grinding into the hull from the outside to get to the bottom of the white broken resin and fiber and will need to build up additional repairs.
So in all, I don’t have a big issue with the repair.  I could ask why they chose this particular boat as there are many other candidates that are NOT all fucked up from better builders.  They don’t have the styling and “features” of the Beneteau.  It’s tough to do this work living on site, sleeping in a van with two dogs, which probably bodes well for their ability to live aboard for a long period of time.
SHC
