Ryan.. 7 Posted August 31, 2021 Share Posted August 31, 2021 Anyone have an idea of the approximate carbon fiber skin thickness for a 60ft-80ft catamaran hull, over 1 inch? 5lb density pvc core. In the general non-reinforced areas, hulls and deck Thanks Quote Link to post Share on other sites
BGeff 281 Posted August 31, 2021 Share Posted August 31, 2021 Call up Gougeon Brothers/West System Epoxy. Or Mike Bell at Offshore Catamarans. Quote Link to post Share on other sites
fastyacht 2,594 Posted August 31, 2021 Share Posted August 31, 2021 ????? Everything depends on details. Sheesh. Is this an engineering question or justvwinging it? Quote Link to post Share on other sites
Reference 117 Posted August 31, 2021 Share Posted August 31, 2021 No single answer, the point of composite laminates is to engineer the laminate schedule according to load paths. That said, for a general rule, the minimum skin thickness in [non-reinforced areas] is probably going to be limited by the # of layers required to orient the loads & resist puncturing, rather than the absolute minimum calculated required strength. So most likely [at least] 1-2 layers of biax and a layer of uni, or maybe 3 layers of uni oriented at 0/30/30 at about .012-.015" per layer, vaccuum bagged & cured. A rough approximation is to add 60-100% thickness & weight to the raw carbon material, for a complete laminate. But really if you're going to the expense of carbon, it should be engineered and layed up using vacuum-infusion to maximize the material characteristics. Quote Link to post Share on other sites
Ryan.. 7 Posted August 31, 2021 Author Share Posted August 31, 2021 1 hour ago, Reference said: No single answer, the point of composite laminates is to engineer the laminate schedule according to load paths. That said, for a general rule, the minimum skin thickness in [non-reinforced areas] is probably going to be limited by the # of layers required to orient the loads & resist puncturing, rather than the absolute minimum calculated required strength. So most likely [at least] 1-2 layers of biax and a layer of uni, or maybe 3 layers of uni oriented at 0/30/30 at about .012-.015" per layer, vaccuum bagged & cured. A rough approximation is to add 60-100% thickness & weight to the raw carbon material, for a complete laminate. But really if you're going to the expense of carbon, it should be engineered and layed up using vacuum-infusion to maximize the material characteristics. yes, agreed, it should be engineered, eventually, but when doing preliminaries on costs, best methods etc. scantlings or other rules of thumb are useful. Could not find scantlings on carbon sandwich, maybe I didn't look hard enough. >0/30/30 at about .012-.015" per layer, vaccuum bagged & cured Thanks. This helps. So around 1mm? from the 0/30/30 assuming the zero is most critical (depending on bulkhead spacing) Quote Link to post Share on other sites
fastyacht 2,594 Posted August 31, 2021 Share Posted August 31, 2021 Setimrs y ou need to do some prelim eng desgn to beable to makr a useful wgt est. Blowing smoke rarelyvworks. Unlesscyoi are Hunter S Thompson Quote Link to post Share on other sites
Ryan.. 7 Posted August 31, 2021 Author Share Posted August 31, 2021 2 minutes ago, fastyacht said: Setimrs y ou need to do some prelim eng desgn to beable to makr a useful wgt est. Blowing smoke rarelyvworks. Unlesscyoi are Hunter S Thompson I'd like some of what you're smoking If you don't know the answer it's ok to admit it 2 Quote Link to post Share on other sites
Reference 117 Posted August 31, 2021 Share Posted August 31, 2021 Stating the obvious, but overall size of the boat matters too. Something like a J/22, the minimum carbon thickness for strength is going to be determined by what's available in cloth, whereas a 50' boat, that 2/3 layers would likely be of insufficient strength to carry the loads. Quote Link to post Share on other sites
nota 87 Posted August 31, 2021 Share Posted August 31, 2021 is there a conversion factor for the same hull in glass vs carbon lay up a X weight of glass per sq = Y weight of carbon per sq ? Quote Link to post Share on other sites
Ryan.. 7 Posted August 31, 2021 Author Share Posted August 31, 2021 18 minutes ago, Reference said: Stating the obvious, but overall size of the boat matters too. Something like a J/22, the minimum carbon thickness for strength is going to be determined by what's available in cloth, whereas a 50' boat, that 2/3 layers would likely be of insufficient strength to carry the loads. Seems logical. There are most certainly some rules of thumb or scantling calcs, on these as there are with fiberglass or wood etc. Quote Link to post Share on other sites
