  Fun boat to sail. It's tricky to sail single hand. As Sailman said check the chain plates, also everything that goes through the hull and deck to see that what ever, is properly bedded, and backed. That means everything should be backed with a fender washer or backing plate with enough bedding compound (I like Boat Life) to prevent water seepage. This is most important on the Gudgeons and through hull on the stern. You will find the J22 is an easy boat to maintain and sail.
  The only real draw back that I have is, when I have to race PHRF, against bigger boats. And most the time the owners of the larger boats have no clue as to the rules of racing.
