Borax Johnson 107 Posted August 12, 2021 Share Posted August 12, 2021 Fkuc me. I bought the wrong iPad - it doesn't have the GPS chip - Fkcu Tim Cook. Save $3.09 per unit in the Uyghur concentration camps and rape factories?!? So, what is the best aftermarket GPS (bluetooth?) device to buy? Thanks. Quote Link to post Share on other sites
Mulligan 49 Posted August 12, 2021 Share Posted August 12, 2021 I loved my Bad Elf Bluetooth GPS, before I got my cellular iPad. I may just get another for backup! Quote Link to post Share on other sites
Mulligan 49 Posted August 12, 2021 Share Posted August 12, 2021 One really cool thing about it is that you can connect several BlueTooth devices at once. It’s battery lasts a long time, and it doesn’t chew up as much battery on the iPad. Quote Link to post Share on other sites
knurd 8 Posted August 12, 2021 Share Posted August 12, 2021 +1 for bad elf. I'm using the same setup, an old ipad mini paired with a bad elf gps. I've had no problems with the combination. Quote Link to post Share on other sites
Ruminator 156 Posted August 12, 2021 Share Posted August 12, 2021 Another vote for the Bad Elf. A solid piece of gear for years onboard. Quote Link to post Share on other sites
CutterCaptain 6 Posted August 12, 2021 Share Posted August 12, 2021 I too used the Bad Elf until I installed an AIS transponder that has Wifi (the Vesper XB8000.) Shows not just AIS targets, but GPS and NMEA data even on an ancient iPad2 running iNavX. Quote Link to post Share on other sites
Slim 129 Posted August 12, 2021 Share Posted August 12, 2021 I also use the Bad Elf. Works with my iPad, my iPhone, and a windows PC running OpenCpn. Quote Link to post Share on other sites
SEC16518 114 Posted August 12, 2021 Share Posted August 12, 2021 I've used a small Garmin handheld that connects via Bluetooth to the iPad......works great for the Navionics app. Quote Link to post Share on other sites
dacapo 1,571 Posted August 13, 2021 Share Posted August 13, 2021 I use the DUAL multipurpose. It can have more than 1 device use the gps https://www.amazon.com/Dual-Electronics-XGPS150A-Multipurpose-Augmentation/dp/B006M49G80/ref=asc_df_B006M49G80/?tag=hyprod-20&linkCode=df0&hvadid=312195667633&hvpos=&hvnetw=g&hvrand=410882393065843823&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004840&hvtargid=pla-441061981403&psc=1 Quote Link to post Share on other sites
Tom Keffer 69 Posted August 13, 2021 Share Posted August 13, 2021 13 hours ago, dacapo said: I use the DUAL multipurpose. It can have more than 1 device use the gps https://www.amazon.com/Dual-Electronics-XGPS150A-Multipurpose-Augmentation/dp/B006M49G80/ref=asc_df_B006M49G80/?tag=hyprod-20&linkCode=df0&hvadid=312195667633&hvpos=&hvnetw=g&hvrand=410882393065843823&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004840&hvtargid=pla-441061981403&psc=1 +1 on the DUAL. Less expensive, and just as capable. Quote Link to post Share on other sites
Mulligan 49 Posted August 13, 2021 Share Posted August 13, 2021 31 minutes ago, Tom Keffer said: +1 on the DUAL. Less expensive, and just as capable. The Bad Elf has twice the battery life. I used mine for point to point racing. I was able to leave mine plugged into ship’s power and leave the unit down below. But, you can’t do that on carbon boats, as the signal won’t go through! The Bad Elf also has a small lcd display, giving speed and cog. Quote Link to post Share on other sites
Hike, Bitches! 353 Posted August 17, 2021 Share Posted August 17, 2021 I also used the Dual GPS (marine version, it was white, not sure any other difference), until I went a similar route as @CutterCaptain and got a Quark AIS/GPS/Seatalk/NMEA/WiFi combo box. But the Dual is still in the iPad bag in case I go somewhere else. Quote Link to post Share on other sites
Scrambler 7 Posted August 28, 2021 Share Posted August 28, 2021 On 8/11/2021 at 11:37 PM, Mulligan said: it doesn’t chew up as much battery on the iPad. Do you notice the using the bad elf that the iPad battery lasts longer? Quote Link to post Share on other sites
Mulligan 49 Posted August 29, 2021 Share Posted August 29, 2021 16 hours ago, Scrambler said: Do you notice the using the bad elf that the iPad battery lasts longer? Yes! Quote Link to post Share on other sites
Scrambler 7 Posted August 29, 2021 Share Posted August 29, 2021 8 hours ago, Mulligan said: Yes! I’m running a 9” IPad brightness is on full, the gps and wifi are on (connection to Furuno radar, works great) and it is a battery hog. I might go to an IPad mini and perhaps a bad elf to use less power. I assume a mini is less power dependent. We had a lot of fog on our June cruise and wouldn’t of cruised on schedule without this stuff. Quote Link to post Share on other sites
