Quickstep192 91 Posted December 26, 2021 Share Posted December 26, 2021 I'm making a new plexiglass cover for my engine control panel. I've got a 9" x 18" piece of 3/8 plexiglass that I must reduce to 9" x 13-1/2". I can use a table saw or a miter saw. Seems a blade with few teeth, could cause chips and a blade with lots of teeth could generate too much heat. Any tips to be had? Quote Link to post Share on other sites
Will1073 102 Posted December 26, 2021 Share Posted December 26, 2021 I use a fine cut wood blade on the table saw all the time with acrylic. I leave a 16th and sand it the rest of the way with a stationary belt sander. 2 Quote Link to post Share on other sites
slug zitski 575 Posted December 26, 2021 Share Posted December 26, 2021 I don’t own a table saw so I use a jig saw use the correct blade , high friction causes the plastic to melt To polish the edges I use polishing wheel flame polishing works but the edge tends to check, crack when used outside Quote Link to post Share on other sites
rocketscott 0 Posted December 26, 2021 Share Posted December 26, 2021 Can you use the old one as a template? You could stick the old piece to the replacement and use a router with a flush cut bit Quote Link to post Share on other sites
Max Rockatansky 913 Posted December 26, 2021 Share Posted December 26, 2021 I’ve always used tape to cut plastics: Quote Link to post Share on other sites
Steam Flyer 8,381 Posted December 26, 2021 Share Posted December 26, 2021 Yep. Tape the edge, use a fine tooth saw (I use a blade for metal), go slow. I used to use a sander to take the melted gobbets off the edge and smooth it out, now I use a hand file. - DSK Quote Link to post Share on other sites
jamhass 133 Posted December 26, 2021 Share Posted December 26, 2021 As mentioned earlier, saw near, but not on, the line. My preference is to then use the original as a template and a router with a piloted bit to finish off. Then a light sanding to remove router marks and polish if you want. If you need to drill holes, either use a special bit for plastic or slightly dull a regular bit so the cutting angle is about 90 degrees. Quote Link to post Share on other sites
SloopJonB 12,554 Posted December 26, 2021 Share Posted December 26, 2021 If you have to saw it, slow feed with a fine toothed blade - treat it like it was metal. The best way is to use the old piece as a template - stick it to the new piece with double sided tape and cut with a flush trim bit on a router table. I've done that to make new hatch lenses and they come out near perfect with only a little fine sanding to perfect the edge. If you have swarf "melted" to the edges it's better to use a file than sandpaper to clean it off. 1 Quote Link to post Share on other sites
Waiex191 64 Posted December 26, 2021 Share Posted December 26, 2021 Our weapon of choice is the bandsaw. One advantage over the jigsaw is the blade motion is in one direction. Here my son was trimming the canopy of the airplane we built while I was supporting the other side. Of course we did the same as everybody else said - cut wide and then use another method to get to your cut line. We used a belt sander and finished up with hand sanding. Quote Link to post Share on other sites
Startracker 52 Posted December 26, 2021 Share Posted December 26, 2021 1 hour ago, SloopJonB said: If you have to saw it, slow feed with a fine toothed blade - treat it like it was metal. The best way is to use the old piece as a template - stick it to the new piece with double sided tape and cut with a flush trim bit on a router table. I've done that to make new hatch lenses and they come out near perfect with only a little fine sanding to perfect the edge. If you have swarf "melted" to the edges it's better to use a file than sandpaper to clean it off. I find the best choice are the fine tooth wood clean cut blades for finishing work. Metal blades are ok but slow and gum up quickly. Two things to make it easier: 1. Set the blade oscillation to 2 not 0, and keep blade speed up and your feed rate wayyyyyyyyy down. 0 oscillation means the blade gets dragged back down the surface and creates melting issues. Oscillation and pushing the saw too hard leads to chipping. A little oscillation and a slow feed rate, you can tell when you're going slow enough because you hear the saw blade contact the piece only on the up stroke. 2. Lube. I use a spray bottle of dish soap and water. Keeps from getting those melted edges and cuts cleaner. 2 Quote Link to post Share on other sites
gkny 26 Posted December 26, 2021 Share Posted December 26, 2021 There is a specific plexiglass blade for a jigsaw that works really well and is easy to control. https://www.amazon.com/Bosch-T102BF-3-Piece-Plexiglas-Bi-Metal/dp/B00CZEGW7E/ref=asc_df_B00CZEGW7E/?tag=hyprod-20&linkCode=df0&hvadid=309869401414&hvpos=&hvnetw=g&hvrand=2540716957454716375&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004172&hvtargid=pla-568021545102&psc=1&tag=&ref=&adgrpid=63364097444&hvpone=&hvptwo=&hvadid=309869401414&hvpos=&hvnetw=g&hvrand=2540716957454716375&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004172&hvtargid=pla-568021545102 Quote Link to post Share on other sites
Quickstep192 91 Posted December 26, 2021 Author Share Posted December 26, 2021 7 hours ago, slug zitski said: I don’t own a table saw so I use a jig saw use the correct blade , high friction causes the plastic to melt To polish the edges I use polishing wheel flame polishing works but the edge tends to check, crack when used outside It’s hard to argue with the results of that video. I can’t saw straight for shit with a jig saw, but I guess there’s where you cut close and sand to the line. Quote Link to post Share on other sites
