sliquerick96 1 Posted May 10 Share Posted May 10 Currently figuring out my new NMEA 2k setup. Will my displays still work with the proposed set up? Quote Link to post Share on other sites
Snowden 500 Posted May 10 Share Posted May 10 Why connect the laptop twice? Are you running Expedition or Adrena on it? Why have an N2K network at all when you could connect the GPSMAP 740s plotter over NMEA0183? How does your VHF DSC radio get its GPS position? Does either of the plotters put GPS info on either the Nexus or N2K networks (i.e. can your Nexus multis show SOG and COG)? Do you have any AIS gear on board and if so do you need a 38400 baud NMEA 0183 wiring? Quote Link to post Share on other sites
WHK 94 Posted May 10 Share Posted May 10 The Laptop USB Connection will work on the GND10. You can run the Nexus Race S/W on it. No need to use the serial port connection between laptop and Nexus Server. The NMEA 0183 connection from the Raymarine C Series can also feed the GPS input for the VHF DSC radio. The 740s also has AIS capability. You should consider a 38.4K connection between the VHF radio and the 740s to display AIS contacts. Quote Link to post Share on other sites
sliquerick96 1 Posted May 11 Author Share Posted May 11 1. The laptop probably wont be connected twice, it is just highlighting that it can be plugged into either port 2. I am not a fan of the 740s Chart plotter or raymarine C series. Ultimately I want to remove that and just have a tablet. (Laptop down below and tablet on deck) 3. The displays can show SOG and COG (I believe) 4. I am planning on connecting the VHF Quote Link to post Share on other sites
WHK 94 Posted May 11 Share Posted May 11 This is a moving target. Describe your end state on what you want. You never mentioned the tablet. What kind of boat? What is your intended use (racing Cruising, etc.). Quote Link to post Share on other sites
sliquerick96 1 Posted May 11 Author Share Posted May 11 Part of the problem is that I am still trying to understand what I need/want at the end of the day. This is part learning experience/part upgrade. Ultimately I want a NMEA2k backbone to make it easier to make my upgrades easier in the future. I would love to have data recording everything (fuel levels, RPMs, Amps, volts, everything...) That is more of a want than need.. Express 37, coastal and offshore racing, with a good bit of cruising. The boat has a wheel, not a tiller, with a handrail in front of the wheel where the 740s is mounted. I would add a tablet mount there (with charger). I know visibility and touch screen capabilities can be an issue with tablets, but still preferable to the 740s. The raymarine C series just takes up space on the nav table. The laptop can show everything that charplotter does. The only real benefits I see with the chartplotters is that they act as the GPS. I have a class D VHF which only receives AIS (the picture I originally posted has a different VHF because it was just a google picture). I will need to add a class B AIS transceiver with it's own dedicated GPS. Quote Link to post Share on other sites
sliquerick96 1 Posted May 11 Author Share Posted May 11 Went back to the morning and traced some more wires! Not possible to use the garmin 740s since the wires were snipped (I guess I could just buy new wires and splice them in, but not that motivated to go that route) I am just going to plug the GND10 wires into the empty multiplexer port that says "Nothing". Fingers crossed the multis/tacktick instruments still work! Quote Link to post Share on other sites
rmgeis 8 Posted Thursday at 09:37 PM Share Posted Thursday at 09:37 PM Just got a KC-2W / KC-2W N2K NMEA2000 And NMEA0183 Bidirectional Converter from ebay, haven't used it vet, will let you know when I do. Quote Link to post Share on other sites
sliquerick96 1 Posted Friday at 02:39 PM Author Share Posted Friday at 02:39 PM 17 hours ago, rmgeis said: Just got a KC-2W / KC-2W N2K NMEA2000 And NMEA0183 Bidirectional Converter from ebay, haven't used it vet, will let you know when I do. Great! Thanks! Quote Link to post Share on other sites
