i need a new mainsheet
suggestions? 9mm-10mm  water repellant , soft on hands, easy through blocks with good abrasion protection...
Doubtful one can have both a nice hand and abrasion resistance. The soft lines are also snag prone. Why abrasion resistance? Sounds odd for a mainsheet application.
Marlow's Excel Fushion says it's all that (and a bag of chips). No experience with it, but I'm not a fan of blended ropes using polypropylene.
Take a look at New England's Nexus Pro. The cover does have polyester blended in with the dyneema so it will absorb some water though.
I did 8mm salsa on my columbia and it's awesome. it was a little tricky to splice, but I chalk that up to me being terrible at splicing. you can get it in 9.5 as well.
Big fan of the Nexus Pro...  I don't even need gloves. Taper it and leave the cover only where it cleats and for your hands.
Runs faster and with less friction.
Dyneema holds up remarkably well in UV however I have a boom tent that helps protect the cockpit and sky all my halyards regularly.
I suggest you remove the old mainsheet, take it into WM or a rigger with good line selection, see what they have that you'd deem acceptable, write those few down, research them then go back & buy it.
That's what I did.
as an aside, I like your setup. our main coarse tune is still on the traveller, which makes it tricky. Fine tune is on that eye like yours.
Moving this to the Lumbo thread for specifics...
second on the salsa,  i have 5/16, runs fast, light weight , easy on the hands , doesn't stay soggy...    if you have a lot of extra line, it does occasionally find a way to tie itself into a knot..
