Ventucky Red 1,102 Posted August 21, 2021 Share Posted August 21, 2021 Cable provider notified me that I should upgrade to the DOCSIS 3.1 modem and provided me a list of units to pick from or rent theirs. I am inclined to buy my own and looking at some of the units out there the new set up is modem and router in the same unit. I have used Netgear from the start, and I am looking at the Orbi. https://www.netgear.com/home/wifi/mesh/cbk752/?cid=us-run-rates-srch-cpc&utm_source=shopping&utm_medium=cpc&utm_campaign=us-run-rates-shopping-cpc Anyone here have this or a recommendation on something better? Quote Link to post Share on other sites
IStream 3,415 Posted August 22, 2021 Share Posted August 22, 2021 FWIW, I just retired an one year old Arris SB8200 modem. No wifi, but it's a good performer: https://www.amazon.com/ARRIS-SURFboard-Approved-SB8200-Frustration/dp/B07DY16W2Z/ref=sr_1_3?dchild=1&keywords=arris+sb8200&qid=1629590237&sr=8-3 I just switched to fiber and was going to put it up on CL but if you're interested PM me and I'll give you an SA deal. Quote Link to post Share on other sites
ExOmo 177 Posted August 22, 2021 Share Posted August 22, 2021 You might consider getting a separate modem and router. Just gives you some flexibility. It is my understanding that unless you have a very fast connection, then you may not benefit that much from wifi 6 and it certainly costs more at this time. 1 Quote Link to post Share on other sites
Ventucky Red 1,102 Posted August 22, 2021 Author Share Posted August 22, 2021 13 hours ago, IStream said: FWIW, I just retired an one year old Arris SB8200 modem. No wifi, but it's a good performer: https://www.amazon.com/ARRIS-SURFboard-Approved-SB8200-Frustration/dp/B07DY16W2Z/ref=sr_1_3?dchild=1&keywords=arris+sb8200&qid=1629590237&sr=8-3 I just switched to fiber and was going to put it up on CL but if you're interested PM me and I'll give you an SA deal. Check PM Quote Link to post Share on other sites
IStream 3,415 Posted August 22, 2021 Share Posted August 22, 2021 2 hours ago, Ventucky Red said: Check PM Back atcha. Quote Link to post Share on other sites
LionessRacing 669 Posted August 22, 2021 Share Posted August 22, 2021 Anyone up to speed on “MoCA” bridges ? just learned that my Internet/cable provider installed one, off the Modem to the house coax network. the “cable box” gets its “network” connection over the bridge, apparently multiplexed along with the digital cable signals. as I understand, I can put similar bridges at various points in house, and connect my Apple airport 801.11ac Wifi gear, extending the network by wires rather than propagation through house. I would expect to get much better speed across house (three story, 5 k ft^2) are all brands compatible ? Is gen 2.5 back compatible to gen 2? Quote Link to post Share on other sites
Throatwarbler-Mangrove 33 Posted August 24, 2021 Share Posted August 24, 2021 On 8/22/2021 at 6:37 PM, LionessRacing said: Anyone up to speed on “MoCA” bridges ? just learned that my Internet/cable provider installed one, off the Modem to the house coax network. the “cable box” gets its “network” connection over the bridge, apparently multiplexed along with the digital cable signals. as I understand, I can put similar bridges at various points in house, and connect my Apple airport 801.11ac Wifi gear, extending the network by wires rather than propagation through house. I would expect to get much better speed across house (three story, 5 k ft^2) are all brands compatible ? Is gen 2.5 back compatible to gen 2? MOCA is a better solution than WiFi repeaters. Not only higher speed than 802.11ac, but more reliably. MOCA has a certification and interoperability program, so all brands should work together. Don’t know for sure about back compatibility, but would be very surprised to find out that it isn’t. Go for it. Quote Link to post Share on other sites
LionessRacing 669 Posted August 24, 2021 Share Posted August 24, 2021 8 hours ago, Throatwarbler-Mangrove said: MOCA is a better solution than WiFi repeaters. Not only higher speed than 802.11ac, but more reliably. MOCA has a certification and interoperability program, so all brands should work together. Don’t know for sure about back compatibility, but would be very surprised to find out that it isn’t. Go for it. thanks, I know that I should be able to propagate the Airport extended network by wired connection, so that will be a speed boost. Quote Link to post Share on other sites
rockb 30 Posted September 7, 2021 Share Posted September 7, 2021 My experience with Mediacom is if you have your own modem and there is a problem they always say their system is working fine, the problem is with your equipment. If you rent a modem from them and there is a problem at least you can plug 1 computer directly into their modem and if the problem persists you can prove it is their problem not yours. Quote Link to post Share on other sites
