dfw_sailor
- Thread starter
- #21
So this mess is the outboard and solar panel.
Getting the outboard to the right height has been challenging. It is an older yachtwin 9.9hp long shaft, 2 cyl. Works fine although the brack is a bit loose and allows it to jump a bit in reverse if too many revs. Does the job, although it does need to be moved down again now the boat is a further 2 inches out of the water because of the AC drying out everything.
That's why the upper bracket shims arent painted etc. 4 to 1 pulley system with cam cleat. Sits under the solar panel. The solar panel will get a twin soon - just rotate the existing panel 90 degrees and go side by side with them.
Stern light changed to Led. Kept the bow lights as incandescent because they do seem to stand out better at night over distance than led. And on lake Ray Hubbard you really need to be visible at night because of the power boat idjuts. We came within 30' of being run over by a 30' stink boat doing about 30 kts at 11pm while we were anchored. Of course we didnt have our stern light on (have a bright white led anchor light) but this is just an example. Asshole had to take evasive action to avoid running over us from our stern. 5 more second and he would have hit us. He did set up a nasty wake as he turned hard to port. Inside of his boat was fully lit up, bright white cabin, tc screens, family drinking etc. Did I already say Asshole?
A very annoying aspect of the stern arrangement is the pushpit has at some stake taken a strong push from the port side, such that the vertical posts lean about 10 degrees to starboard. Others cant see the effect but I sure as heck can. havent decided whether I need to remove the whole assembly and have it heat bent back into shape, or just tie the boat down hard in the slip and pull it back using a strap / ratchet.
9.9hp longshaft gives us a pleasant 3.5 kts, 5.5 kts if in a hurry and dont mind the 3 x consumption. Irwin 30 displacement is 10k pounds. About 27' waterline. We've had it to about 8 kts under sail, but not been pushed in strong winds - yet.
Got the outboard for free - from a boat that was about to be crushed. Speaking of which, I have my eye on a furler on another boat about to be crushed - The Irwin 30 could really do with a furled staysail (it has previously had a stay sail, with underdeck strop still in place). Sure the lake is only 3 x 5 miles, but why not? The rig easily overpowers, and has a habit much weather helm in a reach / close reach - especially with oldish sails.
