Actually on a cat with 8 feet of beam and twin trapezes, you need to add between 150 and 200 kg of additional RM from the crew, who when fully extended apply this load an additional 4 feet to weather of the windward gunnel - a considerable lever arm. Based of the CofE of the average 6ft crew being through their chest at about 4 ft from their toes. A trimaran might be as wide as it is long - but many are not - and the central hull is only contributing its mass at half beam point. In fact until windward RM is developed (read on why this is unlikely) its RM is generated by a lever arm of only half its beam (9 7 half ft in this case) The additional RM of a Tri needs to be compensated by the additional engineering and structure it carries to achieve the same platform rigidity. So a similar length boat is often much heavier (3 hulls to lug around rather than 2 etc etc) to achieve the same rigidity. Heavier structures are affected proportionally less by their crew weight and position than lighter ones - think Moth (30 kg plus Sailor) vs. MOD70 (4.5T plus crew of say 500kg)
Even Oracle have demonstrated that platform rigidity is highly valued in performance multihulls - both between v.1 & v.2 of their AC72's - but most tellingly with their 45ft test mule that they have subsequently developed which is super rigid in all directions.
Secondly, the only boat to successfully deploy windward RM was SailRocket - but remember that this is a one tack boat only and when it didn't work it nearly killed the pilot. Look for the video of it somersaulting at 50 knots. It also was not hydrofoiling but sailing on very small planing sponsons. Its rig needed to be heavily canted to align its forces with the water foil - and it had some interesting steering characteristics........
This is the reality of text book physics as opposed to real life sailing.
Currently foil developments are successfully reducing drag - and the instability of both wind and water conditions make chasing additional righting moment problematic and potentially dangerous. It would also lead to adding drag back into the equation and loading the structure up. Hydrofoiling is more likely when the structure is feather weight light and rigid. There is enough complexity to attempt to understand and control, without adding the reverse scenario of adding down force from the weather foil.
Using the parallel example of say an F1 car which rolls on a fixed immovable surface (the road or track surface) where the amount of down force is firstly related to speed and secondly limited by the track surface - a very useful hard barrier that resists the car burying itself into the ground unlike water where a boat would fly its windward hull back down to archimedian position (or worse) where the deceleration caused by touchdown would not only spoil the hydro foiling experience - but more likely manifest itself in a violent round up to weather (remember the leeward hull would still be flying and now trying to overtake it' windward brother) or worse...... All of that would (or could happen in a split second) so some very clever active management of flight characteristics would be required - and for many (myself included) would be a step too far from the characteristics of sailboats - it would be akin to putting traction control and ABS of cars on sailboats. I want the hairs on back of my neck stood up for the right reason - not because the on board flight computer has shorted out in its carbon fibre housing.
Bare in mind that F1 have recognised that all the downforce which is great in corners is performance reducing down the straights - so they now back this off in certain sections of the track.
Armchair commentators need to recognise that there is a lot more going on than lawn ornaments will ever demonstrate...........