Hike, Bitches! 353 Posted September 7, 2021 Share Posted September 7, 2021 I have been running the Netgear Orbi CBR40, with one satellite for a few years. It is still technically a hub/spoke style "mesh" network, but the repeaters talk to the main router on their own frequency band so it isn't piggybacking off your wifi frequency. I still don't get as much 'range' outside as I would like, but I haven't hooked up one of their outside satellites yet. The other nice thing is one network name...I tried at $35 repeater once, and it was a PITA to switch between networks. The Orbi seems pretty seamless hopping between the router & satellite. The connection is good enough for all my IoT's to get a connection. Quote Link to post Share on other sites
P_Wop 3,413 Posted September 8, 2021 Share Posted September 8, 2021 My own view (FWIW), having cabled several homes, is to install the modem and/or router where the external signal arrives in your property, then immediately after it install a 24 or 48-port secure gigabit switch. They aren't expensive. Then you run one or two Cat 6 cable spans to each room (excluding bathrooms of course). This was easy in my last big home as it was built on a hillside and hade huge void areas underneath. YMMV. If you want WiFi, a cheap and cheerful Wifi transceiver on each floor or building should be fine - just tune each to a different channel. You can also plug in a small 8-port GB switch if there are more wired users or devices in a room (TV, Roku, etc...). If you want the highest speed for your porn habit, just plug in a local patch cable. Quote Link to post Share on other sites
Grande Mastere Dreade 4,131 Posted September 8, 2021 Share Posted September 8, 2021 11 hours ago, P_Wop said: If you want the highest speed for your porn habit, just plug in a local patch cable. what if I'm into sloth porn, do I still need high speed internet? Quote Link to post Share on other sites
P_Wop 3,413 Posted September 8, 2021 Share Posted September 8, 2021 5 hours ago, Grande Mastere Dreade said: what if I'm into sloth porn, do I still need high speed internet? Good question. If you're into that, or tortoise porn, just stick with dialup. 14.4 should be plenty. Quote Link to post Share on other sites
Hike, Bitches! 353 Posted September 8, 2021 Share Posted September 8, 2021 15 hours ago, P_Wop said: My own view (FWIW), having cabled several homes, is to install the modem and/or router where the external signal arrives in your property, then immediately after it install a 24 or 48-port secure gigabit switch. They aren't expensive. Then you run one or two Cat 6 cable spans to each room (excluding bathrooms of course). This was easy in my last big home as it was built on a hillside and hade huge void areas underneath. YMMV. If you want WiFi, a cheap and cheerful Wifi transceiver on each floor or building should be fine - just tune each to a different channel. You can also plug in a small 8-port GB switch if there are more wired users or devices in a room (TV, Roku, etc...). If you want the highest speed for your porn habit, just plug in a local patch cable. Having some cat 5 or cat 6 cables for a direct wire between routers/satellites, etc. would be really nice. My last house (2003) I had them do a double Cat 5 run to each cable box in the bedrooms LR, etc. outlet that terminated in the garage. That ended up being really nice and I used it for all kinds of stuff, but I never needed to hardwire routers together though. Quote Link to post Share on other sites
shaggy 1,096 Posted September 8, 2021 Share Posted September 8, 2021 16 hours ago, P_Wop said: My own view (FWIW), having cabled several homes, is to install the modem and/or router where the external signal arrives in your property, then immediately after it install a 24 or 48-port secure gigabit switch. They aren't expensive. Then you run one or two Cat 6 cable spans to each room (excluding bathrooms of course). This was easy in my last big home as it was built on a hillside and hade huge void areas underneath. YMMV. If you want WiFi, a cheap and cheerful Wifi transceiver on each floor or building should be fine - just tune each to a different channel. You can also plug in a small 8-port GB switch if there are more wired users or devices in a room (TV, Roku, etc...). If you want the highest speed for your porn habit, just plug in a local patch cable. Been doing the wifi thing in my house for years beating my head against the wall. Finally just bit the bullet and ran cat5 downstairs and into the bedrooms. $$$ but with everyone moving in, 4 of us now, and at least 2 devices running between us at all times most times 6-7 streaming etc.. It was the only solution as I WFH and my connection speeds were going into the shitter. ... 1 Quote Link to post Share on other sites
mustang__1 344 Posted September 9, 2021 Share Posted September 9, 2021 I think I've got a us robotics 56k in the office closet, want me to send it to you? Quote Link to post Share on other sites
