John D 23 Posted November 2, 2021 Share Posted November 2, 2021 Need advice for (2 part epoxy paint or??) for final finish. Have faired and fixed scratches and dings with epoxy surfacing primer But would like to finish spray a durable waterproof finish coat. Suggestions?? Quote Link to post Share on other sites
SloopJonB 12,541 Posted November 2, 2021 Share Posted November 2, 2021 IP2K Dunno about spraying it though 1 Quote Link to post Share on other sites
Will1073 101 Posted November 3, 2021 Share Posted November 3, 2021 3 hours ago, SloopJonB said: IP2K Dunno about spraying it though Sprays beautifully 1 Quote Link to post Share on other sites
John D 23 Posted November 3, 2021 Author Share Posted November 3, 2021 Trailered boat. Will it withstand carpeted bunk rash from frequent launching. I've been led to believe that easy to sand, easy to chafe Quote Link to post Share on other sites
See Level 1,168 Posted November 5, 2021 Share Posted November 5, 2021 Interprotect gets very hard and not easy to sand smooth, that's why it's important to apply it smooth to start with. Best is spraying it, but not recommended for amateurs as it requires a fare amount of specialized spray and safety gear. If you roll it on use a short nap roller and make sure you don't leave any tracks, like the edge of the roller tends to do. Wet sand with a block to suit. 80,120,320 grit...back side of 320 Oh, and keep it off the bunks for a few days to harden up. Quote Link to post Share on other sites
F_L 122 Posted November 5, 2021 Share Posted November 5, 2021 Interprotect sands ok if you get to it the next day. If you wait until fully cured it's hard as hell and will double or triple your sanding time. 1 Quote Link to post Share on other sites
basketcase 793 Posted November 5, 2021 Share Posted November 5, 2021 7 minutes ago, F_L said: Interprotect sands ok if you get to it the next day. If you wait until fully cured it's hard as hell and will double or triple your sanding time. in my experience, theres about a three day window. first day its too soft and gums up the paper, second and third the stuff is awesome and theres grey dust every where, fourth day you are sanding a rock. but the results awe worth it. 1 Quote Link to post Share on other sites
John D 23 Posted November 5, 2021 Author Share Posted November 5, 2021 THANKS, LOVE THE FEEDBACK Quote Link to post Share on other sites
voodoochile 41 Posted November 15, 2021 Share Posted November 15, 2021 Awlgrip 545 Primer. Really hard, can be finish sanded/polished. Quote Link to post Share on other sites
Controversial_posts 140 Posted November 25, 2021 Share Posted November 25, 2021 For a keel job, Best to use alternating grey/white color coats with interprotect. That way you can see how much you have sanded through. Follow up with a final 2x coats grey, then sand to 600/1200grit & apply bottom paint. Quote Link to post Share on other sites
slug zitski 576 Posted November 25, 2021 Share Posted November 25, 2021 On 11/2/2021 at 4:33 PM, John D said: Need advice for (2 part epoxy paint or??) for final finish. Have faired and fixed scratches and dings with epoxy surfacing primer But would like to finish spray a durable waterproof finish coat. Suggestions?? Lead instantly oxidizes Grind the lead bright then paint immediately many times this means several separate small repair patches To prevent wicking , Do not apply the primer to naked lead with a roller .. use brush or spray only Quote Link to post Share on other sites
John D 23 Posted November 28, 2021 Author Share Posted November 28, 2021 10/4 launching soon, will comment on results Quote Link to post Share on other sites
