Renegade-27 7 Posted August 30, 2021 Share Posted August 30, 2021 Hi all - question of main trim... I'm referring to generally light(er) winds, say 8-12 kts. I have an X-34... fractional rig with 106% blade, BIG mainsail. I typically go upwind with noted twist in the leach of my main. I've pulled it to align with centerline (often top telltale curls to leward) but found that the speed decrease outweighs the pointing benefit. It feels like the boat want to be sailed like a dinghy and 'comes to life' letting the leech breath some. Recently I've raced on a 41' boat with a similar rig (fractional with blade) and they are convinced to pull the main in with tight leech upwind. It feels like a brake to me (and we in fact don't do too well) but the highly experienced crew are set on the main trim. What's the collective thoughts here? Sorry, no pics... 1 Quote Link to post Share on other sites
Frogman56 122 Posted August 30, 2021 Share Posted August 30, 2021 Renegade, Find a pic of the Farr 40 world champions from Italy, upwind in 8 TWS: 1. Boom well above cl. 2. Lower quarter height leech on the cl 3. About 20 degrees main twist 4. Main chord depths around 11% For 12 TWS, depths reduced and boom near cl, little or no perceptible twist reduction. Less twist raises the ce and increases the tip vortex... 1 Quote Link to post Share on other sites
Livia 1,086 Posted August 30, 2021 Share Posted August 30, 2021 Only one person can answer your question the person holding the helm at the time maybe time for a better driver 1 Quote Link to post Share on other sites
dogwatch 1,320 Posted August 30, 2021 Share Posted August 30, 2021 There's no single answer. If you are coming off a crowded startline and need to hold your lane, leech hard for pointing mode. Same in flat water. Twist in waves or when you need to build speed e.g. after a tack or a bad wave. 2 Quote Link to post Share on other sites
Steam Flyer 8,451 Posted August 30, 2021 Share Posted August 30, 2021 20 minutes ago, dogwatch said: There's no single answer. If you are coming off a crowded startline and need to hold your lane, leech hard for pointing mode. Same in flat water. Twist in waves or when you need to build speed e.g. after a tack or a bad wave. ^ this^ Driving up, immediately after a start... approaching another boat on starboard... pinching to get around the windward mark... there are a few circumstances in which a temporary tactical consideration outweighs max VMG. Otherwise, you want max VMG for that wind speed/wave condition. Same wind, more waves = more twist. But in general it's easy to overdo twist and lose a bit of pointing. FB- Doug 1 Quote Link to post Share on other sites
neuronz 70 Posted August 30, 2021 Share Posted August 30, 2021 I have seen many boats having their leeches too tight which then drop the traveller to reduce heeling. Inefficient. I think some of this due to sailors moving up from dinghy classes where you can use vang and boom to induce mast bend and flatten the sail. This usually does not work on yachts. Generally stalling the sail is not fast as it creates less drive force and more heel. You might have to play with the upper part of the sail. With a fractional rig this area will not benefit from the inflow from the jib and thus stalls more easily. In certain conditions it thus might make sense to stall it, but only the upper part. Mainsail trim also depends a lot on the characteristics of your boat and conditions. For example in a high performance boat with slender appendages if in doubt I would rather trim for speed and add twist to get the appendages to work. Same in waves where you need more power and have more risk of dynamic stall due to boat motions. Quote Link to post Share on other sites
gn4478 82 Posted August 30, 2021 Share Posted August 30, 2021 This is the best book on sail trim I have ever read. Excellent pictures of what you sail should look like when shifting gears. https://www.amazon.com/Sailboat-Racing-Greg-Fisher-Hubbell/dp/0970357109/ref=cm_cr_arp_d_pdt_img_top?ie=UTF8 Quote Link to post Share on other sites
danstanford 130 Posted August 30, 2021 Share Posted August 30, 2021 I always thought I should take twist out till the upper leech telltales start to stall or you have too much heel. Benchmark is upper batten parallel with the boom . Am i giving up speed by doing this? If so, how do you decide how much twist you should add? Quote Link to post Share on other sites
bridhb 921 Posted August 30, 2021 Share Posted August 30, 2021 3 minutes ago, danstanford said: I always thought I should take twist out till the upper leech telltales start to stall or you have too much heel. Benchmark is upper batten parallel with the boom . Am i giving up speed by doing this? If so, how do you decide how much twist you should add? My boat has a rig similar to the X, and I have to carry a lot of twist in the main with the 110. The upper batten is definitely to leeward of the boom to keep the upper batten (full batten main) tale at least partially flying as it is not in air directed by the jib. In light air, to get that much twist, I sometimes have to have the traveler up to windward and the mainsheet eased. I do have a pretty heavy boom section though, it is the same section as used for the mast. As Neuronz wrote, stalling the upper main seems to slow the boat down and add helm. I need to carry even more twist with the 155. I like fractional rigs as I sail solo mostly and the jibs are smaller for the boat size (33.5'), but it seems more fiddly to get the main correct compared to the mast head boats I have had in the past. Quote Link to post Share on other sites
