Bull City 2,596 Posted November 18, 2021 Share Posted November 18, 2021 When did the big renovation of my H-Boat, I removed the bow chocks prior to the painting, and put them back on afterwards. Did I reverse them, i.e. put them on the wrong side? Quote Link to post Share on other sites
SloopJonB 12,642 Posted November 18, 2021 Share Posted November 18, 2021 I don't think so but you did fail to clock the screw heads. 3 Quote Link to post Share on other sites
LakeBoy 111 Posted November 18, 2021 Share Posted November 18, 2021 at least you got your shoes on the right (correct) feet 1 Quote Link to post Share on other sites
allweather 70 Posted November 18, 2021 Share Posted November 18, 2021 Uh... Bull? What difference does it make? Also, I am more concerned about your knotted bow lines. Those left some scratches in my gelcoat/paint after some time of the boat periodically pulling on each bowline and jerking the knot across the deck. Of course your dock is probably less dusty and possibly has less movement than mine, but stuck out to me. This is how mine looks, but no guaranty that it actually is as original... Quote Link to post Share on other sites
See Level 1,188 Posted November 18, 2021 Share Posted November 18, 2021 Judging from the worn down chrome, I'd say they're on as they were originally. Quote Link to post Share on other sites
Bull City 2,596 Posted November 18, 2021 Author Share Posted November 18, 2021 1 hour ago, allweather said: Uh... Bull? What difference does it make? Well, it looks like the line follows the open angle of the chock, so it's easier to come out. I suppose it would be OK if the dock line were led at a more forward pointing angle. Looks like you made your loop with seizing twine. Maybe I'll do that. Is that your electric cord? And what about the big log? Quote Link to post Share on other sites
allweather 70 Posted November 18, 2021 Share Posted November 18, 2021 Now I see what you mean, we should be fine then.(yep, used some bigger twine. Frankly overkill but has worked for years) You're right on the power cord run forward from the lazarette where I have stashed... 15 or so meters which is kind of heavy but useful. The log is the reason why the pic even exist. Sometimes, regular enough, the wood carriers lose some and eventually they tend to find their way through the bay. Which I honestly try not to think about too much. Luckily our local fishermen get rewards for bringing those in and that limits some risk. Also not a container... In this case it was just drifting(pretty harmlessly) between two neighbours' boats and I got it out of the way. Quote Link to post Share on other sites
Grande Mastere Dreade 4,175 Posted November 19, 2021 Share Posted November 19, 2021 20 hours ago, Bull City said: When did the big renovation of my H-Boat, I removed the bow chocks prior to the painting, and put them back on afterwards. Did I reverse them, i.e. put them on the wrong side? i'd say backwards and on the wrong side.. left front goes to right back... Quote Link to post Share on other sites
El Borracho 2,636 Posted November 19, 2021 Share Posted November 19, 2021 Yeah. They are wrong. I’d take them off, sell them, use the money to buy a forestay. 3 Quote Link to post Share on other sites
weightless 709 Posted November 19, 2021 Share Posted November 19, 2021 1 Quote Link to post Share on other sites
Pertsa 270 Posted November 19, 2021 Share Posted November 19, 2021 In Finland I have seen very few bow chocks on H-boats. You know, extra weight on bow ruining performance. 1 Quote Link to post Share on other sites
allweather 70 Posted November 19, 2021 Share Posted November 19, 2021 Haha, yes! Isn‘t it a single eye now or nothing even?(could have sworn I saw someone tie to the forestay...) Race boats are a different kind of breed, though I believe the cockpit locker sealing has not been solved to satisfaction for older boats? Looking to redo mine completely but haven‘t settled yet. Would be easier if I knew where to source the right gasket. Quote Link to post Share on other sites
Pertsa 270 Posted November 20, 2021 Share Posted November 20, 2021 8 hours ago, allweather said: Haha, yes! Isn‘t it a single eye now or nothing even?(could have sworn I saw someone tie to the forestay...) Race boats are a different kind of breed, though I believe the cockpit locker sealing has not been solved to satisfaction for older boats? Looking to redo mine completely but haven‘t settled yet. Would be easier if I knew where to source the right gasket. Yeah, it is that damn drawer handle. I still have no idea how to tie rope to it. My friend uses soft EPDM-tape as seal with latches that tighten locker hatches on. He said that now they are almost dry. Quote Link to post Share on other sites
allweather 70 Posted November 20, 2021 Share Posted November 20, 2021 1 hour ago, Pertsa said: I still have no idea how to tie rope to it. Most I see clipping the bow lines with a snap shackle. Though that works less well if one needs to adjust length from the boat and best for the primary dock where it's always the same... 1 hour ago, Pertsa said: He said that now they are almost dry. Isn't that the truth? "Almost" dry... I have been using similar(foamed rubber tape) to kind of reasonable success, but hatches are old and wood, meaning I can't get enough "down force" without worrying about the fitting in the relatively soft wood... Really thinking about building entirely new hatches because bone dry is ultimately the way to go. Going to have to figure out how to make it work though, especially since the Artekno ones end up with water standing at the lower seal when heeled. Quote Link to post Share on other sites
Diamond Jim 88 Posted November 23, 2021 Share Posted November 23, 2021 Chocks with slanted top projections were called Skene chocks, after their original designer, Norman Skene, a respected yacht designer of the early 20th century. The slanted top business was intended to prevent an anchor rode, which would lead straight ahead, from jumping out of the chock in storm conditions. You did it right. 1 Quote Link to post Share on other sites
