3YM20 Seawater coolant pipe leak
Got a leak from the small valve stem seal on seawater side.  The tiny valve is closed but still leaks.  (YM Part #128990 49110).  Should I replace the valve or the whole pipe?  (YM part #128990 49010). Any tips on changing old pipes is appreciated!
Can't you simply replace it with hose?
The only diesel I've had with hard coolant lines was an old Perky 4-107 - all the rest used all hose.