some dude 201 Posted August 30, 2021 Share Posted August 30, 2021 Look at the telltales on the leech of the main. Are they flying? No? Ease trav or sheet. Yes? See if you can pull it in some more (then watch the speedo) Look at your friends. Are the falling over because the boat is flipping over? Yes? Trav down Look at the helmsman. Are his or her arms getting more ripped by the second from pulling on the tiller so hard? Yes? Trav down Pull the main in as hard as you can get away with, watching those 3 things and mostly the speedo. Main trimmer is the throttle man. Also depends on tactical situation (fighting to hold lane? Footing toward the shift? Overstood?) YMMV 2 Quote Link to post Share on other sites
TJSoCal 274 Posted August 30, 2021 Share Posted August 30, 2021 11 hours ago, Renegade-27 said: we in fact don't do too well) but maybe because the "highly experienced" crew are set on the main trim Maybe convince them to try something different and see if it makes a difference? I think conventional wisdom for moderate air is boom right around centerline and get the top telltale stalling about 70% of the time. If you start getting too much heel or helm, some boats like traveler down and others like easing sheet and letting the top twist off a bit. 1 Quote Link to post Share on other sites
Left Shift 3,628 Posted August 30, 2021 Share Posted August 30, 2021 Batten parallel to the boom is from the old IOR ribbon main day where you had to press the boat uphill to overcome the genoa. Fractional rig the traveler sets the angle of attack and the mainsheet the twist/depowering. Main trim also has to do with the efficiency of your keel. These guys like to point, but they need speed to do so with their narrow keels. So traveler down can help with speed build. Quote Link to post Share on other sites
Somebody Else 899 Posted August 31, 2021 Share Posted August 31, 2021 I like trimming main especially when it's for a driver with whom I have a lot of confidence/experience. Having done this for several decades, I have a pretty good idea what the main should look like for given wind speeds and sea states. IN GENERAL. Modify that theoretical ideal shape for a particular boat's characteristics. After I have a good-looking sail (should take under a minute) I turn my attention to the helm/helmsman. You can tell when a helmsman is in the zone and a lot of that has to do with the feel of his/her helm. If the helmsman has to dial in too much weather helm -- drop the traveler an inch. Wait 2 seconds and see if that's enough or if it needs another inch. Small increments. By concentrating on the helm, I can help the driver "walk" that boat upwind. I will glance up at the sail every minute or so to make sure I haven't lost touch with the basic shape but that very rarely happens; by starting with good base trim and then staying in touch with the driver's inputs, you tend to stay pretty close to where you need to be. I have been known to use my super-powers for evil (use my experience with main trim to subtly dictate tactics.) Without saying a word, you can "suggest" that maybe the driver should be going for more point... or driving for some more speed. When you have a lot of confidence/experience with a driver, you get to know what they would like to do in a given situation. The brief conversations should take place on a fairly high level, not at the nuts and bolts level. This is extremely satisfying and fun. 4 Quote Link to post Share on other sites
TUBBY 453 Posted August 31, 2021 Share Posted August 31, 2021 You have to know how your boat performs best. Some get best vmg sailed high with a tight leech, (many) others will respond better to footing and sometimes a surprising amount of twist. But you also need to know/read your helmsman, a bit more twist (in conjunction with matching heady trim), will usually make an average helmsman more comfortable and be quicker simply through being less demanding to steer to. Often you will have different baselines for different helms on the same boat. 2 Quote Link to post Share on other sites
TUBBY 453 Posted August 31, 2021 Share Posted August 31, 2021 Somebody has said this better while I was posting! Quote Link to post Share on other sites
Livia 1,086 Posted August 31, 2021 Share Posted August 31, 2021 17 minutes ago, TUBBY said: Somebody has said this better while I was posting! Too open? Lets go to the TV audience! Quote Link to post Share on other sites
TUBBY 453 Posted August 31, 2021 Share Posted August 31, 2021 Not enough information to even guess with an accuracy rating above 50%! 1 Quote Link to post Share on other sites
Somebody Else 899 Posted August 31, 2021 Share Posted August 31, 2021 43 minutes ago, TUBBY said: Somebody has said this better while I was posting! We said pretty much the exact same things! Quote Link to post Share on other sites
Left Shift 3,628 Posted August 31, 2021 Share Posted August 31, 2021 27 minutes ago, Livia said: Too open? Lets go to the TV audience! You might try hiking. Like the guy pointing in front of you. 1 Quote Link to post Share on other sites
Irish River 159 Posted August 31, 2021 Share Posted August 31, 2021 Another thing to consider is making sure the leech of jib is similar to main. I've seen and been a trimmer to focused on a jib or a main, while forgetting to big picture of the whole sail plan. Quote Link to post Share on other sites