slug zitski 575 Posted December 26, 2021 Share Posted December 26, 2021 Use a saw guide the tricky part when working with plastic and a saw guide or drilling Templates is the super slippery surface of the plastic sheet In addition to clamps use double sided adhesive tape to stabilize your guide or template to the plastic Quote Link to post Share on other sites
Startracker 52 Posted December 27, 2021 Share Posted December 27, 2021 4 hours ago, Quickstep192 said: It’s hard to argue with the results of that video. I can’t saw straight for shit with a jig saw, but I guess there’s where you cut close and sand to the line. The right blade will help, and the finishing blades are less prone to wander because they have almost no set to the teeth. They make ones for straight lines and ones for curves, you really want to have both. Most larger curves can be done with the straight line blade in a pinch though. The spray bottle of dish soap and water and the light oscillation to the blade are critical, dry is bad, constant contact is bad, heat is bad. far fewer boogers on the edge this way. For straight line cuts you just clamp a piece of aluminum L or a yardstick onto the work piece. I have a festool jigsaw with accessory kit which includes soft shoe bases, hard g10 style bases etc. Also have their guide rails, so it locks onto the track and cuts perfectly straight. Even bevels of any angle are reasonable with it. It will cut nice circles in just about anything, I've cut multiple circles of 2' in aluminium fiberglass and steel with it. That setup is > 1800$ these days though, so unless you're making money with it, 20$ worth of material to make a straight edge is good enough and possibly even free. Other thing that is worth every penny and much cheaper are plastic specific drill bits. 1 Quote Link to post Share on other sites
DrewR 69 Posted December 27, 2021 Share Posted December 27, 2021 I have had zero problems cutting both acrylic & polycarbonate (Lexan & Plexiglass) with a sharp table saw blade. No chipping and a blowtorch to smooth the cut. Quote Link to post Share on other sites
py26129 176 Posted December 28, 2021 Share Posted December 28, 2021 When i re-did the lenses in my old Lewmar hatches, i rough cut the new lenses with a jig saw and a plexi cutting blade. To do the final shaping, stuck the old lens onto the new one with double sided tape and used a router with a flush cutting bit. Worked very well 1 Quote Link to post Share on other sites
Jules 2,808 Posted February 21 Share Posted February 21 On 12/27/2021 at 12:12 PM, DrewR said: I have had zero problems cutting both acrylic & polycarbonate (Lexan & Plexiglass) with a sharp table saw blade. No chipping and a blowtorch to smooth the cut. I've been using plywood blades to cut plastics. The cut can be clean but if the feed rate is too slow, melting can occur. Both Amana and Freud make "no melt" table saw blades specifically for cutting plastics and in a variety of sizes. When we move to replacing fixed ports, I'll be picking up one of those blades. Quote Link to post Share on other sites
Grande Mastere Dreade 4,126 Posted February 21 Share Posted February 21 On 12/26/2021 at 2:24 PM, gkny said: There is a specific plexiglass blade for a jigsaw that works really well and is easy to control. https://www.amazon.com/Bosch-T102BF-3-Piece-Plexiglas-Bi-Metal/dp/B00CZEGW7E/ref=asc_df_B00CZEGW7E/?tag=hyprod-20&linkCode=df0&hvadid=309869401414&hvpos=&hvnetw=g&hvrand=2540716957454716375&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004172&hvtargid=pla-568021545102&psc=1&tag=&ref=&adgrpid=63364097444&hvpone=&hvptwo=&hvadid=309869401414&hvpos=&hvnetw=g&hvrand=2540716957454716375&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004172&hvtargid=pla-568021545102 cool , but I love the fact that it's labeled BOSCH Clean for Plexiglas Bi-Metal Jig Saw Blades and in the picture towards the bottom they state bi-metal is not recommended for plexiglass.. Quote Link to post Share on other sites
Will1073 102 Posted February 22 Share Posted February 22 On 2/21/2022 at 10:40 AM, Grande Mastere Dreade said: cool , but I love the fact that it's labeled BOSCH Clean for Plexiglas Bi-Metal Jig Saw Blades and in the picture towards the bottom they state bi-metal is not recommended for plexiglass.. Then stick to your charts… the bi-metal Bosch jigsaw blades work great. Quote Link to post Share on other sites
danstanford 130 Posted February 22 Share Posted February 22 Table saw or router work great though the router will make better edges with less stress in them. Polishing the edges with a propane torch is not the best as you will force impurities into the edge which will then create problems later. Oxy-hydrogen is the best gas for polishing edges. Quote Link to post Share on other sites
Will1073 102 Posted February 22 Share Posted February 22 My experience with torch polishing is that it will eventually craze along the edge. I prefer to sand up to 600 and then buff the edges Quote Link to post Share on other sites
SloopJonB 12,554 Posted February 22 Share Posted February 22 I sand to 1200 and then lightly flame the edges - they become as polished as the "good" surfaces. Just wave a propane torch over the edge and the finish will appear before your eyes. Easy does it. Quote Link to post Share on other sites
Captain Ujack 8 Posted March 7 Share Posted March 7 Table saw good. Chop saw very very bad. A table saw works well because, as the blade cuts it pushes the material down into the table. If the plexiglass melts and sticks to the blade, the saw will just cut it again and your cut will continue. If you try to cut plexiglass with a chop saw, the plastic can adhere to the blade as it rotates up, causing very undesirable effects. (Bang! Holy Crap! Count your fingers!) You can probably guess, how I know this! Otherwise, most woodworking tools do a pretty good job on the material. I’ve even used electric jointers and hand planes. Good Luck! Quote Link to post Share on other sites