Zonker 5,223 Posted August 31, 2021 Share Posted August 31, 2021 Seriously why are you asking? If you are considering building a boat ask the designer. If you are doing a proper cost estimate you should have some preliminary plans as a bare minimum. Way too many variables to even guess. Vacuum bagged? Resin infused? Pre-preg? If you are doing a cost estimate the difference in cost of guess A and guess B won't matter. Why? An 80' catamaran has many, many thousands of manhours of labour in it. It will dominate the cost estimate rather than material costs of the skin. Ask SOMA about Gunboat construction costs... 2 Quote Link to post Share on other sites
Reference 117 Posted August 31, 2021 Share Posted August 31, 2021 10 minutes ago, nota said: is there a conversion factor for the same hull in glass vs carbon lay up a X weight of glass per sq = Y weight of carbon per sq ? No. Because if the question is "what is the minimum required", that answer may reflect the available cloth rather than the absolute strength. I know someone who just reskinned a fiberglass sport boat in carbon. It's not going to weigh any less than before, b/c 2 layers of carbon laminate weighs about the same as 2 layers of fiberglass even if it's stronger. And just because carbon is stronger/stiffer, you can't get away with half a layer of it. Quote Link to post Share on other sites
Bruno 137 Posted August 31, 2021 Share Posted August 31, 2021 Umm, just a chippie but I heard somewhere that safety factors vary upon intended use. A cruising boat may use a 3x load factor, a racing yacht 2x or less, fortunately (?) insurance adjusters seem generally unaware of this. You are actually getting some expert replies here, some estimate these projects on weight. A designer should have a target weight he can provide, different builders will have different costs per kg. Then factor in how do you feel about holes in the hull. Quote Link to post Share on other sites
fastyacht 2,594 Posted August 31, 2021 Share Posted August 31, 2021 1 hour ago, Ryan.. said: I'd like some of what you're smoking If you don't know the answer it's ok to admit it Hey I docthis forca living. I have MDD. Do as I recommenx amd tou too will be hi on life and your boatcwill float on its limes Quote Link to post Share on other sites
fastyacht 2,594 Posted August 31, 2021 Share Posted August 31, 2021 57 minutes ago, Reference said: No. Because if the question is "what is the minimum required", that answer may reflect the available cloth rather than the absolute strength. I know someone who just reskinned a fiberglass sport boat in carbon. It's not going to weigh any less than before, b/c 2 layers of carbon laminate weighs about the same as 2 layers of fiberglass even if it's stronger. And just because carbon is stronger/stiffer, you can't get away with half a layer of it. News flash. Carbon isvnotv stronger. Only stiffer. On square area. Somewhat stronger ontex basis. It is stiffer. 1 Quote Link to post Share on other sites
Zonker 5,223 Posted August 31, 2021 Share Posted August 31, 2021 Well it's a bit less dense so that helps too. Quote Link to post Share on other sites
Ryan.. 7 Posted August 31, 2021 Author Share Posted August 31, 2021 3 hours ago, Zonker said: Way too many variables to even guess. Vacuum bagged? Resin infused? Pre-preg? Assume 60/65% fiber volume fraction. We are able to guess just fine with fiberglass scantlings .. all I need is 3 variables to get skin thickness for those.. why would carbon be any different ? Quote Link to post Share on other sites
Zonker 5,223 Posted August 31, 2021 Share Posted August 31, 2021 You understand that a 80' boat weighs about double a 60' boat if it is a geosim right? So maybe the skin thickness to handle what is getting to be global loads might differ. 1mm is a good starting point as a bare minimum for a 60' version. There. Now go and price out a multi million dollar boat on that basis. 2 Quote Link to post Share on other sites
Reference 117 Posted August 31, 2021 Share Posted August 31, 2021 Why do you want carbon anyway? Unless you're going to invest the time/$$ in design & quality construction techniques, there's no weight savings over a well-engineered fiberglass structure. Quote Link to post Share on other sites