Livia 1,086 Posted August 31, 2021 Share Posted August 31, 2021 3 hours ago, Left Shift said: You might try hiking. Like the guy pointing in front of you. That was not the question, and obviously maths is not a strong point. Quote Link to post Share on other sites
Left Shift 3,628 Posted August 31, 2021 Share Posted August 31, 2021 9 minutes ago, Livia said: That was not the question, and obviously maths is not a strong point. OK, putting 500# on the rail will increase the the righting moment be approximately 2,500#, which will allow the traveler to be raised approximately 2.5" and the mainsheet to be eased approximately 1" and improve boat speed by .15 knots and pointing by 1.2°. What would really help would be to have a picture from dead astern, but while they are waiting for the photoboat to maneuver around, they might block the mast forward at the partners to induce some lower bend and then try putting on some topmast to take about 30% of the draft out of that main, and open up that airbrake of a lower leach. Then try traveler up and grind on some sheet. And have a beer. Really, WTF does "maths" have to do with recommending hiking? 3 Quote Link to post Share on other sites
greasy al 58 Posted August 31, 2021 Share Posted August 31, 2021 5 hours ago, Left Shift said: OK, putting 500# on the rail will increase the the righting moment be approximately 2,500#, which will allow the traveler to be raised approximately 2.5" and the mainsheet to be eased approximately 1" and improve boat speed by .15 knots and pointing by 1.2°. What would really help would be to have a picture from dead astern, but while they are waiting for the photoboat to maneuver around, they might block the mast forward at the partners to induce some lower bend and then try putting on some topmast to take about 30% of the draft out of that main, and open up that airbrake of a lower leach. Then try traveler up and grind on some sheet. And have a beer. Really, WTF does "maths" have to do with recommending hiking? And that’s outta the park and still rising Quote Link to post Share on other sites
Grande Mastere Dreade 4,184 Posted September 1, 2021 Share Posted September 1, 2021 On 8/30/2021 at 6:46 PM, Livia said: Too open? Lets go to the TV audience! I'd go with , too much belly, .. more luff tension and move it forward a little bit.. Quote Link to post Share on other sites
danstanford 130 Posted September 2, 2021 Share Posted September 2, 2021 On 8/30/2021 at 2:37 PM, some dude said: Look at the telltales on the leech of the main. Are they flying? No? Ease trav or sheet. Yes? See if you can pull it in some more (then watch the speedo) Look at your friends. Are the falling over because the boat is flipping over? Yes? Trav down Look at the helmsman. Are his or her arms getting more ripped by the second from pulling on the tiller so hard? Yes? Trav down Pull the main in as hard as you can get away with, watching those 3 things and mostly the speedo. Main trimmer is the throttle man. Also depends on tactical situation (fighting to hold lane? Footing toward the shift? Overstood?) YMMV In lighter airs (4-8 kts), we are struggling with the boat feeling more sluggish then it seems she should. With no weather helm at all beating up the course we go down a similar analysis, boom at CL, all main leech telltales flying, both sails pretty flat, and still no feel in the helm or acceleration. Do we have to accept that this is as good as it gets when it is this light or where would you search for more speed? The only thing we haven't really done is try for lots of twist in the main because we are focused on leech telltales and they seem fine. We have in-haulers which we try to set with the North Sails guide even though the sail always looks like it would be better with less in-fucking. Quote Link to post Share on other sites
Livia 1,086 Posted September 2, 2021 Share Posted September 2, 2021 On 8/31/2021 at 2:45 PM, Left Shift said: OK, putting 500# on the rail will increase the the righting moment be approximately 2,500#, which will allow the traveler to be raised approximately 2.5" and the mainsheet to be eased approximately 1" and improve boat speed by .15 knots and pointing by 1.2°. What would really help would be to have a picture from dead astern, but while they are waiting for the photoboat to maneuver around, they might block the mast forward at the partners to induce some lower bend and then try putting on some topmast to take about 30% of the draft out of that main, and open up that airbrake of a lower leach. Then try traveler up and grind on some sheet. And have a beer. Really, WTF does "maths" have to do with recommending hiking? Still not good at counting! Quote Link to post Share on other sites
Left Shift 3,628 Posted September 2, 2021 Share Posted September 2, 2021 58 minutes ago, Livia said: Still not good at counting! Undies? Bunched? Quote Link to post Share on other sites
Frogman56 122 Posted September 2, 2021 Share Posted September 2, 2021 Dan, Boom above cl will help. Try bottom batten at cl 1 Quote Link to post Share on other sites
