rksailsolo 0 Posted July 2, 2021 Share Posted July 2, 2021 How do you access the hose clamp where the pipe connects with the heat exchange? On my Jeanneau 349, it's so tight I can't see the clamp and can barely fit a screwdriver in the space. Quote Link to post Share on other sites
Zonker 5,241 Posted July 2, 2021 Share Posted July 2, 2021 flexy shaft nut driver? Quote Link to post Share on other sites
longy 850 Posted July 2, 2021 Share Posted July 2, 2021 1/4" ratchet drives with the right socket work quite well Quote Link to post Share on other sites
rksailsolo 0 Posted July 2, 2021 Author Share Posted July 2, 2021 But driver use, good idea. Flex shaft even better. Thanks. Guess I could investigate removal of belts cover and even the steps from cockpit to cabin to ease access. Quote Link to post Share on other sites
IStream 3,415 Posted July 2, 2021 Share Posted July 2, 2021 One of the first things I do on any boat is add hatches/hinges/latches to any cabinetry surrounding the engine for easier access. Yes, your hose issue will turn into a carpentry project cascade but it only hurts once and you'll smile inside every time you access the engine in the future. 1 Quote Link to post Share on other sites
SloopJonB 12,568 Posted July 3, 2021 Share Posted July 3, 2021 Engine access as well as stuffing box, sea cocks and steering access are among the very first things I check out when considering a boat. I can't count the number of boats I've been on where destruction was required to maintain things. Last year I spent several horrible days cutting, grinding and laminating the engine beds on my boat so I could access the stuffing box. Previously it was simply not possible to adjust it. 1 Quote Link to post Share on other sites
rksailsolo 0 Posted July 3, 2021 Author Share Posted July 3, 2021 Thanks Quote Link to post Share on other sites
Parma 432 Posted July 12, 2021 Share Posted July 12, 2021 Not accessible? Hard to believe jeanneau would do that. I have a 3YM 20 but's accessible on all 4 sides. Quote Link to post Share on other sites
