ollylove 0 Posted January 9, 2021 Share Posted January 9, 2021 We are looking at getting a PC and Software onboard, We have a Tacktick system running 0183 NMEA USb link Garmin Plotter (older ne) AIS Transponder boat is only used for racing, what we want is to be able to have something like experdition or seatrack that we can click marks and get some sort of data feedback through the system and it all appears on the screens on deck, then we get the polars and suggest kites etc, What do people suggest? Not keen on Ipads etc and they just arnt good for a days racing and the battery will be gone by midday Quote Link to post Share on other sites
us7070 308 Posted January 9, 2021 Share Posted January 9, 2021 Expedition does have the ability to receive data from Tacktick, and to send custom channels to Tacktick displays. The receiving is going to be straight forward.., but not having used expedition with tacktick, i am not sure how well the sending will work The thing is, it's going to be a NMEA 0183 connection, so you are limited to numbers for which there are NMEA 0183 sentences, plus whatever custom sentences tackitick has enabled I have Tacktick on my boat - but i have never connected expedition to it - i just daysail..., nevertheless, i did just get the T122 interface, and might as well give it a try in the spring here is the section of the expedition manual that deals with Tacktick: Quote Raymarine Wireless instruments, previous Tacktick instruments. Web www.raymarine.com (previously www.tacktick.com) Connection settings Raymarine wireless / Tacktick instruments (via the T122 Wireless Interface) communicate using the NMEA 0183 protocol, so the default serial port settings are 4800,8,N,1. See the NMEA 0183 and serial port help for more information on the Nmea standard and interface, however, there are also several custom NMEA strings available with Tacktick. Baud rate 4800 Data bits 8 Parity None Stop bits 1 Note: Tacktick does not send TWD, so Expedition needs to calculate it. Select this on the calculations page. Tacktick settings More advanced interface options are available by clicking on this button. Output Any Expedition channel, including alternating channels, can be sent to one of four or six Tacktick Proprietary NMEA sentences. See your Tacktick manual for further information. Selecting the damped check-box next to any output channel will cause damped data to be output. The Custom name fields lets the user over-ride the default external channel tag. Some displays cannot display the proprietary data, please check your Raymarine/tacktick product documentation. The T210 Maxi, T215 Maxi and T110 displays can, but the T111 dual line and 215 dual maxi displays can't. Because of the limited display space, values below -100 may not show the - sign. NMEA 0183 Allows NMEA messages to be selected to receive and/or sent. Tacktick cals Send Twa and/or Twa auto-cal values to the Tacktick processor. Select which auto-cal values to send on the calibration system page. Alternating Alternating numbers. Exp calibration Advanced calibration and calculations. Exp calculations Tacktick does not send TWD, so Expedition needs to calculate it. Select this on the calculations page. Quote Link to post Share on other sites
airacer 22 Posted January 9, 2021 Share Posted January 9, 2021 5 hours ago, ollylove said: We are looking at getting a PC and Software onboard, We have a Tacktick system running 0183 NMEA USb link Garmin Plotter (older ne) AIS Transponder boat is only used for racing, what we want is to be able to have something like experdition or seatrack that we can click marks and get some sort of data feedback through the system and it all appears on the screens on deck, then we get the polars and suggest kites etc, What do people suggest? Not keen on Ipads etc and they just arnt good for a days racing and the battery will be gone by midday What type of boat and what is your budget? Based on your initial post I get the feeling your expectations may exceed the budget and time commitment. Expedition is the standard. Running it on a handheld PC or relaying the screen to an iPad will be your most economical choice. Maybe just run an app like RaceQs? Quote Link to post Share on other sites
ollylove 0 Posted January 9, 2021 Author Share Posted January 9, 2021 I have used Experdition quite a bit, always feel its a bit offshore orentaited, We have a tablet but i think the main thing is stopping the plotter being the primary input to the course etc, Not keen on ipad/phone use as the apps are more toys than serious race tools, and dont feedback into the system, Boat is a 32ft, Quote Link to post Share on other sites
solosailor 616 Posted January 9, 2021 Share Posted January 9, 2021 I think you are looking for something you don't need. Sail suggestions from your system for an inshore race? 2 Quote Link to post Share on other sites
b393capt 30 Posted January 10, 2021 Share Posted January 10, 2021 For expedition I use a 12vdc I5 fanless mini PC found on Amazon years ago and have been happy with that, it is something like this with lots of cooling fins, SSD, and then upgraded the memory to 16GB. Like this, I didn't use exactly this: https://www.amazon.com/QOTOM-Processor-Fanless-Desktop-Windows/dp/B07DYLMWYN/ref=sr_1_3?dchild=1&keywords=fanless+i5+128GB&qid=1610237224&sr=8-3 Beware, if your PC and engine use the same battery, you may need to put something to manage the power surges in front of this to keep it from rebooting on engine start. Also, plan on buying a copy of windows10, the windows these pcs come with are sometimes crippled and you cant get them setup quite right and get updates. Here are the links for the actual monitor, lighted wireless keyboard, and wireless mouse I added to it. monitor https://www.amazon.com/gp/product/B07P3ZSXJ1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 keyboard https://www.amazon.com/gp/product/B00ZOPVSKW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 mouse https://www.amazon.com/gp/product/B01EZZMAJ4/ref=ppx_yo_dt_b_asin_title_o00_s02?ie=UTF8&psc=1 1 Quote Link to post Share on other sites