Rain Man 1,992 Posted September 3, 2021 Share Posted September 3, 2021 Set the boom on the centreline and the top batten parallel to the boom, then ease the mainsheet very slightly to open the top an inch or so from parallel. Try that setting and see if it works better. There are so many factors at play here. Some boats need the extra sheet tension to shape the main properly and to get enough forestay tension. Others prefer the top batten a little open. If your boat has running backstays, check the sag in the headstay at each main setting you try. The sag must be kept constant by the running backstay tension in order to conduct proper mainsail trim testing. If the sag is changing that will make as big or a bigger difference to the way the boat sails and feels. Check your halyard tensions too. Just enough halyard tension to remove the horizontal wrinkles is what you want. Many sailors are sailing around with too much halyard tension because it makes the sail "look good". The sail does look good but the entry angle is too large, so you can't point. This is a very common way to lose races - if you can't point off the starting line you are quickly shuffled to back of the pack and will struggle to make gains from there on. All because you had too much halyard tension on. This is a painful lesson that has to be learned. YMMV. 1 Quote Link to post Share on other sites
TJSoCal 274 Posted September 3, 2021 Share Posted September 3, 2021 1 hour ago, Frogman56 said: Dan, Boom above cl will help. Try bottom batten at cl Agree with this. Some boats like a lot of twist in the main especially in light air. Travel most of the way up and adjust sheet tension & traveler position so bottom batten is in line with the backstay and top telltale is stalling on the leeward side of the sail much of the time. Also remember to ease outhaul to put some depth in. Quote Link to post Share on other sites
Kenny Dumas 408 Posted September 3, 2021 Share Posted September 3, 2021 Great conversation Y’all. Thanks Quote Link to post Share on other sites
Tunnel Rat 1,232 Posted September 3, 2021 Share Posted September 3, 2021 13 hours ago, Left Shift said: Undies? Bunched? Double handed....... (my guess). Quote Link to post Share on other sites
danstanford 130 Posted September 3, 2021 Share Posted September 3, 2021 9 hours ago, Rain Man said: Set the boom on the centreline and the top batten parallel to the boom, then ease the mainsheet very slightly to open the top an inch or so from parallel. Try that setting and see if it works better. There are so many factors at play here. Some boats need the extra sheet tension to shape the main properly and to get enough forestay tension. Others prefer the top batten a little open. If your boat has running backstays, check the sag in the headstay at each main setting you try. The sag must be kept constant by the running backstay tension in order to conduct proper mainsail trim testing. If the sag is changing that will make as big or a bigger difference to the way the boat sails and feels. Check your halyard tensions too. Just enough halyard tension to remove the horizontal wrinkles is what you want. Many sailors are sailing around with too much halyard tension because it makes the sail "look good". The sail does look good but the entry angle is too large, so you can't point. This is a very common way to lose races - if you can't point off the starting line you are quickly shuffled to back of the pack and will struggle to make gains from there on. All because you had too much halyard tension on. This is a painful lesson that has to be learned. YMMV. Funny, my main trimmer and I were swapping emails to discuss the feel of the boat and we mentioned the fact that the last time this happened someone added main halyard tension as well and we probably had too much. Will try that for sure along with getting the boom above CL. Quote Link to post Share on other sites
climenuts 242 Posted September 3, 2021 Share Posted September 3, 2021 I'm generally looking at the leeward luff telltales on the main to determine halyard tension. If they're not flying I ease to flatten the entry and make sure the luff isn't stalled. This also keeps the draft further aft in light air and helps give the boat some helm. 1 Quote Link to post Share on other sites
Left Shift 3,628 Posted September 3, 2021 Share Posted September 3, 2021 7 hours ago, Tunnel Rat said: Double handed....... (my guess). I thought so too, until I counted at least 3 people on board. One sitting to leeward, staring at the jib. Quote Link to post Share on other sites
Livia 1,086 Posted September 3, 2021 Share Posted September 3, 2021 Come on everyone, you can do better. Quote Link to post Share on other sites
Rain Man 1,992 Posted September 3, 2021 Share Posted September 3, 2021 13 hours ago, danstanford said: Funny, my main trimmer and I were swapping emails to discuss the feel of the boat and we mentioned the fact that the last time this happened someone added main halyard tension as well and we probably had too much. Will try that for sure along with getting the boom above CL. On your boat, I would recommend boom on the centre line. Boom above centre line only for pinching someone out after the start or staying above someone who is doing that to you. I think you will find that putting the boom above centre line costs too much in speed. If you have VMG on your boat try it and see what the effect is. Pointing higher than the keel can point without stalling is a common problem. Some boats are designed to point super high and carry additional sail area to be able to achieve that - TP 52's for example. I doubt pointing super high will work for you, but it is worth a try. 1 Quote Link to post Share on other sites