Ryan.. 7 Posted August 31, 2021 Author Share Posted August 31, 2021 2 hours ago, Reference said: there's no weight savings over a well-engineered fiberglass structure. May want to let the AC builders know that secret, would save them huge 1 Quote Link to post Share on other sites
JohnMB 559 Posted August 31, 2021 Share Posted August 31, 2021 45 minutes ago, Ryan.. said: May want to let the AC builders know that secret, would save them huge It's fine, they already know. Of course they do : 2 hours ago, Reference said: invest the time/$$ in design & quality construction techniques, So they get the benefit :). (They also seem to like using aluminum honeycomb for core, and only an insane person would consider that for a boat that actually had to spend any time in the water ) There are plenty of aircraft makers who make very light efficient structures with glass sandwich construction. Especially once you get the skins down to 1 or 2 layers. Quote Link to post Share on other sites
Ryan.. 7 Posted August 31, 2021 Author Share Posted August 31, 2021 13 minutes ago, JohnMB said: There are plenty of aircraft makers I've helped build aircraft.. quite familiar with the various build options, but you may have noticed, boats travel on water not air. Let's not compare apples to bananas If carbon was the same cost as glass, most boats would be made from carbon. But you go ahead and build in floppy fiberglass. That was not the question Quote Link to post Share on other sites
Ryan.. 7 Posted September 1, 2021 Author Share Posted September 1, 2021 Seems everyone wants to argue fiberglass is better than carbon, rather than answer the question. I already have access to carbon and ... "19mm H80 foam 1.5 kgs per sq m,with average of 450 gsm carbon (1.8 kgs/sq m) each side it would weigh (1.5+1.8+0.5 (wet out the foam) = 3.8 kgs per sq m. Replace the carbon with twice as much glass, it would be 1.5+1.8+1.8+0.5= 5.6 kgs/sqm. Difference on 126 sq m is 227 kgs..." but found the answer to my question. 1/2 x glass or thereabouts so will just use glass scantlings, thanks you can carry on convincing yourselves fiberglass is better Quote Link to post Share on other sites
Reference 117 Posted September 1, 2021 Share Posted September 1, 2021 1 hour ago, Ryan.. said: 27 minutes ago, Ryan.. said: you can carry on convincing yourselves fiberglass is better I think I’ll “carry on” convincing myself that it’s better to like… do actual engineering analysis on a 60’ cat design. but to each his own… 2 Quote Link to post Share on other sites
fastyacht 2,594 Posted September 1, 2021 Share Posted September 1, 2021 2 hours ago, Ryan.. said: I've helped build aircraft.. Okay then...so why are you asking? So far you have at least two nav archs involved here. I think there may be a third...but you definitely know better. Pics or it didn't happen. Quote Link to post Share on other sites
Sail4beer 3,408 Posted September 1, 2021 Share Posted September 1, 2021 9 hours ago, fastyacht said: Setimrs y ou need to do some prelim eng desgn to beable to makr a useful wgt est. Blowing smoke rarelyvworks. Unlesscyoi are Hunter S Thompson Are you suggesting contacting an actual naval architect or engineer? Quote Link to post Share on other sites
Autonomous 1,230 Posted September 1, 2021 Share Posted September 1, 2021 Why the hell would you spend $25,000 to insure a $350,000 investment? We have internet wizards with almost as many opinions as assholes! 1 Quote Link to post Share on other sites
Ryan.. 7 Posted September 1, 2021 Author Share Posted September 1, 2021 10 hours ago, fastyacht said: so why are you asking you are a bit slow. we are not building aircraft but boats, very different environment, very different scantlings Quote Link to post Share on other sites
fastyacht 2,594 Posted September 1, 2021 Share Posted September 1, 2021 23 minutes ago, Ryan.. said: you are a bit slow. we are not building aircraft but boats, very different environment, very different scantlings Okay whatever. Sheesh. Like I said. Pics or it didn't happen. Quote Link to post Share on other sites
fastyacht 2,594 Posted September 1, 2021 Share Posted September 1, 2021 10 hours ago, Sail4beer said: Are you suggesting contacting an actual naval architect or engineer? Lol well he managed to contact not one but two of them. Something tells me he only wants free advice, though. Quote Link to post Share on other sites
Sail4beer 3,408 Posted September 1, 2021 Share Posted September 1, 2021 I think he doesn’t want advice. He just wants an audience to laud his innovative and unique approach to solving the age old problem of being shit flat broke and wanting what he can’t afford. 1 Quote Link to post Share on other sites
Sail4beer 3,408 Posted September 1, 2021 Share Posted September 1, 2021 Maybe Perry and Taunton can chime in on this. They might learn something from our new friend Ryan… Quote Link to post Share on other sites
slug zitski 576 Posted September 1, 2021 Share Posted September 1, 2021 46 minutes ago, Sail4beer said: I think he doesn’t want advice. He just wants an audience to laud his innovative and unique approach to solving the age old problem of being shit flat broke and wanting what he can’t afford. Yah Carbon is a waste of money on a cruising boat properly compacted , properly selected , oriented eglass fabrics and properly cured resin will product a very light , strong hull , deck you are best advised to spend weight saving money on foam core interior components , carbon mast , synthetic rigging and molded sails 2 Quote Link to post Share on other sites
fastyacht 2,594 Posted September 1, 2021 Share Posted September 1, 2021 Yabit carbon! I gotta have it! (I felt that way aboit kevlar in 1985. I built a vacuum bagged kevlar rudder. Because it was cool.) Quote Link to post Share on other sites
Ryan.. 7 Posted September 1, 2021 Author Share Posted September 1, 2021 3 hours ago, slug zitski said: Carbon is a waste of money on a Instead of attempt to answer the question asked, idiots will make numerous assumptions about what you are thrying to do, and spew whatever dogma of the day the sheep are flocking to, providing no value to anyone except trying to make themselves feel smart Quote Link to post Share on other sites
sledracr 905 Posted September 1, 2021 Share Posted September 1, 2021 13 minutes ago, Ryan.. said: ... idiots will make numerous assumptions about what you are thrying to do, and spew whatever dogma of the day the sheep are flocking to, providing no value to anyone except trying to make themselves feel smart ....and, in turn, noobs will make random ad-hominem statements about the people who tried to help but who, ultimately, have given you a forum to prove that you aren't smart enough to understand that informed answers have value even if you don't "like" them. 2 Quote Link to post Share on other sites
Rasputin22 3,483 Posted September 1, 2021 Share Posted September 1, 2021 http://www.fiberglasssupply.com/Product_Catalog/Reinforcements/Knitted_Fabrics/Knit_Laminate_Calculators/knit_laminate_calculators.html Start here. And then go here if you really want to get serious. http://vectorply.com/vectorlam-cirrus-2-0/ Let us know what you glean from those two calculators. Quote Link to post Share on other sites
Grande Mastere Dreade 4,124 Posted September 1, 2021 Share Posted September 1, 2021 17 hours ago, fastyacht said: Okay then...so why are you asking? So far you have at least two nav archs involved here. I think there may be a third...but you definitely know better. Pics or it didn't happen. if the flyin' hawaiian can make it 100 yards out of SF bay , I'm sure when Ryan's done, he can at least double that distance.. 1 Quote Link to post Share on other sites
basketcase 793 Posted September 1, 2021 Share Posted September 1, 2021 1 hour ago, Ryan.. said: Instead of attempt to answer the question asked, idiots will make numerous assumptions about what you are thrying to do, and spew whatever dogma of the day the sheep are flocking to, providing no value to anyone except trying to make themselves feel smart wow, so you want the members here to engineer your laminate schedule for free, and when you get an answer you dont like you turn into a proper cunt. awesome. has anyone told you to fuck off newbie, yet? 4 Quote Link to post Share on other sites
Liquid 640 Posted September 3, 2021 Share Posted September 3, 2021 Is the OP also LongJohn? Does the build include ama shock adsorbers? Quote Link to post Share on other sites
basketcase 793 Posted September 3, 2021 Share Posted September 3, 2021 11 minutes ago, Liquid said: Is the OP also LongJohn? Does the build include ama shock adsorbers? I read that thread, and while LongJohn maybe a short stack short of a Denny's breakfast, he did not get as cunty as our boy here. And as for the 'ama shock adsorbers', have a look at an old Formula 40 tri called Adrenaline....... http://trimarancool.blogspot.com/2009/10/adrenalin-is-pumping-again.html 1 Quote Link to post Share on other sites
